Espritmodel.com Heli Air
Old Feb 09, 2013, 09:33 PM
wjs
William
United States, MI, Brighton
Joined Oct 2012
Originally Posted by mrforsyth View Post
It shows 4.2 volts at the output when the pack is accepting charge current. 4.15 volts resting voltage as measured by the DMM subsequent completion of charge is perfectly normal and expected. IMO, any charger that charges to 4.2 volts resting is overcharging, albeit slightly. e.g.- wjs is absolutely correct.
Mark
Kind a like trying to go the speed of light. The closer you get, the more you slow down, until you stop. Hence you can never get there.
wjs is offline Find More Posts by wjs
Old Feb 09, 2013, 09:40 PM
So. Cal.
Haha. Very true.
The asymptotic nature of LiXX charging can be a challenging concept to convey, especially to those who have historical experience with NiXX chemistry.
Now, if we could only have superconductors and lipolys with zero internal resistance...
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 10, 2013, 12:12 PM
Martin7182
Martin.'s Avatar
Bussum, Netherlands
Joined Oct 2009
I agree it's funny. Still I recommend to calibrate your A6 so that it does what it is supposed to do.
Martin
Martin. is offline Find More Posts by Martin.
Old Feb 10, 2013, 01:02 PM
gapi's Avatar
North Georgia
Joined Oct 2010
Hi,
I plugged my power supply into the charger in low light conditions and seen sparks at the port.
Is the thing putting voltage to the outside surface?
gapi is offline Find More Posts by gapi
Old Feb 10, 2013, 01:13 PM
So. Cal.
Nearly all chargers will do this. It's due to high initial current when the input capacitors are charging. Recommend that you first plug the charger into the power supply and then turn on the power supply to eliminate the spark and any potential damage to the charger input section.
Mark
Old Feb 10, 2013, 01:20 PM
wjs
William
Joined Oct 2012
Martin
Mine was right on the money. Should probably not change if it is close as the numbers on the MM and charger float so much it is hard to get a consistent reading between the two. If in doubt, leave it.
Old Feb 10, 2013, 01:35 PM
Martin7182
Martin.'s Avatar
Bussum, Netherlands
Joined Oct 2009
That may indicate another problem, e.g. dirty contacts or an unstable power supply. Mine shows consistent and stable values when connecting a lipo. The reading was a about 30mV off before calibration.
Martin
Old Feb 10, 2013, 01:37 PM
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
Originally Posted by gapi View Post
Hi,
Mine did that every single time and it did it for nearly 3000 charges and 7 years later it's still kicking...so I wouldn't worry about too much about it.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Feb 10, 2013, 02:02 PM
Joined Jan 2013
Not sure whether it has something to do with the battery.
Currently my Syma107G can only fly less than 2 minutes before it became unresponsive after a full charged cycle. It is funny though, it is responding and can throttle as if it was being fully charged after switch off and on (with no delay) the little switch of the heli, but the flight time will be less and less..
I started to see this problem after I changed the dead motor for upper blade. Then I thought it might be the motor of lower blade that cause the faulty so I replace it as well but it didn't resolved. I should have mention if I give the heli forward or backward pitch or rudder the heli would even go dead faster than just stay hovering.
The problem remain even with new mainboard replaced.
Check the reading of its 1S lipo shows 4.26 after fully charged, and non-responsive state of the heli show 3.75.
SO the lipo was overcharged and possible defective already, but how could the heli is not listening while it still hold 3.75V?
OR what could have causing this headache?
Ps. my DMM read 4.2 on other full charged lipo, so no worry for the accuracy over here.
guner7 is offline Find More Posts by guner7
Old Feb 10, 2013, 05:01 PM
Pineville, LA
Joined Dec 2006
How old is your Syma? Usually it becomes unresponsive when the low voltage protection circuit kicks in. If your fully charged battery is going to 3.75V in 2 minutes, you may need to replace the battery. If your heli cuts off due to the low voltage protection circuit, it's a bad idea to turn it back on and run it again. It runs the battery too low and will shorten it's life.
Rob
robgau is offline Find More Posts by robgau
Old Feb 10, 2013, 06:12 PM
gapi's Avatar
North Georgia
Joined Oct 2010
Mark
Thanks. I am using a Walkera small charger's power supply that came with a Heli. Its 15v ~1000mA. I'll start applying it at the wall instead of the charger.
Old Feb 10, 2013, 06:56 PM
wjs
William
Joined Oct 2012
Martin
Would help if I plugged in a batter first. Dooh. No directions to calibration in my docs. Works good now.
Old Feb 10, 2013, 07:54 PM
Joined Jan 2013
It was about 3 months old I guess. I admit the way I treated my Syma in the beginning of time was totally cruel due to lack of knowledge of heli care. I push the battery everytime until it cut off. Then charge immediately, and most of the time it was left unattended for hours, then fly it again once the charge cable is off.
So the battery is really gone bad thanks to my stupidity.. At least the problem doesn't pull any complexity to be fix.
Thanks Rob.
Old Feb 11, 2013, 10:28 AM
Pineville, LA
Joined Dec 2006
Did you replace the motor with a different brand. If the problem started after replacing the motors, your replacement motors may be pulling more current than the original one. This would also give you a much shorter flight time.
Old Feb 11, 2013, 10:44 AM
Barbados
Joined Jan 2011
Martin
I calibrated mine in the beginning and it worked great terminating at 4.20v,having learnt now that charging to the last drop may shorten the batt life span of a lipo.I have recalibrated the charger to it's max on the + side this now fools the charger to terminate at 4.18v.I don't use this charger very much as i have better ones but dollar for what it is it's hard to beat.
The Tug is offline Find More Posts by The Tug
New Product New Bantam e-Station "Dual Balance Board" for BC-6 Charger & PB-6 Balancer RC Accessory Batteries and Chargers 13 Mar 05, 2008 06:30 AM
Making the charger lead for 6-330D ? rc-whirlybird Batteries and Chargers 0 Apr 03, 2005 12:56 AM
Ice Charger...Detects 12.6 voltage early asmokindeal Batteries and Chargers 17 Mar 23, 2005 10:04 AM
Whoops! On Orbit Charger - How do I balance LiPo packs ? lempert Batteries and Chargers 15 May 11, 2004 09:46 AM
Graupner Charger a Schulze 6-330? NewNCEGuy Batteries and Chargers 2 Jul 02, 2003 07:51 AM
