Old Nov 23, 2009, 11:23 PM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
Thanks Kit, already have another version, but thanks for posting that cause its a bit easier to read. You are now seeing my lack of understanding of electronics Should I just do it like they have the basic temp sensor on page 6? If so what size resistor should I use?
Thanks for help, I am very inexperienced at this side of electronics
discostu956 is offline Find More Posts by discostu956
Old Nov 23, 2009, 11:36 PM
kit is offline
kit
Find More Posts by kit
kit
USA
Joined Oct 2001
It would easier if you would just use the LM35DZ. If you PM me with your address, I'll see it I can send you one in the mail. By the way, you can buy LM35DZ on Ebay.
kit is offline Find More Posts by kit
Old Nov 23, 2009, 11:59 PM
Is my CG correct?
Wollongong, Aus
Joined Sep 2009
Thanks for the offer, really generous of you. I am in Australia so it wouldn't be worth it.
Reason I bought the 335......hmmm, remember I said I am not good with electronics Was at the electronics shop, said I wanted an LM35. he dug around, pulled out the 335 and looked on the spec sheet. Said this would be the same for what I am doing. I stupidly just took his word for it. It was only $3 or something, but now I am just being stubborn and determined to use it for something.
Old Nov 24, 2009, 10:02 AM
V0RT3X is offline
Find More Posts by V0RT3X
Slovenia (EU)
Joined Mar 2009
Originally Posted by gulio View Post
see the yellow tip?
The outer is - and the inner is +
Voltage on power supply when no charger is connected is around 15V so that shouldn't be the problem. Could it drop under load?
Guess it's dead.
V0RT3X is offline Find More Posts by V0RT3X
Old Nov 24, 2009, 11:13 AM
zl3vml is offline
Find More Posts by zl3vml
Sir Jasper
zl3vml's Avatar
Christchurch - New Zealand
Joined Jan 2003
Guess it's dead.
Yes if the power supply is faulty. You should try to measure the voltage with some kind of load on it. Something like two 12v car indicator bulbs in series, or say a 10 - 15 ohm resistor (minimum of 1 watt) across the 15 vpower supply should give you a pretty good indication.
If the voltage does not drop right down then it is probably the Accucell that is faulty which would be my guess anyway.
zl3vml is offline Find More Posts by zl3vml
Old Nov 24, 2009, 11:14 AM
zl3vml is offline
Sir Jasper
zl3vml's Avatar
Joined Jan 2003
An easier test is just connect the Accucell to your 12v car battery and see what it does when you try and charge something.
Old Nov 26, 2009, 03:05 AM
maxwolfie is offline
Find More Posts by maxwolfie
Joined Oct 2009
OK, I've got a new battery. Amp meter is giving me 12v with the deans connector. The Accucel is giving me "Connection Break" with both the Dean's connector AND the balance lead. It does this on Charge OR Balance.
The charger is working fine with a number of other batteries in my collection.
Any ideas?
maxwolfie is offline Find More Posts by maxwolfie
Old Nov 26, 2009, 09:03 AM
V0RT3X is offline
Slovenia (EU)
Joined Mar 2009
Tried yesterday and same thing. But I did try to charge through the balance connector right now and heard a pop and smoke came out.
lol
edit: Connection break now showing up.
Old Nov 26, 2009, 10:44 AM
seisickj is offline
Find More Posts by seisickj
Joined Nov 2009
hello guys
i;m new into electric flying, so help me out
i just purchased this charger along some zippy flightmax lipo batts
from hobbyking.
my question is this, is the discharge connector on the zippy lipo batt
deans or bullet? or if neither, can anyone help me out with the link
to connect the accucel via output to the zippy batts?
I understand that in order to charge and balance, you should use the jst xh
and the output leads, just like the pic above.
i've got zippy batts, turnigy esc and motor, are these compatible (the esc and the batt?)
thanks and sorry but i've been into glow only
seisickj is offline Find More Posts by seisickj
Old Nov 26, 2009, 11:20 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Depending on what size Zippy batts you get as to what connectors are on it. The balance connectors on the Zippy Flightmax and Rhinos have the same connectors as the Accucell. I use Deans on everything, so use them on the charger and whatever batts I get.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Nov 26, 2009, 02:40 PM
Joined Oct 2009
Any ideas?
Update: My Hobbyzone charger seems to be charging it just fine with the balance lead. What gives?
Old Nov 27, 2009, 09:55 PM
Fly-n-3D is offline
Find More Posts by Fly-n-3D
Columbia, S.C.
Joined Aug 2005
Try changing the deans/banana plugs on your charger.
Fly-n-3D is offline Find More Posts by Fly-n-3D
Old Nov 28, 2009, 05:55 AM
Joined Oct 2009
But if it works with three other batteries...... ?
Old Nov 28, 2009, 07:35 AM
Fly-n-3D is offline
Columbia, S.C.
Joined Aug 2005
It won't hurt to try.
Old Nov 28, 2009, 11:30 AM
zl3vml is offline
Sir Jasper
zl3vml's Avatar
Joined Jan 2003
My guess is the balancing plug on the lipo is wired wrong way round. Check the pins with your meter compared to one of the other packs that works for correct polarity.
I had to swop some of mine round, different manufacturers seem to have different plugs/wiring sequences.
Be "very" carefull when you pull the pins out of the balancing connector that you do not short them out. Put something over each one as you remove it.
New Product New Bantam e-Station "Dual Balance Board" for BC-6 Charger & PB-6 Balancer RC Accessory Batteries and Chargers 13 Mar 05, 2008 06:30 AM
Making the charger lead for 6-330D ? rc-whirlybird Batteries and Chargers 0 Apr 03, 2005 12:56 AM
Ice Charger...Detects 12.6 voltage early asmokindeal Batteries and Chargers 17 Mar 23, 2005 10:04 AM
Whoops! On Orbit Charger - How do I balance LiPo packs ? lempert Batteries and Chargers 15 May 11, 2004 09:46 AM
Graupner Charger a Schulze 6-330? NewNCEGuy Batteries and Chargers 2 Jul 02, 2003 07:51 AM
