Old Jun 18, 2008, 12:08 PM
agriebel is offline
Find More Posts by agriebel
agriebel's Avatar
Madison WI
Joined Aug 2003
Build Log
35" Xb-70
Not wanting to hijack hellrazor_77 build log I have started my own. It is a slightly larger build with a wingspan on 35" rather than the 25" hellrazor is doing. it is based on Steven Wongs plans and fuelsguys plans. I have most of the parts cutout. I ran out of depron and have to wait for more to come in. I am in a building mood also!
Not many parts, should be a quick build. Canard up front, but I forgot to not cut the elevons out to the tips of the wing, so no wing tip droop for me. I plan on following hellrazor_77 bomb bay technique and add a bomb bay. I guess a cruise type missile might be the best choice for something to drop.
I am thinking about making the nose solid rather than hollow. Should give me more room for shaping the nose.
agriebel is offline Find More Posts by agriebel
Site Sponsor
Old Jun 18, 2008, 12:20 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
Because of the size (60" long), it would be difficult to hand launch so I plan on setting up a dolly landing gear arrangement like hepdog did on his SR-71.
Power will be provided by a Little screamers super park jet with a 7x5 prop and thunderpower 1320 battery.
Site Sponsor
Old Jun 18, 2008, 10:41 PM
Esprit440 is offline
Find More Posts by Esprit440
Supersonic hover
Esprit440's Avatar
Michigan, United States
Joined Sep 2003
Cool project - I just happened to run across this XB-70 site today, really fascinating. Good luck!
-Matt
Esprit440 is offline Find More Posts by Esprit440
Old Jun 19, 2008, 07:27 AM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
Wow, I learned more new info about the XB-70 in that article than I had previously known...thanks
Site Sponsor
Old Jun 20, 2008, 07:10 AM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
The depron came in and I am at it again. There was a previous thread where the person was confused about the notches in the bottom of the fuselage sides. He didn't know what they were for. When the plans were tiled the notches were removed. Well, it turns out that you need those notches. The neck of the fuselage sets on top of the wing. So, what the notches do is allow you to glue the fuselage bottom to the sides then attach them to the wing and get a smooth line.
Also the plans show the whole forward canard moving like a taileron, however if you look in the picture you can see that it is clearly set up like a horizontal stab and a conventional elevator.
Site Sponsor
Old Jun 20, 2008, 11:20 AM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
I have been thinking about the wingtip droop and was never happy with the other system that was developed. It required 2 servos and looked like there could be some slop in the mechanism. I came up with a different way that only requires 1 servo and is really tight. Best of all, it is simple!
Site Sponsor
Old Jun 21, 2008, 07:30 AM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
More progress today. Glued the wingtip pushrod tubes into position. Cut a small slot to make it fit in the wing better. Also glued on the sidewall doublers.
Started working on the truck type landing gear. I'm just now sure the best way to attach the landing gear frame to the fuselage.
Site Sponsor
Old Jun 21, 2008, 01:45 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
Update on the notches! The notches caused a problem, there was a large gap on the bottom of the fuselage caused by the notches. So, I recut the pieces without the notches. But that is not exactly right either. If you look at the fuselage attachment on the real aircraft you see there is a gap between the fuselage and the wing. So, the notch is correct if you want that gap, it is just in the wrong spot. It was too far back. I recut it and now it fits great.
Site Sponsor
Old Jun 25, 2008, 12:08 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
I have made some progress today. Test fitted the elevons and wing droops. Then reinforced the upper fuselage with some basswood and epoxy. Looks like about 15oz without battery or paint.
Site Sponsor
Old Jun 25, 2008, 11:24 PM
Hepdog is offline
Find More Posts by Hepdog
Registered Plan-a-holic
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
WOW, I didn't think many of my ideas were useful Thanks.
This has been the best dolly I have ever built - 20+ flights and not a single hang up or glitch - even on rough grass.
Whatever you want to know just ask.
Here's 2 interesting pics showing liftoff - very cleanly. The XB 70 should do the same.
Nice build BTW
Hepdog is offline Find More Posts by Hepdog
Old Jun 25, 2008, 11:46 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
hep, those are AWSOME pics. that is one GORGEOUS SR.
corsair nut is offline Find More Posts by corsair nut
Old Jun 26, 2008, 06:28 AM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
That's the great thing about this site, you pick up bits and pieces from other builders that you can use on other birds. I've always admired your Black Bird projects. Some really great work that has helped to inspire me.
Site Sponsor
Old Jun 26, 2008, 08:01 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
The servos for the elevon's and wing droop are mounted along with the servo for the canard. I had some problem getting it setup correctly. My spektrum receiver has a channel labeled aux1 but when I tried to mix elevator with aux1 all I could find in my spektrum transmitter is aux2. I ended up mixing it with the rudder channel and reducing the rudder end point to zero. That way if I bump the rudder I don't get elevator!
There is a video of the wing droop movement here http://www.rcgroups.com/forums/showt...5#post10034524
Site Sponsor
Old Jun 27, 2008, 03:28 PM
agriebel is offline
agriebel's Avatar
Madison WI
Joined Aug 2003
Some progress today. Glued the upper fuselage to the wing and attached all of the control surfaces permanently. I need to finish up the landing gear so I can place the supports for it in the lower fuselage. I came up with an idea for the engines. I'll post it when I get it finished.
Site Sponsor
Old Jun 27, 2008, 03:40 PM
tehachapi, CA
Joined Jan 2006
ag, looking good dude! a couple things though...regarding the SPJ...have you run it on that e-fltie esc yet? reason i ask, was that mine didnt run well, err all all on that esc. the CC TB 18 or 36 will work GREAT with it. also, airflow..tha motor wont be getting any airflow at all like that...with SPJ's its pretty criticle that they get good flow. id suggest getting some cooling to her. try a stick mount, they work best for cooling, as they dont block the air.
XB-70 Successful flight! Dr. Jet Electric Ducted Fan Jet Talk 40 May 06, 2007 02:05 AM
XB-70 scratch build TeamSME Electric Ducted Fan Jet Talk 24 Jul 30, 2004 11:52 PM
XB-70 First Flights tonycl65 Foamies (Kits) 21 May 13, 2004 09:09 AM
Fan Fold XB-70 Thatovalguy Foamies (Kits) 12 Jul 18, 2003 04:39 PM
XB-70 project? U812 Electric Ducted Fan Jet Talk 14 Oct 17, 2002 09:12 PM
