Old Jun 23, 2008, 09:47 PM
AlignTrex is offline
Find More Posts by AlignTrex
Joined Jun 2008
Tail Servos and Normal Servos
hi guys. Is the tail servo different from the other 3 servos that you use to control the main rotors? and the helicopter specialist from Hobby People recommended this instead of buying the gyro and the 4 servos separately. He told me this has all 4 servos and the nice gyro. does this thing really come with all 4 servos? and is the tail servo included? thanks here is the link.
http://www.hobbypeople.net/gallery/715246.asp
AlignTrex is offline Find More Posts by AlignTrex
Old Jun 23, 2008, 09:53 PM
P-38J-Lightning is offline
Find More Posts by P-38J-Lightning
Team Me!
P-38J-Lightning's Avatar
AB, Canada
Joined Mar 2005
No that does NOT come with 4 servos, it comes with a Gyro, Amp and Tail servo.
Just everything you need to set-up your tail, and it works great! (Got one on my raptor).
Joel
P-38J-Lightning is offline Find More Posts by P-38J-Lightning
Old Jun 23, 2008, 09:55 PM
Joined Jun 2008
really? Where did you buy it? cause the guy said it comes with all 4 servos and the gyro so its a perfect set.
Old Jun 23, 2008, 10:10 PM
Team Me!
AB, Canada
Joined Mar 2005
It really doesnt
It is a Futaba GY611/9256, which is a Gyro/Tail Servo and that is the standard street price. I got mine at readyheli.com when it was on sale a while back for about $300.
The Hobby-People guy is wrong.
BTW, yes a tail servo generally is different, it usually has much less torque and a much higher speed than the main servos (9256 is a tail servo that is 0.06s/60 Degrees with 47 ounces of torque while my cyclic servos (9252) are 0.14s/60 Degrees with 91.6 ounces of torque.
Joel
Old Jun 23, 2008, 10:30 PM
Serg is offline
Find More Posts by Serg
Serg
Rostov-on-Don, Russia
Joined Apr 2005
It appears that there is some confusion here. The link in the original message points to a page describing a combo of the Futaba GY611 and the S9256 servo and there is no reference to the rotor servos.
The tail servo should be fast. Speed requirements for 3 CCPM servos are lower but generally they should have more torque. For example, a quite popular setup is 3 Futaba S9252 servos (.14 sec/60) for the rotor and Futaba S9254 (.06 sec/60) for the tail.
Manufacturers often offer matched pairs of gyros and tail servos that are known to work well. A page referenced by the link is an example.
Obviously, you can use the same servos for the rotor as the tail one (if it is both fast and strong enough) but unless you are Alan Szabo , this would probably be just a waste of money (compare the prices of S9252 and S9254) because you will not see the difference anyway.
So, if you are buying the whole setup, you will need either a gyro/tail servo combo or you can buy gyro and fast tail servo separately, and 3 identical servos (a bit slower but stronger) for the rotor.
Sergey
Serg is offline Find More Posts by Serg
Old Jun 23, 2008, 11:50 PM
Joined Jun 2008
looks like i am going to have to call up the shop again! thanks for the info tho!!
Old Jun 24, 2008, 03:13 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
There is more to it than transit speed. Futaba gyros and matched tail servos have a higher frame rate - that is they update the position of the servo more frequently. Regular servos operate at 50frame/s. Futaba gyros/tail servos operate at 270frame/s (IIRC). If you use a conventional analog servo or a basic digital servo with a gyro (in digital mode) it will burn out due to the high frame rate.
All the popular leading gyros have high frame rates in digital mode and require a digital tail servo *rated for high frame rates*. Most servos sold specifically as tail servos are digital and will work at the high frame rates generated by modern gyros.
kgfly is offline Find More Posts by kgfly
Old Jun 24, 2008, 12:49 PM
Joined Jun 2008
alright so guys, what servos should i get for a Trex 600E? cause the guy at hobby people said that the normal servos should be around 13-16 dollars, or a bit more. but I should put my money on the gyro and tail servo. So i can either buy the Futaba 611 gyro+ tail servo (S9256) for $370, or I can buy 3 Futaba S9254 servos for the main rotors, and a Futaba S9254 for the tail. if i do that what gyro should I get? I want a pretty decent gyro. thanks!!
Old Jun 25, 2008, 10:00 AM
Team Me!
AB, Canada
Joined Mar 2005
"Standard" servos have low resolution and are going to just suck in your heli. Look into high end digitals. I personally use 9252's.
Joel
Old Jun 25, 2008, 02:09 PM
Greybird is offline
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
Have you priced out a complete set-up?
Greybird is offline Find More Posts by Greybird
Question Can i stop my normal servos from drifting in IC plane treehog Radios 7 Feb 24, 2008 08:09 PM
Filip 600 V-tail servos in tail? Up&Away Electric Sailplanes 4 Aug 13, 2004 02:39 PM
Slow-Stick and normal servos Sloop Beginner Training Area (Aircraft-Electric) 18 Apr 08, 2004 11:42 AM
V tail HLG servos Dandi6065 Hand Launch 1 Mar 21, 2002 08:15 PM
Mounting servos in Filip T-tail rtideas Electric Sailplanes 6 Jun 26, 2001 07:13 PM
