Helis are far too dangerous to be flown anywhere else than remote open fields. |
update about the crash damage, worse than what I first thought :
- 4 propellers - 1 dome - 1 CF arm - 1 esc (but got fixed, wire got pulled off from board) - at least 2 motors, probably three (they did not appreciate being slammed on the concrete from 20 feet high) Arghhhhhh, gotta make a new order in Hong-Kong and pay lots of shipping and taxes (but still cheaper than buying here in France) @Mikro : thanks for all the info ![]() - I will try to use servotimer2 and see what happens with crackling noises and speedups - I will try to put delay in the main loop if I ever find it, any clue to help me? - about weight, are you saying that lighter Quad are more prone to drifting and instability? |
![]() We are not making fun of your debugging abilities. It just makes helping you more involved and time consumming, with very little return for us sometimes, than there other wise would be. Just means we have to work with each other more without getting too frustrated too quickly. I suggest going with the OMM/Spectrolutions board, UAVP, or MicroKopter, or TT copter if you need a "ready to fly" quad right away. You might be able to use your quaduino sensors on the UAVP sensorless board? Hope you stick with this project as well but it does require us to be able to sit back and enjoy the long development cycle at times. Quote:
At least you have possibly discovered one issue with the code, since changing the values may have affected the full throttle issue. Were you able to write down all of the values you put into the quad for both of these flights so we can reproduce your results? Quote:
Some of the others have english manuals and plenty of english build threads with people nice enough to help anyone out but it seams like you always run into some german specific stuff if you really dig into the code. Quote:
---------------------------------------------------------- Quote:
![]() It would be cool to have a separate section in his repository for stable builds or a way for him to tag his builds as stable or works in progress if possible? Can't blame him really for the "testing before releasing code" thing much since it's not a full time project for him and he can only do so much testing himself. The testing phase is a great area we can all assist in.
Opps. Thought my last post was edited in this one instead of being in a new post
![]() I'll use this post to invite people over to the new (Quaduino-Part2) thread. Editing the first page to future links sounds like good "high level" work that I can handle It ain't ideal but I suggest this new forum be used for both continued AeroQuad tech support and general Quaduino talk. I'll do my best to keep it up to date to help separate the general talk from the tech support, fingers crossed Just keep the tech support condensed and to a minimum if possible. I suggest Mikros support forum be used if someone is really stuck and doesn't resolve there issues with in a few posts.
Personal tech support. That is seriously nice of you.Quote:
![]() It's working now. I just posted a link instead of copying the text. Quote:
If your getting the full throttle issue, your heavier quad may be dampening it, unless that's what you were talking about. I'll double check this but I recall my full throttle issues only happening for a brief second unlike others have reported but I need to double check that. |
Joined Jan 2009
Interrupt based ADC sampling.
As I am waiting for the PCB to be frabricated, I started to look at coding some of the important modules. Here is a intial code for interrupt based ADC sampling.
I just wrote the ISR and initialization function. Currently the loop() function is empty. I have not yet tested this code with any sensor data. I don't have sensors with me right now. I measured the timings and it takes about 256us if the system is running at 100Hz loop rate. Code:
//Program that using ADC autotrigger capability to continously sample all the 8 channels.
//The Arduino default ADC sampling rate is 9615.384 Hz
//When sampling 8 channels the net sampling rate for individual channel is 9615.384/12 = 1201.92 Hz
//With a 100Hz control loop rate each individual channel will be sampled 12 //times with in the time period of the loop. Hence we have 12 times //oversampling. Which increases the ADC bit resolution by 1 bit.
//These 12 values are accumalated and put into output array adc_sample[].
//The ISR does not divide the result by 12 and get average value. Using the //accumlated value we get advantage of increased ADC bit resolution.
//NOTE: the ADC results in the adc_sample[] will be 12 times larger than //normal Arduino analogRead() value.
int ledPin = 13; // select the pin for the LED
void analogAutoTriggerInit(uint8_t num_samples);
void setup() {
analogAutoTriggerInit(12);
void loop() {
delay(2);
//dummy loop doing nothing hear.
