@martin555
That's good to know. I wonder if it's just a difference in firmware? |
Latest blog entry: Syma S105 Battery Mod
8.4v x 6A = 50.4W > you can't get to 8A with that charger for those lipos. Plus you are using it to the max. Don't know if that will make a difference in the long run. It might get hot. Stupid fan on mine needs grease periodically to run right. People run up against this limitation all the time. Trying to parallel charge 2200mA lipos is another one. |
NOT enough power to charge bigger packs in a reasonable length of time. |
It's not that bad. I've been using the Accucel-6 to charge my LiIon packs, Lead Acid battery and NiMH packs. And it's fine on my 3s 2200mAH LiPo packs as well. I also use it connected to the computer for LogView. Not bad for a $23 charger IMHO.
But your guys make a good point. For those looking to charger higher capacity LiPo. Spending extra to get a more capable charger is what you should do. |
Circuit Board Component Burned
Hi,
Here's a question for the circuit board experts on this thread. I have had a couple of these chargers since they came out, and they have given good service. I must have shorted something on one of them because i got the tell-tale smell of hot component on sunday .When I opened the case, I could see the component in the photo circled in yellow was damaged plus, of course, the charger no longer works ( selections and screen OK but I get "connection error" every time I hit the start with any kind of battery. So the question is:- What is the component, is this an easy component to obtain and do you think it is worth it? I have already ordered a couple more chargers from Hobbyking but if it is an easy fix I wouldn't mind trying. Thanks in advance, Al |
Joined Feb 2011
I'm sure you can buy whatever it is from any electronics supplier for cheap. If it's "easy" all depends on your skill at soldering SMT components. You said you have a couple chargers. Can't you check one of them to see what the markings on the chip is? Then you could find what it is and where to get it.
Joined Feb 2012
| Thread Tools | |
| New Product New Bantam e-Station "Dual Balance Board" for BC-6 Charger & PB-6 Balancer | RC Accessory | Batteries and Chargers | 13 | Mar 05, 2008 06:30 AM |
| Making the charger lead for 6-330D ? | rc-whirlybird | Batteries and Chargers | 0 | Apr 03, 2005 12:56 AM |
| Ice Charger...Detects 12.6 voltage early | asmokindeal | Batteries and Chargers | 17 | Mar 23, 2005 10:04 AM |
| Whoops! On Orbit Charger - How do I balance LiPo packs ? | lempert | Batteries and Chargers | 15 | May 11, 2004 09:46 AM |
| Graupner Charger a Schulze 6-330? | NewNCEGuy | Batteries and Chargers | 2 | Jul 02, 2003 07:51 AM |
