Feb 06, 2003, 10:34 AM
Rochester Monroe Cty, New York, United States
Joined Aug 2002
Better results today
Flew the smaller wing version today. The connector wire broke on the larger wing version, so it was not tested.
This is the 16"X2.5" polyhedral wing version. It could make multiple trips around the gym, perhaps three, but would not climb. There was significant tail fluttering, so a centering magnet is in order. I have some of Forcefield's smallest, so that shouldn't be hard. I need to rebuild with the Rx further forward, as the balance could have been a bit further forward.
The power system seems good. The N20 with GWS 2.5X08 pushed it at a nice indoor speed. I should be able to shed a gram of weight, center the rudder, and reposition the Rx to achieve better flight characteristics.
We are so close. I will weigh the whole mess tonight and build two new versions a bit more refined.
Hippo,
That looks so much better than my crude versions. Your design skills are showing through. Attentioin to detail shows through as well.
Note that my last couple were made up with the bottoms of the fuse sides glued directly together and a V shape achieved by gluing an oversized strip of center-cut F3 on the tops. The excess is trimmed off after gluing. This made for an easy assembly, lightened it a bit, and used the inherent strength of triangles.
You may also want to try a fuse entirely of center-cut F3. The stuff is incredibly light. Peeling the F3 may yeild the same results, but I used the skinned for wings, so there is always some center cut available.
