Old Jun 27, 2008, 06:01 PM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
Build Log
2008 SSDC - Oblique Dynamic Soaring
Category: open/crunchy
Project Name: Oblique Dynamic Soaring
Build Thread: here
Design Goals:
To answer following questions about oblique flying wing (OFW)
- Can OFW soar on the slope without motor?
- Can OFW fly with 2~3 control surfaces?
- Does OFW preserve the benefits at subsonic speed?
- Is there any benefit for dynamic soaring with OFW?
Be the first ODSing flying wing ..... I hope
Geode is offline Find More Posts by Geode
Old Jun 27, 2008, 06:07 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Background Information
Oblique Wing (from Wikipedia, the free encyclopedia)
An Oblique wing is a variable geometry wing concept. On an aircraft so equipped, the wing is designed to rotate on center pivot, so that one tip is swept forward while the opposite tip is swept aft. By changing its sweep angle in this way, drag can be reduced at high speed (with the wing swept) without sacrificing low speed performance (with the wing perpendicular).
DARPA oblique flying wing ..... this is cool
DARPA Oblique Flying Wing (0 min 26 sec)
Old Jun 27, 2008, 07:16 PM
Cory is offline
Find More Posts by Cory
I DS slower than I build!
Cory's Avatar
Idaho Falls
Joined Jul 2006
Are you putting a SAS in that? (Stability Augmentation System) It'll sure be cool if you get it to work.
Cory is offline Find More Posts by Cory
Old Jun 27, 2008, 07:39 PM
yogiraw is offline
Find More Posts by yogiraw
It's the best day ever!
yogiraw's Avatar
Corte Madera (in Marin County, CA)
Really really really cool. Thoughts on control surfaces? If you had two "elevons" the more aft one would be an elevon/elevator and the one on the side that is more front (possibly even partly in front of the cg) would be just an aileron? Hmmmm. Maybe 3 control surfaces? Hmmm... Thin wing with fuse or thicker wing with no fuse?
yogiraw is offline Find More Posts by yogiraw
Old Jun 27, 2008, 08:36 PM
Alex May is offline
Find More Posts by Alex May
I'd Rather Fly
Alex May's Avatar
United States, CA, San Diego
Joined Feb 2008
The problem that NASA had with their oblique wing project is that when the wing is at high angles to the fuse, the ailerons begin to have a pitch effect as well as roll so it kind of mixes weirdly. It was because the ailerons suddenly became placed in between the pitch and the roll axes instead of being directly on the roll axis.
I'd like to see this working. Are you going to have it be variable geometry or fixed?
Alex May is offline Find More Posts by Alex May
Old Jun 28, 2008, 12:00 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Not really sure what to do on control surface at this moment (that's what I'm trying to find out through this build thread. Don't be surprised if I dropped out half way ). A few thoughts, basically follwiing Dr. Jones' prior work.
Oblique Flying Wing on CNN (2 min 56 sec)
I'll keep the control surface as flexible as possible on the prototype (could be 3~4 control surfaces) and count on my EVO Tx to trim it right. Once set, I hope I could reduce the number of servos.
I also plan to start with a few "fixed" flying modes (such as normal, 30 deg and 60 deg modes) with manual adjustment on vertical tail. Once set/trimmed for each fly mode, I plan to add one servo controling a full flying vertical tail and use "fly mode switch" to change oblique angles. No fuse planned at this momnent to make the building simple.
As for SAS, looks like I need to count on my two thumbs and EVO Tx .
Geode
Old Jun 28, 2008, 05:05 AM
admodesi is offline
Find More Posts by admodesi
Soap Box Junkie
admodesi's Avatar
Sydney, Australia
Joined Nov 2007
hmmm wont the ailerons work like an elevator? ooh its giving me a headache just thinking about it!
admodesi is offline Find More Posts by admodesi
Old Jun 28, 2008, 05:13 AM
mr_editor is offline
Find More Posts by mr_editor
Biting ankles since '53
No Pants Island
Joined Feb 2007
Why not try the AD-1? At least you've got a tail group.
NASA's Ames Dryden AD-1 Pivoting (Oblique) Wing plane (1 min 7 sec)
mr_editor is offline Find More Posts by mr_editor
Old Jun 28, 2008, 10:41 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
That's a good ideal. If ODS flying wing doesn't work, I'll just add a tail group and go ODS AD1 .
Here is a draft version of ODS flying wing at 45 degree oblique angle. Vertical tail is removable with plug-in CF tube/rod.
Now the question is .... should I turn left or turn right for ODS'ing (i.e., the vertical tail should be on the R- or L-hand side)?
Geode
Old Jun 28, 2008, 10:46 AM
No Pants Island
Joined Feb 2007
That does look sweet. Better get my SSDC design drafted.
Old Jun 28, 2008, 10:50 AM
No Pants Island
Joined Feb 2007
One additional question, forget the aileron/elevator problem, what happens to the CG when you shift the wing? Is the perceived chord longer so the CG position is less critical? And forward swept wings have structural twist issues, so what happens there? And what about washout.
i must go lie down. My head hurts.
Old Jun 28, 2008, 11:11 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
My head hurts too.
CG - Will do some free-flight model to check it out.
Washout - will do zero washout. But like to add some transitional airfoil for aerodynamic washout.
Wing twist - I do not have a fuse. Should not be as bad as conventional configuration. This is also part of the planform/airfoil optimization to minimize the twist.
BTW, I'm not sure if OFW is swept forward or backward .
Old Jun 28, 2008, 12:20 PM
Alex May is offline
I'd Rather Fly
Alex May's Avatar
Joined Feb 2008
I think that if you pivot the wing on it's CG then there should be no issues concerning the CG of the aircraft. However, I'm not sure where the wing would have to pivot - either on the CG or on the center of lift.
It's both!
Old Jun 28, 2008, 06:02 PM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
That looks more like a surfboard than a wing
ZIPPER is offline Find More Posts by ZIPPER
Old Jun 28, 2008, 07:32 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Good idea.
Here is where I fly. Once done with front side ODS'ing, just flip it and go surfing, I mean "OS'ing" .
Dynamic soaring with foamies Vector Foamies (Kits) 16 Mar 09, 2010 08:31 PM
Dynamic soaring FAD Dynamic Soaring 0 Oct 02, 2002 10:20 PM
Dynamic Soaring Ade Electric Plane Talk 0 Sep 03, 2002 01:45 PM
Dynamic soaring with foamies Vector Electric Sailplanes 1 Feb 02, 2002 01:08 PM
Dynamic Soaring!! fisher Electric Sailplanes 14 May 01, 2001 11:36 PM
