Old Feb 08, 2013, 06:49 PM
wjs is offline
wjs
Find More Posts by wjs
wjs
William
United States, MI, Brighton
Joined Oct 2012
"Since balancing during storage discharge masks potential problems with a pack, I would personally avoid such."
I think that is designers logic to "balance" somewhat during discharge to *error if cell is outside some margin of error (which I can't find what the margin is). So it points out the error, not hides it. If you just discharge to X volts, without balance leads, you have no clue what cells end up at. Unless you manually check with a cell meter after every discharge. I let the computer do the grunge work, it seems to do the job well enouph and better then I would remember to do regularly.
wjs is offline Find More Posts by wjs
Old Feb 08, 2013, 07:20 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
If the voltage differential threshold is sufficiently narrow, I agree that this 'feature' would certainly be less problematic. But then the 'true' differential will be greater than that shown when an error is generated given that the charger has been compensating for the high cells throughout the storage discharge process, hence masking a larger issue. If it did not balance on storage discharge and simply showed cell voltage, the true conditions of the pack would be available on the cell monitor screen. I consider this to be much better. Fortunately, so do Hyperion, FMA, and iCharger.
Is it really that difficult to bust out a cell monitor or DMM to verify individual cell voltage on occasion?
Cheers,
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 08, 2013, 10:51 PM
robgau is offline
Find More Posts by robgau
Pineville, LA
Joined Dec 2006
I've had my Accucel 6 for about 2 years. It seems to work fine but when I'm charging my 1s batteries it stops at 4.2v on the display but when I take the battery off the charger it almost always reads 4.15v. Is that normal or is there some type of firmware update for it?
robgau is offline Find More Posts by robgau
Old Feb 08, 2013, 11:11 PM
wjs is offline
wjs
wjs
William
Joined Oct 2012
It is ok. 4.2v is the constant voltage output by the charger, not the battery voltage. The non-load voltage will differ a little bit depending on battery age and other factors. Could also be variance in the device testing your voltage when you remove it.
Old Feb 09, 2013, 08:53 AM
Martin7182 is offline
Find More Posts by Martin7182
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
I doubt that. Perhaps you should calibrate your A6 first with the calibration program and a voltmeter.
Martin
Martin7182 is offline Find More Posts by Martin7182
Old Feb 09, 2013, 11:07 AM
gapi is offline
Find More Posts by gapi
gapi's Avatar
North Georgia
Joined Oct 2010
Hi, The noober is back.
I connected this battery and chose 0.9A & 7.4(2C) and it came back Connection Break.
I only had the 3-pin connected. Do I need to connect the other? I don't have that adapter yet.
gapi is offline Find More Posts by gapi
Old Feb 09, 2013, 11:24 AM
So. Cal.
4-pin?
Yes, you need to connect both connectors to balance charge your pack. The red JST connects to the main charge port and the white JST-XH balance plug connects to the balance port.
Old Feb 09, 2013, 11:41 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Thanks, I edited my post to say 3-pin.
Old Feb 09, 2013, 12:28 PM
zl3vml is offline
Find More Posts by zl3vml
Sir Jasper
zl3vml's Avatar
Christchurch - New Zealand
Joined Jan 2003
If you are only charging then you only need the two pin connected to the main charging port.
If you want to select the balance charge setting then you will need to connect the white three pin plug up as well.
Mark
zl3vml is offline Find More Posts by zl3vml
Old Feb 09, 2013, 12:49 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Thanks, I made an adapter a little while ago and am balance charging them now.
I just purchased a Heli that came with those batteries and have not worked with the 7.4v 2-cells before or the Accucell6, or any charger of this type, and thanks to you guys I am not stranded.
Old Feb 09, 2013, 01:00 PM
So. Cal.
Nicely done! Looks like your battery is charging perfectly and is in proper balance.
Mark
Old Feb 09, 2013, 01:36 PM
wjs is offline
wjs
wjs
William
Joined Oct 2012
Martin
Not clear what you doubt. Just the way it works.
1) At least on mine, there is no calibration program that I could find.
2) During the CV mode, the volts on the screen and at end of charge is the voltage output (i.e. constant voltage output). Notice it climbs up to 12.60v on a 3S pack. Does not waver after.
3) A Turnigy Watt meter inline shows 12.54v over here even when charger shows 12.6v.
4) After removing the pack, my good multimeter shows 12.52v on the pack. My Hobbico multimeter shows 12.38v. My balance connector voltage alarm rounded it 12.6v. Woah.
So there is multiple levels of margin error involved depending on device. Could be .06v+- or more. There can also be a "floating" voltage on top of pack that should drain off before a real voltage can really be read on pack.
Old Feb 09, 2013, 01:55 PM
wjs is offline
wjs
wjs
William
Joined Oct 2012
Nice work. That is how you do that. Now just get a paraboard V3 at some point. Takes the wear off the chargers XH connectors, makes hooking up a tad easier potentially, and gives you parallel charging for multiple packs, and some short protection as a bonus.
Old Feb 09, 2013, 07:24 PM
Wallop!
Martin7182's Avatar
Bussum, Netherlands
Joined Oct 2009
I doubt whether it is ok to show 4.20V while the real voltage is 4.15V.
To enter the calibration program, power up while pressing "-" and "start" buttons.
Martin
Old Feb 09, 2013, 07:49 PM
So. Cal.
It shows 4.2 volts at the output when the pack is accepting charge current. 4.15 volts resting voltage as measured by the DMM subsequent completion of charge is perfectly normal and expected. IMO, any charger that charges to 4.2 volts resting is overcharging, albeit slightly. e.g.- wjs is absolutely correct.
Mark
New Product New Bantam e-Station "Dual Balance Board" for BC-6 Charger & PB-6 Balancer RC Accessory Batteries and Chargers 13 Mar 05, 2008 06:30 AM
Making the charger lead for 6-330D ? rc-whirlybird Batteries and Chargers 0 Apr 03, 2005 12:56 AM
Ice Charger...Detects 12.6 voltage early asmokindeal Batteries and Chargers 17 Mar 23, 2005 10:04 AM
Whoops! On Orbit Charger - How do I balance LiPo packs ? lempert Batteries and Chargers 15 May 11, 2004 09:46 AM
Graupner Charger a Schulze 6-330? NewNCEGuy Batteries and Chargers 2 Jul 02, 2003 07:51 AM
