Old Jan 24, 2003, 09:48 PM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Making a big wing strong enough
I have cut foam cores for a large sailplane project: 12' span, 15" root chord, 9" tip chord. 4 sections, each 36" long.
I plan to use 3/8x3/8" spruce spars top and bottom for the root sections, aand 1/4x1/4" for the tip sections. I plan to use a 1/2" id aluminum tube and 1/2" carbon rod for the root joiner. Tip sections will have plywood joiners and be glassed together.
Here's the [art I'm struggling with: Should I cover it? I've used 3/4oz glass on a 7 foot wing with good success; no L.E. carving, etc. I may go to 1.4oz cloth and do the same for this 12' one.
Any experiences out there to share? Thanks.
FlyingW is offline Find More Posts by FlyingW
Old Jan 24, 2003, 10:02 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You need to use 1/8" vertical grain balsa for the spar, and cap it on both sides with carbon tow. You're not 'covering' the foam, you're building a glass wing and using the foam to give it shape. It needs to be vacuum formed. You don't need to use heavy glass.
..a
Question is the fling HLG wing strong enough to DL? jstevens Hand Launch 6 Oct 29, 2006 09:22 AM
Discussion Making a lighter (yet strong) FFF wing Nethole Foamies (Scratchbuilt) 4 Aug 13, 2006 11:40 PM
Hot glue strong enough for wing joint ?? .-=banzai=-. Flying Wings 13 Sep 14, 2005 06:19 PM
Making the Big MONGO electric?????????? Rob R Foamies (Kits) 9 Jan 11, 2002 07:57 AM
Making Foam Wing dorysch1 Electric Ducted Fan Jet Talk 2 May 09, 2001 10:16 AM
