Old Nov 22, 2010, 11:55 AM
Salty79 is offline
Find More Posts by Salty79
Salty79's Avatar
United States, AR, Benton
Joined Jul 2009
Sorry about all the questions but, how did you hinge the ailerons? It looks like there is not enough balsa on the wing to use CA hinges. Also I'm still looking for the size of push rods everyone is using.
Salty
Salty79 is offline Find More Posts by Salty79
Old Dec 03, 2010, 05:47 AM
EeleyEagle is offline
Find More Posts by EeleyEagle
SINK HAPPENS !!!!
EeleyEagle's Avatar
Coffs Harbour NSW Australia
Joined May 2006
Aileron Hinging
I actually left my Pro film coverirng on each of the ailerons about 3/8" longer on the top front edge and then Ironed it onto the TE as the hinge ( if that all makes sense).Works well. I used standard CA hinges for the elevators.
Andrew
EeleyEagle is offline Find More Posts by EeleyEagle
Old Dec 04, 2010, 10:56 AM
JimTMich is online now
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Salty, I used tape instead of CA hinges.
Aileron pushrods I used .047" music wire. It seems to be adequate.
For the tail I used the Dubro parkflyer pushrods which consist of .030 music wire inside guide tubes. This is pretty marginal, but it works. If you could find something more like .047 with guide tubes for the tail, that would be my suggestion.
Jim
JimTMich is online now Find More Posts by JimTMich
Old Dec 08, 2010, 11:50 AM
Salty79 is offline
Salty79's Avatar
Joined Jul 2009
I already bought a .032 gold-n-cable. Is there anyway to make it work or do I need to try to exchange it?
Salty
Old Dec 08, 2010, 08:14 PM
God is my pilot
JimTMich's Avatar
Joined Aug 2006
if it's in a tube then it should be fine. the tube will keep it from flexing.
Old Jan 29, 2011, 11:56 PM
RCPtero is offline
Find More Posts by RCPtero
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Well, I'm finally getting around to working on mine again. Covered the top of the wing tonight. Very happy with the color. Although those compound curves are a bear to cover. The bottom is going to be transparent gold, and I think the head might be red like a vulture's.
Tom
RCPtero is offline Find More Posts by RCPtero
Old Jan 31, 2011, 01:32 PM
dswitkin is offline
Find More Posts by dswitkin
dswitkin's Avatar
United States, CA, SF
Joined Sep 2007
Nice Tessex. I haven't seen one with gold before. Keep those photos coming.
dswitkin is offline Find More Posts by dswitkin
Old Feb 13, 2011, 01:14 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Control surfaces are mounted. Now I just need to hook up the ailerons, install the tail surface controls, receiver, battery, and props. Then adjust the throws and set center of gravity and she'll be ready for maiden.
Old Feb 13, 2011, 08:05 PM
Skyshark is offline
Find More Posts by Skyshark
South of Boston, Ma.
Joined Mar 2004
You forgot the horns...
Skyshark is offline Find More Posts by Skyshark
Old Feb 13, 2011, 08:07 PM
God is my pilot
JimTMich's Avatar
Joined Aug 2006
You're in the home stretch. I like the green.
Old Feb 13, 2011, 09:18 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Yeah, I realized that after I posted the photo. Those are going on. I figure they'll be opaque gold. (The underside is transparent gold with red trim around the wing. I'll get a shot of it up in a few days.
Tom
Old Feb 13, 2011, 09:20 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Yeah, I like the green too. Although I should have run the covering as a single piece from wingtip to wingtip. As it is, I have a dark green line down the center where the two pieces overlap. Oh well, something to remember when I build her big sister, the 80" one.
Tom
Old Feb 14, 2011, 07:42 AM
God is my pilot
JimTMich's Avatar
Joined Aug 2006
Tom
Yes, that's the tricky part of translucent covering. I cannot seem to avoid them.
Old Feb 14, 2011, 10:58 AM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Thought about making irregular sploches to make it look more like cammoflauge. It would seem a natural effect to me. Kind of like a leopard's spots only I wouldn't make them so small.
Tom
Old Feb 14, 2011, 12:00 PM
Skyshark is offline
Joined Mar 2004
I did mine in a lighter shade of translucent green and was going to add purple dots as a sort of color scheme but the wife nixed it. She said it looks better in the plain green.
