Old Jun 18, 2008, 08:51 PM
afinepoint is offline
Find More Posts by afinepoint
Richmond, VA
Joined Dec 2007
Flashing light on GY 401 gyro but GEM says all OK.
After my second flight I noticed the red light on the GY 410 flashing slowly. According to the manual that means "no rudder operation signal being input from the transmitter. At this time, the rudder does not operate."
The rudder operates just fine. The lights on the JR R921 transmitter are also flashing. The GEM 2000 monitoring system says all is OK by its rapid flashing light.
What gives? The helicopter is flying just fine.
Reg
afinepoint is offline Find More Posts by afinepoint
Old Jun 18, 2008, 09:24 PM
TheBum is online now
Find More Posts by TheBum
TheBum's Avatar
McKinney, TX
Joined May 2007
A flashing LED in that case probably just means that the gyro is getting rudder inputs. If you let it hover and don't touch the rudder stick, does the flashing stop?
TheBum is online now Find More Posts by TheBum
Old Jun 19, 2008, 01:40 PM
barracudahockey is offline
Find More Posts by barracudahockey
Multi-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Slow flash means its not initialized or not recieving a signal on the gain wire.
Flashing reciever lights means the voltage went below 3.5v and caused the receiver to reset. It could also mean you changed batteries and didn't turn the transmitter off.
If its a case of not turning the transmitter off, then the receiver just took the battery disconnect as you loosing power, it doesn't know any better.
To prevent the slow flash, leave the gyro switch in heading hold and rebind the reciever, its probably booting before the receiever and the fail safe on the gyro channel is rate mode, and the gyro wont boot correctly. Flipping it to heading hold and rebinding will make the fail safe heading hold mode.
barracudahockey is offline Find More Posts by barracudahockey
For Sale 'Nuther Big Bunch of stuff- Phoenix 35, Electron 6, GY 401 Gyro all Like new badbill Aircraft - Electric - Airplanes (FS/W) 11 Oct 02, 2005 10:19 AM
Killer deal on GY-401 but is he legit? turbojoe Micro Helis 16 Jul 08, 2005 05:07 PM
Futaba Gy 401 Gyro new, out of box ldracer Aircraft - Electric - Airplanes (FS/W) 0 May 26, 2003 03:58 PM
GY 401 Gyro $130.00 or best offer KenP Aircraft - Electric - Airplanes (FS/W) 3 Feb 10, 2003 09:29 AM
