Old Jan 26, 2003, 10:41 PM
simingx is offline
Find More Posts by simingx
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
Is there such a thing as motor being too powerful/prop being too big?
I installed a Mega 16/15/5 with a Master Airscrew 7x4 (gas) prop on my Wattage F-22, gave it a launch... and round it went, rolling RIGHT INTO the ground 2 meters in front of me! No amount of right aileron could save it
It has a broken stabilator now... I wonder if the torque produced was too much for it to handle?
The motor is turning the prop at about 12,500 RPM.
simingx is offline Find More Posts by simingx
Old Jan 26, 2003, 10:45 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Sure, it can happen.
..a
Old Jan 27, 2003, 12:40 AM
ShredAir is offline
Find More Posts by ShredAir
slope'n somewhere in the Andes
ShredAir's Avatar
Peru, Puno
Joined Mar 2001
Sure. If the tail wags the dog or the prop spins the plane... )
Dieter Mahlein,
http://shredair.com
ShredAir is offline Find More Posts by ShredAir
Old Jan 27, 2003, 01:20 AM
shaneyee is offline
Find More Posts by shaneyee
shaneyee's Avatar
Singapore
Joined Aug 2002
Sounds like what happened to my PicoJet the first time I flew. I launched it upwards with a moderate throw like a parkflyer and it stalled and ate dirt so fast I couldnt even blink -just a few metres in front of me. Dont think it was the torque but rather a stall. You have to throw it hard and straight ahead. Next time we fly and if KP brings the Picojet around .. I'll show you how I throw it. You use as much strenght as you would throwing a football or a softball.
Shane
ShredAir: Thats really outrageous...
shaneyee is offline Find More Posts by shaneyee
Old Jan 27, 2003, 04:45 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Yup. If the plane stalls at full throttle, torque nearly always turns it against prop rotation under power, so it looks like a nasty tip stall whether it is or not. The key is to have the model going fast enough so the ailerons actually work
You aren't going to ever run into torque problems on direct drive.
However, if you have put in a heavier or more powerful motor, sometimes its wise to re-check downthrust/upthrust and CG.
Old Jan 27, 2003, 07:10 AM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
I think the potential problem is worse on a pusher set-up, as there's no propwash over over the control surfaces to give authority at low airspeeds.
tim
tim hooper is offline Find More Posts by tim hooper
Old Jan 27, 2003, 10:47 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Prop too big, motor smells bad after flight.
F-22.. BAD airplane for models!
The verticals get blanketed by the large wing.
Unless you have a LOT of speed all the time, it will do exactly what you saw, all the time.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 27, 2003, 10:09 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Yes, the torque of a powerful motor can sure do that.
As Sparky said, the problem is even worse in pushers as there is no prop blast over the control surfaces to help at low ( launch ) speed.
When you go into high power systems, you NEED to have things like dual rates on the transmitter so you can have large throws for low speeds and switch to smaller ones for flying. As you found out, "flying" throws may not be able to handle the takeoff torque.
Try launching at partial throttle and throwing it as hard as you can.
Hope its repairable.
Dave
DaveW is offline Find More Posts by DaveW
Old Jan 28, 2003, 07:28 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Have you checked to make sure your ailerons weren't reversed? If the ailerons were reversed, the more you tried to correct the roll, the worse you made it.
mkirsch1 is offline Find More Posts by mkirsch1
Old Jan 28, 2003, 07:36 PM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
I have a similar setup on my smallish pusher ...
A few less rpm. Same prop - in fact I've used an 8x3.8 as well. 24" WS, 20.6 ounce AUW. Same pusher config. Same stabilator control - no ailerons. No right/down thrust. Approximately 17 ounces static thrust. Never a hint of torque problems during launch. And I don't heave it nearly as hard as my TwinJet.
A maneuver I enjoy watching (more than flying) is to do a slow circuit at eye level & at high AoA and then punch it for a steep, slow climbout. Again, never experienced any appreciable torque reaction with this application of full throttle.
I dunno if this helps or not. But I plan to use EXACTLY the same motor/prop combo as you in the next iteration of my '27, and nothing I had read or experienced to THIS point was suggesting that I would be making a mistake.
I'm always ready to learn, though! If others think this really is a torque problem, I may need to rethink things.
Thomas Nelson is offline Find More Posts by Thomas Nelson
Discussion Is there such a thing as "too hot a motor?" Ebolavoodoo Power Systems 5 May 29, 2007 10:42 PM
Is there such thing as too cold? cincy Aerial Photography 2 Dec 11, 2003 12:15 PM
Is there such a thing as a too large esc? Rackey Beginner Training Area (Aircraft-Electric) 7 Mar 06, 2003 07:48 AM
Is there such a thing as ground effect ? dvint Modeling Science 3 Feb 06, 2003 09:32 AM
