Old Dec 30, 2008, 01:40 AM
KiwiKid is online now
Find More Posts by KiwiKid
RCGroups - my happy place
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
Just noticed this vid posted on YouTube recently. Looks like a Marston
Pterodactyl RC (1 min 35 sec)
KiwiKid is online now Find More Posts by KiwiKid
Old Jan 08, 2009, 03:50 AM
EeleyEagle is offline
Find More Posts by EeleyEagle
SINK HAPPENS !!!!
EeleyEagle's Avatar
Coffs Harbour NSW Australia
Joined May 2006
Hey that looks good in the air. It goes a fair bit quicker than I expected.
EeleyEagle is offline Find More Posts by EeleyEagle
Old Jan 10, 2009, 10:02 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
That's the 80" version, that clip is somewhere on the Marston site I think. It is zippy, looks like it flies like a hotliner
Tres Wright is offline Find More Posts by Tres Wright
Old Jan 11, 2009, 07:28 PM
KiwiKid's Avatar
Joined Jun 2005
Possibly not. The YouTube blurb on 20 Dec said it was the maiden flight of a 54" (meaning 52") ptero.
Old Jan 17, 2009, 11:31 AM
Forney, TX
Joined Mar 2002
Sorry, my mistake. That looks exactly like the clip I saw on the web site a while back of the bigger version, I guess it's a chip off the ol' block in the way it flies
Old Jan 18, 2009, 02:53 AM
SINK HAPPENS !!!!
EeleyEagle's Avatar
Joined May 2006
Getting closer
Progress report. Just need to do a bit more sanding then its ready to cover.
Old Jan 18, 2009, 09:27 AM
Skyshark is offline
Find More Posts by Skyshark
South of Boston, Ma.
Joined Mar 2004
Looking Good EeleyEagle!!
I am having a tough time with mine. I keep pushing back behind other builds because the instructions are so bad and the parts, though numbered themselves, there are no numbers in the plans or drawings. I have the wing about half built and just got the motors and ESC's. Can someone be so kind as to post pictures of the bottom side of the wing and a head on shot so I can see the relationship of the head and breast?
Skyshark is offline Find More Posts by Skyshark
Old Jan 18, 2009, 02:13 PM
JimTMich is online now
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Looking great! You have some BIG motors in there!
JimTMich is online now Find More Posts by JimTMich
Old Jan 19, 2009, 02:55 AM
SINK HAPPENS !!!!
EeleyEagle's Avatar
Joined May 2006
Photos for you.
Hey Skyshark, Took some photos for. Hope they help. I can get some more if you need specific help areas. You may have noticed that I decided to close in the head and neck areas to make the covering job a lot easier. I am unsure how the speedies will go in the centre wing section but there is no where else they will fit. If I can't get enough airflow over them and out ,I may have to leave a hole in the top of the body open. Suck it and see I guess when the time comes.
JimTmich, Believe it or not they are equivelant size motors as the specs say but around 1/2 the price. They are E-Watts. Have a 3S2200mAh lipo for its belly.
Old Jan 19, 2009, 04:39 AM
SINK HAPPENS !!!!
EeleyEagle's Avatar
Joined May 2006
Hey SkyShark.
I just discovered that there is a revised construction manual done in DEC 08 for the Ptero on Rons website. I sugguest you download it and have a look at some of the better, latest photos and he does explain a few things a bit better.
Andrew
Old Jan 19, 2009, 07:12 AM
Skyshark is offline
Joined Mar 2004
Thanks Andrew
Those picture help alot. I will head out to the website and check it out.
Thanks again!
Jim
Old Jan 27, 2009, 03:13 AM
bobhowson is offline
Find More Posts by bobhowson
Coffs Harbour
Joined Jan 2009
Hi Andrew,
I decided to join the forum looks really cool.
Looks like your doing a great job on the bird.
Catch ya soon,
Bob
bobhowson is offline Find More Posts by bobhowson
Old Mar 29, 2009, 04:34 AM
SINK HAPPENS !!!!
EeleyEagle's Avatar
Joined May 2006
Update
I am slow I know that. I now have the body/ tail feathers and ailerons covered. Just leaves the wing. Hopefully I can get some help with the wing covering as I decided to use Pro Film and it might not be as pliable as it needs to be. Time will tell. It is translucent green to keep with the prehistoric theme.
Can't rush these things.
Andrew
Old Mar 30, 2009, 05:22 AM
TugBoat is offline
Find More Posts by TugBoat
NSW, Australia
Joined Jun 2003
Profilm will be fine...
I have not covered a 52", but for the 80" I did the bottom of the wing first (easier and more 'flat'). I did not fully tighten the covering, just attached the leading/trailing edges and shrunk it slightly.
I think that this is important because the film sticks really well to itself and this makes getting the top of the wing film in place easier - because you can bond it to the bottom film.
Then I did the top. Now the top is certainly more difficult, and the most difficult area (at least on the 80" one) is the inboard section next to the body - this has the most 'concave' shape - it is concave on both axis.
With the first wing I just couldn't get the film to work, and I cheated slightly with some cuts and patches. But when I got to the second wing I found that I had mastered the technique. (Or perhaps I just got lucky... )
I think that the important part is to trim the film on the leading edge to have the same concave shape (when viewed from the top) as the wing. This makes it much easier to pull the film down.
You are normally told to leave a lot of excess material on the film - but my experience was that this did not make it easier! So I tacked the trailing edge down and then trimmed the leading edge about 20mm larger than the wing. I did this while pressing the film down to the shape of the wing.
Then it was much easier to work the film down and bond it. As I said on the 2nd wing it was quite easy.
Once it is all tacked down I then used a heat-gun to shrink the whole lot evenly so as not to distort the wing shape.
As they say: it is the journey that is important, not the destination...
Tim
TugBoat is offline Find More Posts by TugBoat
Old Mar 30, 2009, 09:39 AM
Skyshark is offline
Joined Mar 2004
I did a "Bonehead" move a couple of weeks ago. I glued the top and bottom leading edge parts on. Now I find out I was supposed to install the aileron servos before gluing the bottoms on. Time to put it down for a while. I will have to cut access doors for the servos and come up with some way to route the servo wires.
