Old Jun 23, 2008, 08:20 AM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
Build Log
Tiny3D, EPP/FFF, 3:1 Thrust/Weight, Flight Sim, Video, !NEW! V03, 24 in, 1.5 sq ft
Dynomike,
Hope my feeble rendering does your model justice.
Thanks for sharing
Gramps
“have you seen this video?” WOW!
http://www.rcgroups.com/forums/showt...hlight=tiny+3d
This video was shot and edited by my buddy Doug Leighton, from the first day flying a new mini 3D plane at a local gym last Sunday. It's loosely based on a Slofly Micro 3D, but the wingspan is scaled down to 18 inches, and fuse profile plus tail shapes have been modified and scaled down too.
Running gear includes:
E-flite Park 250 outrunner
GWS 7035 prop (2S) and 6030 (3S)
PolyRC 20C 300-2S or 300-3S
Castle Phoenix 10 ESC
Spektrum 6100 Rx
BlueBird 3.6g servos (3 ea)
AUW is 3.53 oz with 2S and 3.8 oz with 3S. Most of the vid is shot flying 3S, with over 12 oz thrust to pull the 3.8 plane around (300 watts/lb!).
It's an absolute hoot to fly, especially the WOT snap rolls and loops!
Mike H.
Cincy OH
Dynomike’s
Tiny 3D
3:1 thrust ratio
Shamelessly rendered
By gramps
PDF prints four 8.5X11 tiles with small no-ink margin
Do not trim off margin, just place side by side and tape.
Edit . . . 30july
!W W!
Tiny 3D RealFlight G3(G4) simulator
Check out post 94
Thanks smwpuck19
Tiny3D-02 (below) with
Longer nose moment
Aileron counter balance
Leading edge sweep
edit 16Sep08
Tiny3D-03
24 inch span / 1.5 sq ft
plans at post 163
chaosMurphy is offline Find More Posts by chaosMurphy
Old Jun 23, 2008, 08:39 AM
Joined Dec 2006
Image 1, PB III, 27 gram
Old Jun 23, 2008, 09:25 AM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
It looks like fun. What size and type foam. It looks like 6mm EPP?
rmgmag is offline Find More Posts by rmgmag
Old Jun 23, 2008, 11:28 AM
Joined Dec 2006
Post 11 ... Link above;
“The EPP is 8mm thick (appx 5/16"). I think 6-7mm would have been better/lighter for this size plane, but in 8mm it sure is stiff and tough! The carbon tube is 3mm OD.” Dynomike
I will use quarter inch PB III skin one side
Old Jun 23, 2008, 07:32 PM
Strick is offline
Find More Posts by Strick
Sticks & Stones
Strick's Avatar
Kinston, North Carolina
Joined Dec 2006
Thank You!
Thanks Gramps:>),
This is just what I needed, can use some of the 6mm EPP that has been on my shelf for a year. Sloper Steve/SlowFly got me started back in to planes again. Big EPP fan for take a chance flying, push it to the limit and see how high it bounces! Super Slofly 28 scaled down,or SFO, thank you for kick-starting the old gray matter!
Thanks, Strick(:{)>
Strick is offline Find More Posts by Strick
Old Jun 24, 2008, 05:21 AM
Joined Dec 2006
Stick,
Great, please post back pics and weigh in against blue FFF.
I bet yours will be lighter. What motor?
‘gray matter’ . . . In my cast ‘eye to thumb synchronization’ through old gray matter.
Would like to try something other than bluecore but modest stash to use up first.
Old Jun 24, 2008, 07:50 PM
Joined Dec 2006
Tiny 3D starts life a ‘peanut’ chucker at 29g
Old Jun 25, 2008, 04:18 PM
smwpuck19 is offline
Find More Posts by smwpuck19
smwpuck19's Avatar
Joined Jul 2007
Cool! I'm nearly as finished with it as you are.
Anxiously waiting for the electronics to come...
Mine is out of FFF, too. Hope it flies as good as the author's in the vid!
wow, looks like a sweet little plane
smwpuck19 is offline Find More Posts by smwpuck19
Old Jun 26, 2008, 02:36 PM
smwpuck19's Avatar
Joined Jul 2007
just noticed something....
On the e-flite website is says to use only a 2-cell lipo with the park 250 motor.
Won't a 3-cell lipo damage something??
It doesn't look like the author looked into the electronic ratings before putting the equipment together....
Old Jun 26, 2008, 02:42 PM
j2m2t2 is offline
Find More Posts by j2m2t2
j2m2t2's Avatar
AZ
Joined Feb 2007
I read that the 250 shouldnt be run on 3S. I have one and havent run it on 3S because of what I read.
Here is the thread:
http://www.rcgroups.com/forums/showt...light=park+250
j2m2t2 is offline Find More Posts by j2m2t2
Old Jun 26, 2008, 02:51 PM
j2m2t2 is offline
j2m2t2's Avatar
AZ
Joined Feb 2007
Test data:
http://www.rcgroups.com/forums/attac...mentid=1143920
Old Jun 26, 2008, 03:53 PM
DaOldGuy is offline
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
That might explain some of its off the hook speed
DaOldGuy is offline Find More Posts by DaOldGuy
Old Jun 27, 2008, 11:06 AM
leebospeed is offline
Find More Posts by leebospeed
leebospeed's Avatar
Yorkshire, UK
Joined Dec 2006
Hope you dont mind, but.......
Hi guys,
I need this little ship in my collection!
I took the liberty to do a full pdf,(Drawn to suit 6mm Depron) hope no one minds too much!
All the best,
Leebospeed.
***EDIT!!!*** Revised pdf based on 'Gramp's' tweaks to the original design
leebospeed is offline Find More Posts by leebospeed
Old Jun 27, 2008, 11:09 AM
*314*john*314* is offline
Find More Posts by *314*john*314*
I'm a registered user!!!
*314*john*314*'s Avatar
Joined Feb 2008
gramps, did you end up buying this plane?
*314*john*314* is offline Find More Posts by *314*john*314*
Old Jun 27, 2008, 01:36 PM
Joined Dec 2006
leebospeed,
thanks for sharing
314,
nope, scratchin one from Dunomike’s two images
love peanut size (my sweet spot) with 3D moments
hope to maiden this weekend
Video "Tiny 3D" EPP Foamy with 3:1 thrust/weight Dynomike Electric Plane Talk 26 Jan 26, 2010 01:23 PM
Discussion Sub 3" EDF with 2:1 thrust:weight? Bugman Jeff Electric Ducted Fan Jet Talk 4 Feb 20, 2007 08:02 PM
Super-QJ with 1.3:1 Thrust/Weight ratio Gordon Johnson Scratchbuilt Indoor and Micro Models 18 May 03, 2005 05:22 PM
FS - Sky Scooter Pro with 3:1 gearbox wmuller Aircraft - Electric - Airplanes (FS/W) 6 Jan 03, 2003 02:55 AM
F/s Speed 380 With 3.1 Gearbox CLARKE Aircraft - Electric - Airplanes (FS/W) 2 Apr 23, 2002 11:05 PM
