Old Aug 19, 2010, 10:39 PM
RCPtero is offline
Find More Posts by RCPtero
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Well, she's starting to look like a bird!
RCPtero is offline Find More Posts by RCPtero
Old Aug 20, 2010, 01:56 PM
JimTMich is offline
Find More Posts by JimTMich
God is my pilot
JimTMich's Avatar
United States, MI, Kalamazoo Township
Joined Aug 2006
Looking good!
JimTMich is offline Find More Posts by JimTMich
Old Aug 29, 2010, 07:40 PM
dswitkin is offline
Find More Posts by dswitkin
dswitkin's Avatar
United States, CA, SF
Joined Sep 2007
Cool, keep the photos coming!
dswitkin is offline Find More Posts by dswitkin
Old Oct 06, 2010, 02:06 PM
Salty79 is offline
Find More Posts by Salty79
Salty79's Avatar
United States, AR, Benton
Joined Jul 2009
Got one!
I started the 52" version last night. I started with the head and neck while I wait on my out-runners to arrive. Are there any tips, tricks, or mods that I should know about ahead of time?
Salty
Salty79 is offline Find More Posts by Salty79
Old Oct 11, 2010, 03:15 AM
EeleyEagle is offline
Find More Posts by EeleyEagle
SINK HAPPENS !!!!
EeleyEagle's Avatar
Coffs Harbour NSW Australia
Joined May 2006
Don't rush the build. Make sure you understand the instructions and make sure you have the latest instructions as improvements are always being made. This model will reward you for your efforts. I used Profilm for covering because of the compound curves and it paid off.
Andrew
EeleyEagle is offline Find More Posts by EeleyEagle
Old Oct 11, 2010, 10:41 AM
JimTMich is offline
God is my pilot
JimTMich's Avatar
Joined Aug 2006
Yes, take it slow as some of the sheeting will look better if you sand it to fit. It's a fun model to build and fly. It's a very unique model so it draws a lot of interest at the field. Go with higher kv motors as suggested by Petroworks, this plane really is fun to fly fast, I wish I had put in the 1400kv motors instead of the 1000kv.
Old Oct 13, 2010, 06:18 PM
Salty79 is offline
Salty79's Avatar
Joined Jul 2009
I have already bought the motors. I've got two Turnigy 2826 1900kv http://www.hobbyking.com/hobbyking/s...idProduct=2110
It looks like they are similar to the AXI 2208. I'm almost done with the head and neck. I always save the wings for last. How many of you put the 2 oz of lead in the nose like the plans call for? It just seems like a lot of lead!
Salty
Old Oct 14, 2010, 06:38 PM
JimTMich is offline
God is my pilot
JimTMich's Avatar
Joined Aug 2006
I put a lot of lead in the nose to get the CG right. I left one piece of the head open until the model was completely built and covered, then ballanced with lead, and glued the last of the head and added the last piece of covering. It's necessary, don't fret too much about it, it was necessary to make the proportions right.
Old Oct 14, 2010, 06:40 PM
JimTMich is offline
God is my pilot
JimTMich's Avatar
Joined Aug 2006
Those motors should be great.
Old Oct 14, 2010, 07:12 PM
TugBoat is offline
Find More Posts by TugBoat
NSW, Australia
Joined Jun 2003
Based on my experience (admittedly with the larger version) you don't want to be short on lead in the nose. You definitely do not want a too rear CG. Been there, done that - not an enjoyable experience...
So don't be tempted to move the CG rear of the recommended position to save a bit of weight - at least until after you have actually flown your creation.
Tim
TugBoat is offline Find More Posts by TugBoat
Old Oct 17, 2010, 05:43 AM
SINK HAPPENS !!!!
EeleyEagle's Avatar
Joined May 2006
I agree with all of the above. Put all the necessary lead you need in the head and it will pay off.Being short coupled you can't afford to get the C of G wrong.
Andrew
Old Nov 16, 2010, 04:01 PM
Salty79 is offline
Salty79's Avatar
Joined Jul 2009
I'm at the part of the build where I need to mount the motors. I was wondering how others did it. Did you use nylon screws? Also for the push rods, what brand and size did you use? Thanks for the help
Salty
Old Nov 16, 2010, 04:20 PM
JimTMich is offline
God is my pilot
JimTMich's Avatar
Joined Aug 2006
I used some regular screws that were of the proper lenght to get through the plywood. I did not use the x plate that came with the motor. I think motor mounting is open to creativity depending on what motors you use.
Pushrods, I used some dubro parkflyer pushrods that come with tubes. That keeps the pushrods from flexing. On the ailerons I simply used piano wire from the hardware store.
Old Nov 17, 2010, 09:40 AM
Salty79 is offline
Salty79's Avatar
Joined Jul 2009
Can you get to the screws in the back of the motor now that it's built and finished?
Salty
Old Nov 17, 2010, 11:35 AM
JimTMich is offline
God is my pilot
JimTMich's Avatar
Joined Aug 2006
No, the way I built it, the motors are there for the durration of the model. As I recall, there wasn't enough room to use the x-mounts with the 28mm motors I bought. x-mounts would have allowed front access.
