Old Jun 25, 2008, 12:34 PM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Build Log
Salvaging a Lindberg Diesel Tug
Part I (the long-winded back story)
The Lindberg Diesel tug was my "Springer Class". It was a quick, cheap and and easy build to introduce me to R/C boating. I built this boat around 1998(?) with a hacked servo mod and a cheap motor stuck to the hull with fabric hockey tape.
Anyone who's built one knows that the parts don't fit together terribly well,
and if you use the molded in guides to assemble the upper works, the wheelhouse winds up looking like it has a bad overbite. The boat was slapped together with no attention to detailing, a crappy brush paint job, and I even managed to install the lightboards wrong.
Having said that, it was a riot to sail. We would shoot rapids, run it on an open lake in chop, and drop it anywhere could find water. Without fail, every boating session would end when the little tug sank, stern first.
Eventually, I got a Victoria sailboat, and scratchbuilt a pair of boats for my boys. The tug was pillaged for its radio, the servo driver "esc" got clipped for its leads, and the tugboat suffered many other indignities as it languished in the basement.
No matter how pathetic it looked, I couldn't bring myself to throw it out. I tripped over it again the other day, and starting wistfully looking at it... Hmmm...
I think folks, the time has come to resurrect my Lindberg tug!
PS: You can still pick these up for around thirty bucks, if you look around.
RGinCanada is offline Find More Posts by RGinCanada
Old Jun 25, 2008, 01:19 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Hockey tape! Only in Canada!
This should be a fun thread! Sounds like a lot of great times with that little boat!
Aerominded is offline Find More Posts by Aerominded
Old Jun 25, 2008, 02:07 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
RG, the crappy paint will come right off without damaging the plastic if you use brake fluid.
(old IPMS trick)
If your glue job was as bad as the paint, the parts should pry apart fairly easily---.
Hockey tape, Eh?
der kapitan is offline Find More Posts by der kapitan
Old Jun 25, 2008, 02:44 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Part II (the plan)
I need to set expectations here. This boat is never going to be transformed into a work of art to be proudly displayed on the mantel. I am shooting for "mediocre but reliable" ( Aim high! ). My work time will be divided between this and the sardine carrier.
On the mediocre side:
No added rivets. No working lights. No detailed cabin. No clever scratch-built scale pieces. No million hour paint job.
On the reliable side:
No leaks, a new hacked servo esc (for old-times sake), a no-nonsense paint job, and a better assembly job.
Aero and kapitan:
The hockey tape actually worked surprisingly well . The current paint job is a tasty blend of Testor's enamels and various acrylics. I don't think anything safely removes enamel from styrene but sandpaper. I've used brake fluid with ABS, it is safe with styrene too? Photos of the ugly beast to follow.
Old Jun 25, 2008, 03:19 PM
seaphoto is offline
Find More Posts by seaphoto
Kurt Greiner
seaphoto's Avatar
USA, CA, Grass Valley
Joined Sep 2005
By the way, anyone who builds a Lindberg tug, and would like way better performance should consider purchasing one of Microglass' replacement hulls. The water flow to the propeller and the slight increase in draft gives you a much better running model. I have one of those hulls for my future YTB project.
http://www.microglass.net/
Kurt
seaphoto is offline Find More Posts by seaphoto
Old Jun 25, 2008, 03:30 PM
CaptLee is offline
Find More Posts by CaptLee
United States, CA, Hayward
Joined Feb 2006
Try using a med torque servo for power plant 60-80 in-lb with a nimh AA 1700 4 pack and it will do nicely. Mine is in for a conversion to Kap's fiberglass hull, may have to go to sub-C's to ballast out correctly.
CaptLee is offline Find More Posts by CaptLee
Old Jun 25, 2008, 03:35 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
But Kurt, that's cheating
The hull for the Lindberg tug is the Generic Tug Hull No.13. If I were to go that, route, I'd probably scratch build the whole thing, thought, because the Lindberg quality is pretty dodgy. Why ruin a beautiful glass hull with an ill-fitting deck and wheelhouse?
Old Jun 25, 2008, 04:04 PM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Say RG; You know a guy in Guelph named Harold Hoffman? Owns a body shop? Pete
norgale is offline Find More Posts by norgale
Old Jun 25, 2008, 04:55 PM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Not personally, but dollars to donuts if I mention his name, someone will. Guelph is pretty small
Old Jun 25, 2008, 05:15 PM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Harold is my neighbor in the winter. I think he does something with Mustang cars like restoring them or something. Really nice guy and a good friend. Say hi if you come across him. get him to build a boat. Pete
Old Jun 25, 2008, 09:02 PM
Joined Feb 2004
[B]The hockey tape actually worked surprisingly well
Hee hee, I'm sure it does! Just giving you a hard time, re: hockey!
Old Jun 25, 2008, 10:50 PM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
I have always liked the lines of the Pyro/Lindberg diesel tug. I have a kit that hasn't been started; sounds like the Microglass hull would be the way to go with it, especially if it gives you a little bit more freeboard aft.
Alternatively, a somewhat larger hull would be even better. The plastic model of the "Cheryl Ann" of TV fame many years ago made into an appealing tug model that was a more practical r/c size. Every once in a great while, one shows up on eBay and goes for a healthy price, regardless of condition or completeness.
jeepers1940 is offline Find More Posts by jeepers1940
Old Jun 25, 2008, 11:04 PM
P_J_Glor is offline
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
The Pyro/Lindberg tug is the same configuration as the Model Shipways static model of the Despatch No. 9. You can find pictures here: http://tinyurl.com/59asdr and download the manual from the lower right side of the web page for some hints on constructing detail items.
Pete G.
P_J_Glor is offline Find More Posts by P_J_Glor
Old Jun 26, 2008, 12:04 AM
rlboats2003 is offline
Find More Posts by rlboats2003
rlboats2003's Avatar
United States, NY, Buffalo
Joined Oct 2003
Jeepers1940
The CA was a popular late 1950's tug boat- that commends a higher price - If you don't want to pay the high Price consider this the Fineline Herclues from the mid -1960's It on commands about 1/3 the cost of a Cheyrl Ann.
The other thing you may want to consider is Hartman Model Boats Little Toot. This is a gel-coated fiberglass hull similiar to the Cheyrl Ann The Plans package contains a long and short cabin version.
Hope this helps,
Rich
rlboats2003 is offline Find More Posts by rlboats2003
Old Jun 26, 2008, 04:39 AM
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
Oh, she's an ugly litttle beastie, and has taken much abuse!
I'm pretty sure the reason she kept sinking on me was because of the large opening around the rudder works. I had tried to seal this off, but the bulwark piece fits poorly and there is a gap right at the stern where the deck piece is notched for the rudder arm.
I'm convinced that if I can seal this up, the boat will stay afloat, and the low freeboard is no longer a worry.
I started by filling that gap with styrene.
The bulwark is a single piece that is about 1/8" to 3/16" too long for the model. (mine anyway) and when you glue it down there is a gap at the bow, or the stern, and it doesn't conform to the hull. I pulled out my trusty razor saw and chopped it in half.
Help! Lindberg 1/82 scale model Diesel Tug sivadmatt Dock Talk 32 Mar 17, 2014 06:39 PM
