Adam |
Paine Field
Joined Apr 2004
Yeah, why the chicken would I be a Cantelope head and apply 10 stinking coats of hard to rub on and buff off wax when my 2 year old daughter can do the entire job with little supervision in less than 3!
What you don't understand, since you have never done this before, is that your mold will get "seasoned" and actually feel different to touch after a certain amount of use. It will feel slippery er , whatever that means. And then, you don't need to take all the precautions you took at first, however you define them. On my next mold, I am really going to cut back on the waxing of the plug and mold, probably let my neighbors 2 year old boy do it, he has lots of energy, which I am absolutely convinced translates in a linear relationship to a job well done. Actually, I spray on some thinned PVA,(with alcohol, not rubbing) in three coats, and have never ever broken the PVA layer, which is why you wax in the first place, in case you nick the PVA somehow. So maybe no more than 5 coats of wax for me, but I have very close control of what I am doing, no cats, wives or kids in the shop, and I am very meticulas by nature. You will need to find out what works for yourself. |
It depends on the mold surface. If you have alot of tiny holes, it will take more wax to build-up the holes even with the mold surface.
If the mold has a perfect finish, one coat of wax will suffice. For the record, using Mother's California Gold, I don't let it dry before buffing. Use the same cloth to buff every time. Sean |
Paine Field
Joined Apr 2004
Another thing you might be missing is that the surface of the mold depends on the surface of the plug you made the mold from.
And you could have pinholes in your mold from airbubbles in the material you build the mold from. Now we are getting into specefic procedures of how you are building building your mold, and anything I might suggest will conflict with what other people think is "best". Depending on how good you want your finished parts to be, you might want to find someone (a Master) to mentor you. You can't just come on to these forums and ask 100 people for their best advice, as they all "know what is best". You need to adapt someones process, at least until you figure out what is going on. Or, you can develop your own process, a real pain in the Avacodo. But there are a couple of thousand people who have perfected a process to get results that stand above the rest. If you are lucky, one of them is in your club, if not, this is a really good place to find that person. Good luck! |
| Thread Tools | |
| Using an on/off motor control for AP switch? | Newberry | Aerial Photography | 4 | Sep 07, 2003 07:08 AM |
| anyone using TP8200 on Logo 10 ??? | jdowdle | Batteries and Chargers | 2 | Aug 17, 2003 09:21 PM |
| Major glitching problem with my MiniMax using qualcomms on first flight! | compuatic | Parkflyers | 3 | Jul 03, 2002 08:59 AM |
| Using "on/off" timer for maintainace charging | RickTatem | Power Systems | 3 | Feb 08, 2002 11:37 AM |
