Clear Coating Mahogany Hulls With Spar Varnish
Where it all started
After years of fooling around trying to find the best alternatives to finished fiberglassed mahogany hulls I think I've stumbled onto something. The material is not new - and I think that's good, because the worst luck I've had in finishing mahogany hulls is with "new" products. After working with everything from epoxy resin to water base polyurenthatne varnishes to automotive clear coats, both catalysed and not, the results have ranged from pretty good, but very time consuming (epoxy resin) to downright terrible. Without going into great detail, I'll never use water base PU again --the results were disastrous to the point of downright embarrasing! -- and depending on the resin, the automotive clear coats have ranged from OK to disastrous as well in that the finish blushed to a hazy gray over time. Back to Basics So this time I thought I'd have a go at the old tried and true oil base spar varnish. Then to keep the sanding and polishing time to a minimum, as with the thinned epoxy resin method I figured spraying it would be the way to go. And by spraying 2 relatively light coats, the shrinkage won't be as difficult to deal with in sanding the surface between coats. The Next Step Now that the first coat is applied, I'll let it cure for two or 3 days and wet sand with 600 grit sand paper to smooth out the little flaws, then a second coat will be applied as described in the photos. From there, it will be down to polish. So stay tuned, I'll post up the final results when she's done. PAT
| Thread Tools | |
| Fiberglass For Mahogany Hulls -- How To | P. Tritle | Scale Boats | 67 | Feb 28, 2012 09:44 AM |
| Discussion How to replace propellor and center fixing with spar. | 7rider | Beginner Training Area (Aircraft-Electric) | 1 | Jan 07, 2008 03:17 PM |
| Discussion Clear coating Tamiya paint | Brian Koester | Slope | 8 | May 24, 2007 09:45 PM |
| Discussion Coating ball links with CA to reduce slop, Long therm effects? | tribologist | Micro Helis | 17 | Nov 23, 2006 12:02 AM |
| Coating circuit boards with wax | ry_goody | Racing Boats - Electric | 8 | Jul 02, 2002 07:16 AM |
