Straight Up,
No problem with question bombing
I find ArtHobby about perfect for my requirements, every piece is sold separately thus enabling you to have whatever spare part you want: infact i plan to purchase another wing set for full house... if only they would use Drela airfoils...
Anyway, i made some changes in the didheral by augmenting it on the central panel and diminishing the last break.
The wing is very robust and goes together with no problems at all.
I used Hs 56 Hb - Karbonite and i find them perfect for the task.
Also the Dyneema-carp fishing elastic system is holding very well.
I'm having a ball by launching it with Dynaflite DYFP8306 Up-Start Standard 3/16" Rubber.
Current weight is exactly as planned
and it floats forever indeed
I'm havig some mild dutch roll problems and i plan to cure it by adding some expo to rudder, move CG slightly backwards and lighten the outer panels by replacing those hard balsa tip blocks with some lighter ones.
Anyway it handles like a DLG and you can wrap it on the mildest thermals.
I will post other photos soon, so stay tuned!
Best regards,
Francesco
P.S. On Ibis i would not use that FG fin...but i'm lightness addicted!
