Old Jan 26, 2003, 08:34 PM
latch66 is offline
Find More Posts by latch66
Oskaloosa, IA
Joined Apr 2002
If your gonna be dumb, you gotta be tough!
Sometimes I can be dumb, so thank goodness the Zagi is tough!
I've always heard about how tough a Zagi is, but have never really experienced it until today.
I have a brushless powered Zagi and I was putting it through its paces by doing low level passes.
My Zagi flys significantly different from the other aircraft I fly on a regular basis. My funfly airplanes are so tail-heavy, they require "up elevator" when they are in inverted flight to fly straight and level. My Zagi needs "down elevator" to be able to fly straight and level in inverted flight.
To make a long story short, I was trying low level inverted passes when I forgot what direction was up. The Zagi went in nose first at full throttle into the field. The battery (an 8 cell 1700mah HR4/5 Nimh) burried itself completely in the mud. The only thing visible on the battery was the plug sticking above the ground. The nose looked like I had split the foam cores all the way to the trailing edge. The wing covering was split in several areas. The tray and cover do not exist anymore.
I thought it was a gonner. After I got home I stripped the covering off and to my suprise, there is no damage to the cores. The wing is in great shape. A little wrinkled in a few areas. All I need to do is to recover and replace the tray. That's it!
I am truly amazed.
If anyone else has similar Zagi Survival stories please share them here.
latch66 is offline Find More Posts by latch66
Old Jan 27, 2003, 06:47 AM
Mats is offline
Find More Posts by Mats
Mats's Avatar
Trollhattan, Sweden.
Joined Oct 2002
I saw this quote somewhere on the web:
"When you're inverted, down is up and up is expensive.."
Mats is offline Find More Posts by Mats
Old Jan 27, 2003, 07:24 AM
latch66 is offline
Oskaloosa, IA
Joined Apr 2002
LOL!
You are right!
Fortunately this time, "up" will only cost me a tray, some covering, and a little time.
Even the battery pack survived.
The motor and ESC survived too!
I'll do a range check to make sure the receiver is OK, but it was still working at the field after the crash.
Alert You might be from the Pacific Northwest if you Don Sims Humor 22 Nov 08, 2014 02:26 PM
you might be a redneck if......... AirWarriorBelgy Humor 16 Feb 16, 2010 06:35 PM
If you are a modeler, Murphy will be with you.. anfarol Electric Plane Talk 1 Aug 21, 2002 03:37 PM
Discussion You might be a Cajun if.... Don Sims Humor 0 Mar 09, 2002 05:22 AM
You might be a red neck pilot if.... barn buster 50 Parkflyers 15 Feb 01, 2002 06:50 PM
