Old Jan 25, 2003, 08:52 AM
FinePC
FinePC
Guest
n/a Posts
band-pass, high-pass, low-pass, notch???
How do I stabilize the inputs from a joystick?
I wired up a custom
joystick(http://www.soldcentralfl.com/flyingpenguin/rcstick.htm) for use
with FMS (http://n.ethz.ch/student/mmoeller/fms/index_e.html)
which has an internal joystick calibration function.
I count him braver who overcomes his
desires than him who conquers his enemies;
for the hardest victory is the victory over self.
- Aristotle
Old Jan 25, 2003, 03:12 PM
FinePC
FinePC
Guest
n/a Posts
Re: band-pass, high-pass, low-pass, notch???
Ok, sorry. The switches and pots in the controller are wired directly to the
game port. With windows calibration utility the primary x/y axes jitter. In
FMS all four channels jitter.
This is causing a bit of unstable flight in FMS that I find highly annoying.
If anyone can assist me with this I surly would appreciate it.
Old Jan 25, 2003, 03:22 PM
FinePC
FinePC
Guest
n/a Posts
oops, all the pots are 100k and 3 of them are audio trim and the 4th is a
linerar trim.
Old Jan 25, 2003, 05:12 PM
Prop Flipper
Prop Flipper
Guest
n/a Posts
It might not be your pots or switches but rather your game port or PC
assuming you tried all variations in settings. The pots don't jitter on
their own.
Prop Flipper
"FinePC" <finepc@gmx.net> wrote in message
news:b0upue$41o$1@news.chatlink.com...
the
In
annoying.
Old Jan 25, 2003, 06:12 PM
Art Steinmetz
Art Steinmetz
Guest
n/a Posts
How much jitter do you see with the windows utility. Some will be present.
Check the voltage at the pots (best done with a Oscope).
Art Steinmetz
the
In
annoying.
Old Jan 28, 2003, 01:32 PM
FinePC
FinePC
Guest
n/a Posts
Loost to me like alot. as if one where lightly bumping around the top end of
the stick.
Voltages are; 4.62, 4.17, 4.68, and 4.62.
I don't own an Oscope. Let alone use one:-)
Oh should I have not used telephone termanal wire inside the controller?
i.e. solid core cppper and one other metal, not to mention any other
electrical properties it's hiding from me.
Old Jan 30, 2003, 08:52 PM
Art Steinmetz
Art Steinmetz
Guest
n/a Posts
Using the Windows XP calibration, I see movement of two units at center with
my Dave Brown old controller. (665 -667 x axis; 533-535 y axis). My meter
is way out of calibration so can not help there. Voltage looks a little low
though.
Art Steinmetz
news:b16i02$hec$1@news.chatlink.com...
of
> the stick.
Best High Speed Low Altitude Parkie Pass LTChip Parkflyers 8 Oct 28, 2012 12:39 PM
For Sale Futaba FP-R148 DF FM Micro 8 Ch High or Low band DPage Aircraft - General - Radio Equipment (FS/W) 1 Jan 09, 2006 03:58 PM
high or low band??? gch Radios 1 Dec 13, 2003 12:46 PM
Futaba Super 8U, is it true it either works high _or_ low band? sizam Radios 3 Nov 25, 2002 04:56 PM
Dream High, Fly Low Todd Long Sport Planes 2 Apr 23, 2001 05:55 AM