//Read data from the adc_sample[] array and use it in processing.
volatile uint16_t adc_acc[8];
volatile uint16_t adc_sample[8];
uint8_t adc_acc_cnt;
uint8_t adc_max_acc_cnt;
uint8_t adc_first_run;
extern uint8_t analog_reference;
//Main initialization program enables a2d conversions.
//disable it while setting up the Auto Trigger functionality
ADCSRA &= ~(_BV(ADEN));
//Set the reference voltage
//Set the mux for first channel.
//LSB 4 bits determine the channel, reset them for first channel
//variable analog_refernece is from Arduino code base.
ADMUX = (analog_reference << 6) | 0;
ADCSRA |= _BV(ADATE); //Enable Auto Trigger
ADCSRA |= _BV(ADIE); //Enable Interrupt
ADCSRA |= _BV(ADEN); //Enable ADC.
//initialize all the variables
adc_first_run = true;
adc_acc_cnt = 0;
adc_max_acc_cnt = num_samples;
for(uint8_t i = 0; i<8; i++)
adc_acc[i] = 0;
adc_sample[i] = 0;
sei(); /* enable interrupts */
* Start one conversion to set the ball rolling.
ADCSRA |= _BV(ADSC);
//Test stuff
pinMode(ledPin, OUTPUT);
* ADC conversion complete ISR.
ISR(ADC_vect)
static uint8_t ch = 0;
uint8_t low, high;
//to measure the execution time of ISR. Comment out for normal operation.
PORTB |= _BV(PIN5);
if(adc_first_run == true)
{//Entering the ISR for the very first time after reset or power up. This is special condition
//and needs different handling. Note that ADC has already started the conversion for channel 0 again.
adc_first_run = false;
++ch;
//select the next channel
ADMUX != (0x07 & ch);
//the next time ISR is triggered we would have result from channel 0 and conversion for channel 1 would
//have begun.
else
// we have to read ADCL first; doing so locks both ADCL
// and ADCH until ADCH is read. reading ADCL second would
// cause the results of each conversion to be discarded,
// as ADCL and ADCH would be locked when it completed.
low = ADCL;
high = ADCH;
//In normal operation if the ch == 2, currently ADC is sampling channel 2 and result from channel 1 is available
//read the ADC value and accumlate/average.
if(ch == 0)
{//special condition, when Ch == 0 the result present if from that of channel 7
adc_acc[7] += (high << 8) | low;
else
adc_acc[ch-1] += (high << 8) | low;
++ch;
if(ch == 8)
{//finished cycling through all the 8 channels
ch=0; //cycle back to first channel
//increment accumlator count
++adc_acc_cnt;
if(adc_acc_cnt == adc_max_acc_cnt)
{//Finished accumlating the samples, copy the value into output result array
adc_acc_cnt = 0;
adc_sample[i] = adc_acc[i];
adc_acc[i] = 0; //reset the accumlator register
PORTB &= (~_BV(PIN5));
Joined Jun 2008
Ok, I'm closing this thread down so that talks can move over to RCvertt's new Quaduino-Part 2 thread. I think he'll be better able to keep the first post up to date than I've done.
Great thread guys! Thanks to everyone who has contributed here! Sometime in the next month or so I should have some info on my own project. It'll feature very low cost sensors, the Tx/Rx entirely replaced by data modems, and some funky matrix math for getting a better orientation out of the gyros and accels. Stay tuned! |
| Thread Tools | |
| Build Log New Project - YF-23 | GlasairAllen | Electric Ducted Fan Jet Talk | 525 | Dec 13, 2008 10:59 AM |
| New project | DBlum | Parkflyers | 42 | Feb 27, 2004 11:43 PM |
| Idea blue foam new project | reznikvova | Parkflyers | 4 | Jan 23, 2002 07:34 PM |
| new project from foam please look | reznikvova | Foamies (Kits) | 3 | Dec 21, 2001 05:29 PM |
| New Project Flys! | Dr. Jet | Sport Planes | 9 | Sep 20, 2001 06:09 PM |
