Old Jun 27, 2008, 11:16 AM
Dick Myers is offline
Find More Posts by Dick Myers
Joined Jun 2006
Wire Length to Motor vs ESC from battery
I have my HV ESC (Large 4-Motor Bomber) mounted at each nacell next to motor. I have the battery wire from each ESC running back to batteries to be located in main fusilage. The battery wires to ESC are quite long at about 3 ft. I read this am that I need to have the long wires (36" +/-) between motor and ESC and short wire (18" or less) between ESC and battery to avoid adding capacitors or something. I hate to rewire every thing but will do what is required. The batteries will not fit in the outer nacells but I have plenty of room for them in the fusilage and can provide good ventilation.
I am using the Turnigy "Sentilon 100A-HV ESC's with Astro 5020-30 motors
Need help -Thanks
Dick Myers is offline Find More Posts by Dick Myers
Old Jun 27, 2008, 12:47 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Info I found soemtime ago: http://www.schulze-elektronik-gmbh.com/tips_e.htm .
“Electronic speed controllers have been designed to operate correctly with a cable length between battery and controller at a maximum of 20 cm (7 inch) each lead.
In some installations it will be necessary to increase the length of the battery cables. In this case it is necessary to install additional low-ESR decoupling capacitors. The installation of these additional capacitors allows the increase to a total length of battery cables to as much as 30-50 cm (12-20 inches), depending on the motor load or 30 cm when using not inline (not end-to-end) soldered packs (12“ pos.+ 12“ neg. cable between "saddle-packs" and controller).
schulze Order Term: cap-330µ/50V (2 pieces - up to 32 Ni-Cd/Ni-MH cells / with mounting instruction).
schulze Order Term: cap-330µ/16V (2 pieces - up to 11 Ni-Cd/Ni-MH cells / with mounting instruction).”
jrb is offline Find More Posts by jrb
Old Jun 27, 2008, 04:30 PM
KenSt is offline
Find More Posts by KenSt
Scratch builder
USA, PA, Telford
Joined Apr 2004
http://www.rcgroups.com/forums/showthread.php?t=883753
KenSt is offline Find More Posts by KenSt
Old Jun 27, 2008, 08:28 PM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
This is what Patrick DelCastillo (founder, CEO and chief designer at Castle Creations) said about this: http://www.rcgroups.com/forums/showp...8&postcount=14
I was going to suggest you ask the ESC maker what the best course was until I saw that they're Hobby City ESCs. Not likely to get a lucid answer if you get one at all.
I have seen input capacitors explode with long battery leads. It's not pretty. I also know from sad experience that much of this Chinese stuff is overrated (ratings quoted, if trusted, lead to immediate failure under NORMAL conditions).
What is the claimed voltage rating of these controllers and what battery are you using? The safest course is probably to use auxiliary input capacitors as described by the quote from Matthias Schulze. Note that the voltage rating on those added capacitors must be quite a bit higher than your battery voltage. You see, what's going on here is that - on the battery side - the controller starts and stops the flow of current at whatever the switching rate of the controller is. Long leads form an inductor and this start/stop gives you voltage spikes. The longer the leads the higher the added voltage from that inductance. Think "water hammer" with electricity.
BEC is online now Find More Posts by BEC
Sold New Speed 550 Motor/Gearbox/ESC/Prop/Battery Cheap! Tommy D Aircraft - Electric - Power Systems (FS/W) 5 Sep 01, 2006 11:20 AM
For Sale HELI Brushless Motor/Brushless ESC/Lipo Battery rapscallion Aircraft - Electric - Helis (FS/W) 0 Jul 11, 2006 07:16 PM
For Sale Brushless Motor and ESC from ParkZone Typhoon GiddeeYupGuy Aircraft - Electric - Power Systems (FS/W) 6 Mar 13, 2006 02:25 PM
Anyone tried new motor and esc from Balsapr? brianb10 Power Systems 4 Dec 13, 2004 11:31 PM
Servos Motor/drives ESC's Battery Packs BIG-NANACAT Aircraft - Electric - Airplanes (FS/W) 10 Jan 10, 2004 12:00 AM
