Old Jun 17, 2008, 04:18 PM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Byron A-4 Skyhawk EDF conversion
Well, I've finally got my new shop together and starting on my next project. This is my Byron A-4 Skyhawk that has hung from the rafters for about 12 or so years. The club I used to belong to outlawed DF's as it was being built - so it has never been finished, but I could never get rid of it as it is my favorite aircraft. I quit that club and was away from the hobby for 5 or so years, then I got back into it with GWS P-51.
So it was already half built, and the conversion should be a piece of cake. I already have the Hacker A50-14S motor and the CC HV 85 ESC. I will be using 10S. Probably 2 5S packs of Flightpower EVO 25 5000 mah. The second grey skyhawk is another kit I picked up. It will get a conversion at a later date.
skyhawk is offline Find More Posts by skyhawk
Old Jun 17, 2008, 05:23 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Looks great!!! Have est. RTF weight?
Bob
bruff is online now Find More Posts by bruff
Old Jun 17, 2008, 05:55 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
That sure brings back memories!
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jun 18, 2008, 12:15 AM
skyhawk is offline
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Bob,
I'm hoping to come out at 11.5 lbs that would be just 1 lb more than the Byron recommended weight. Part of my problem is I doubled up the engine former and a few others as the original pieces didn't last long with an OS 91 and a buch of glow fuel. I also added some mounting platforms as I hate glueing all my components in place (air tanks, fuel tanks, recievers, etc...)
Old Jun 18, 2008, 12:19 AM
skyhawk is offline
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
First thing I did was to convert my fan to electric. I won't go into much detail as I just followed Bob's instructions. http://www.rcgroups.com/forums/showthread.php?t=606759
I just drilled and tapped the holes in the adapter, then mounted it and locktited the screws in. Then I ground them flush.
Old Jun 18, 2008, 12:23 AM
skyhawk is offline
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Here are the rest of the pics.
Old Jun 18, 2008, 09:03 AM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
Are you going to eliminate cheater and install ducting for intake? Just curious because this was always a big problem with the Byron jets. They ignored everything in front of the fan as if it didn't exist. DB
Doug Bateman is offline Find More Posts by Doug Bateman
Old Jun 18, 2008, 10:08 AM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
On my Byron EDF jets, Top Gun F-15, Byron F-16 & now Byron Mig 15 , no I did not. You don't get an improvement by adding duct work to this fan. Now install a 5" fan different story. The Byron fan needs a lot of air and the only way is with the cheater hole. Now what does help, now there is no glow motor or tune pipe in the way plugging up the forward area. My Byron jets fly just like the glow version but with out the mess or headaches.
Bob
Bob
Old Jun 18, 2008, 10:58 AM
Tim Wan is offline
Find More Posts by Tim Wan
Joined Apr 2008
Metal EDF set
Have you seen this type EDF set (attached) before. Even this is only 68mm EDF which is made by full metal (Alu. alloy) with around 85g including back cowling. Only the fan is still used plastic material. But it can be provided the thrusting up to 1.2kg powered by 11.1V (3s Lipo battery) and 4300KV motor. Also this unit has been launched to market after Shanghai Model Show this month. Maybe on or before September, they will put new unit 110mm size to market. you can visit their web-site :www.rclander.com
Tim Wan is offline Find More Posts by Tim Wan
Old Jun 18, 2008, 03:26 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
???????? wot the..
Old Aug 29, 2008, 02:29 AM
skyhawk is offline
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Well, it's comming along nicely. Got the damage repaired. Actually - it's not really damage, it's more like I got carried away making it more scale like rotating mains and doors when my skills are not really up to that. I also want a simple, reliable plane. KISS
My new JR 2.4 radio and flightpower packs should be here tommorow - then I can finish the install and major assembly. The foam parts are now glassed and the retracts are in. I had some leaks that took a while to find - but they all work good now. I also made a mount for the ESC - should get good airflow in the cheat hole.
Old Aug 29, 2008, 09:17 AM
Joined Dec 2004
Skyhawk, make sure you break in those Flightpower packs. I have 2 new 4900 5-cell 25C packs that are starting to sag after about 3 minutes flight time. These packs have maybe 4 flights on them. My 2 year old T/P 5000 extremes perform better and i'm pretty pissed off about it. These things are top dollar at Tower hobbies. I have to hook up the meter and find out whats going on. I was flying my Yellow A-4 when the power drop occured so it was a partial low voltage cutoff at full power. I was able to make it back to the field on reduced power. Doug
Old Aug 29, 2008, 02:45 PM
Mikael is online now
Find More Posts by Mikael
Mikael's Avatar
Sollentuna,Sweden
Joined Sep 2000
Doug
I have PolyRC 4900 25C that also have poor performance. My old Xcell 3900 perform better. Maybe they use the same type of lipo.
Mikael
Mikael is online now Find More Posts by Mikael
Old Aug 29, 2008, 05:25 PM
skyhawk is offline
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Doug,
I fully intend to run these packs through about 3 or 4 times at half throttle or less. I have a 3S 2170 EVO pack that is starting to sag as well. I never knew about a lipo "break in" untill it was too late for that pack. I just spent $600 for a set of batteries and I'm not going to take that lightly!
Old Aug 29, 2008, 05:38 PM
k_sonn is offline
Find More Posts by k_sonn
k_sonn's Avatar
Bellevue, WA
Joined Feb 2004
Doug,
The A-4 looks good.
To break in the Flight Power packs follow this procedure:
http://www.bvmjets.com/Pages/LiPoBattBreakIn.htm
I purchased the 12S 6400 mAh packs and followed recommend procedure for running them on the ground. I have flown it twice at mostly half throttle and the packs are doing fine. I'm going out tomorrow to put a few more flights on it to get it ready for Ohio.
Kirk
k_sonn is offline Find More Posts by k_sonn
Discussion TamJets A4 Skyhawk EDF conversion MaHö Electric Ducted Fan Jet Talk 40 Oct 22, 2010 01:17 PM
For Sale Byron F-16 kit, EDF conversion bruff Aircraft - Electric - Jets (FS/W) 3 Apr 05, 2007 08:38 AM
Video TamJets A4 Skyhawk EDF conversion MaHö Electric Plane Talk 0 Feb 19, 2007 02:28 AM
Yellow A-4 Skyhawk EDF conversion setup Fred Bronk Aircraft - Electric - Airplanes (FS/W) 6 Mar 11, 2005 09:30 PM
RBC A-4 Skyhawk EDF Mark Nankivil Electric Ducted Fan Jet Talk 37 Apr 25, 2001 05:15 PM
