Old Jan 24, 2003, 06:46 PM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Question
End-to-End Packs with an Odd Cell
Hoping to appeal to your technical generosity:
Please advise on good ways to add that last cell at the end of an end-to-end soldered battery pack. I want to make a nine-cell pack out of an 8-cell one. Are there special bars that make this easier?
Freezing in NJ
FlyingW is offline Find More Posts by FlyingW
Old Jan 25, 2003, 03:55 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Use wire?
Haldor is offline Find More Posts by Haldor
Old Jan 25, 2003, 04:20 AM
Mike Seale is online now
Find More Posts by Mike Seale
f5b-uk
Mike Seale's Avatar
United Kingdom, Dorset
Joined May 2002
I use copper bars, about 1mm x 5mm x 20mm for sub C cells. You could fasion these from a piece of copper water pipe if you can't get hold of a strip of copper the right shape.
Pre-tin both ends of the copper bar. Solder the bar to the ends of each 'stick' of 4 cells so the bars point out away from each other. Use the loose cell as a guide to bend the bars with a right angle. Remove the loose cell and bend the bars a little more so that the cell is now gripped by the bars. It's now very easy to solder the end cell and get it all lined up perfectly.
Mike Seale is online now Find More Posts by Mike Seale
Old Jan 25, 2003, 05:20 AM
frederm2002 is offline
Find More Posts by frederm2002
CheapBatteryPacks.com
Beaverton, OR
Joined Dec 2002
If you are trying to do this config: ====|
where "|" is the last cell then The easiest is to do this:
Get some Desoldering Braid (Battery braid) from your local Electronics store for about $2.. If you need more thickness simply bend in two or 3 etc.
Cut strips to length. Pre-tin the battery ends. Put one strip on the end of each battery first. Put last cell between the two ends. Glue in place with a thick CA. Hit it with some booster. When dry. Bend braid into place and solder.
Anyway that's the easiest I know of and braid is cheap. Wire works too. But the braid is soo flat it will bend to any shape..
If you need more info let me know. I build a lot of packs this way and have some pics etc.
frederm2002 is offline Find More Posts by frederm2002
Old Jan 25, 2003, 08:24 AM
ScottS is offline
Find More Posts by ScottS
ScottS's Avatar
Houston,TX
Joined Mar 2000
One way to do this is to remove the bar or braid that is connecting the two sticks together and put the odd cell on the end. This might not be the prettiest pack but it should give you the general idea.
ScottS is offline Find More Posts by ScottS
Old Jan 25, 2003, 08:48 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I use a couple of battery bars - both bent at right-angles. I've soldered the button of one cell to the side case of another, but the contact area is low, and you have to use too much solder to get a good physical connection. I like to use bars, and not braid, because the braid has a little mechanical give to it, which will eventually wear the braid or the connection. This is all personal preference, of course. Do what you're most comfortable with - for me, it's bars. Solder the bars to the ends of the stick first, as close to perfect alignment as possible, then tune with a pair of pliers to get it so the end cell is a push-tight fit. Then solder in place.
..a
Old Jan 25, 2003, 09:13 AM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
Here is my first attempt at the "odd" cell. I use these in my Kwik-e. These CP2400 cells were some of my first cells I tried to solder together and I was trying to learn to solder at the time hence the excess solder.
kelvin is offline Find More Posts by kelvin
Old Jan 25, 2003, 09:14 AM
kelvin is offline
Joined Jan 2002
Another. I use braid with some heat shrink.
Old Jan 25, 2003, 10:27 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Nicely done!
..a
Old Jan 26, 2003, 08:00 AM
Ben Diss is offline
Find More Posts by Ben Diss
Ben Diss's Avatar
United States, OH, Powell
Joined Jun 2000
Nice pack. Only thing is that solder joint between the wire and cell looks like it could have used a hotter iron. The solder should flow freely around all the contact points. When it cools it should be uniform in shape and shiney.
-Ben
Ben Diss is offline Find More Posts by Ben Diss
Old Jan 26, 2003, 09:26 AM
kelvin is offline
Joined Jan 2002
-Ben
My iron is a 60 watt Hobbico. I'm always afraid to get things too hot on the cells. My procedure is to tin the cell and braid. Then I hold the braid down with a screw driver. Then I apply the iron and release the screw driver, wait a few seconds, the solder melts and then I apply to screw driver tip onto the braid to hold it and remove the iron. The screwdriver tip seems to absorb some of the heat.
I'll check my connections. Thanks
Kelvin
Old Jan 26, 2003, 10:01 AM
FlyingW is offline
FlyingW's Avatar
Joined Dec 2001
Last (odd#) Cell - Thanks
Thanks for all your ideas and recommendations. I'll post with my results.
Old Jan 26, 2003, 12:16 PM
Ben Diss is offline
Ben Diss's Avatar
Joined Jun 2000
Hmm... Flying W in New Jersey? Does that refer to a little airport east of Philly with an airplane shaped swimming pool (that hasn't been used in 20 years).
I did my primary flight training there in '90.
-Ben
Old Jan 29, 2003, 08:27 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Here you go.. had to make a 7xCP1300 tonite..
..a
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Wanted WTB: 8 cell NiMh end to end packs thomer Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2005 02:06 PM
Question Can I charge packs with an industrial HP power supply ? yshimoni Batteries and Chargers 6 Nov 15, 2003 08:28 PM
Problems setting the throttle end points with an ESC. pik20 Electric Sailplanes 1 Jun 17, 2002 12:36 PM
Problems setting the throttle end points with an ESC. pik20 Power Systems 0 Jun 16, 2002 11:51 PM
Side by Side vs. End to End/stick battery packs erashby Power Systems 3 Jan 31, 2002 08:09 AM
