This thread is privately moderated by mpotter187, who may elect to delete unwanted replies.
Old Jun 17, 2008, 04:18 PM
mpotter187 is offline
Find More Posts by mpotter187
Trader Rating: 39
Joined Aug 2006
Trader Rating: 39
Sold
Heads up RC (Power up) 15 Amp Burshless ESC and props
Heads UP RC (Power up) 15 Amp brushless ESC was only used for testing never flown has a little bit of wear on the stick from test fitting into plane. Programmable through transmitter. Has male Thunder power type T-Plug on the battery side and 2.3mm femail bullet connectors already soldered on. Has universal type servo plug.
Weight = 0.4 ounces (12 grams)
Dimensions = 1.5 x 0.8 x 0.3 inches
Power handling 15 amp continuous, 20 amp burst
14.00 Shipped OBO
5 GWS 9050 (9x5) direct drive props and 3mm collet prop adaptor standard length perfect for the props. Props are unused, they will need to be drilled out to use with the included prop adaptor
7.00 shipped. OBO
I will take 18.00 for everything shipped.
I take paypal or money order ebay ID is lowship187 for reference if needed pics attached below.
mpotter187 is offline Find More Posts by mpotter187
Old Jun 17, 2008, 09:33 PM
himeros is offline
Find More Posts by himeros
Trader Rating: 98
O. C. CA
Joined Jan 2005
Trader Rating: 98
I'll take it, sending you a p. m. next.
Himeros
himeros is offline Find More Posts by himeros
Old Jun 18, 2008, 01:41 PM
Trader Rating: 39
Joined Aug 2006
Trader Rating: 39
Sold Thanks!
Yippee! 15 amp wattage esc with bec and power switch cheap new flyer Aircraft - General - Radio Equipment (FS/W) 6 Oct 30, 2004 07:32 PM
WTB: 4 micro servos, 15+amp brushed esc, 4 channel rx Capgun_Slim Aircraft - Electric - Airplanes (FS/W) 7 Nov 25, 2003 07:57 PM
WTT my 15 amp mpi esc for a .... RenoRacer Aircraft - Electric - Airplanes (FS/W) 1 Jan 08, 2003 05:36 PM
15 amp GWS esc cutout problem HELP!! Red wings Parkflyers 1 May 19, 2002 10:52 AM
FS: Astro Cobalt 15 & 217D ESC karlk Aircraft - Electric - Airplanes (FS/W) 2 Feb 10, 2002 08:22 PM
