1300 RPM test flights today. 286 Watts for hovering. 258 Watts for forward flight
![]() This is proving to be quite a versatile setup - I haven't even flown this heli at head speeds over 1600 yet - and all I'll have to do is change the throttle curve. This is great!
I've updated post 6791 with the results of today's flights. Awesome day for flying too ![]() -John
If you download the manuals for both you can compare and see the details and differences more clearly. Many of the parts are similar however. |
It's going to be interesting for sure
![]() From what I've read, the blades create lift at lower angles of attack (even at 0°), which means less drag placed on the power system for a given amount of lift, which would require less current, so longer flight (it seems anyway). I may have to adjust my above-mid-stick pitch curve to coincide with blades that have 2x (or whatever) lift. Who knows, maybe a combo of both (lower RPM & increased lift) is possible ? I have to be careful though, as head speed slows so does the tail rotor, and if I slow it too much, then add blades with extra lift (extra torque) the tail may not be able to keep up since it will be spinning slower. I'll have to put my largest tail blades on if I go down that path ... or get larger ones. |
United States, OR, Portland
Joined Jan 2012
Since these blades are suppose to generate lift at 0° pitch you should get light on the skids at mid stick & lift off sooner pitch wise, at your current settings. I would say keep the throttle curve where it is, but reduce the pitch curve above mid stick.
~psguardian |
Joined Jan 2012
Is your rudder at 85% rate? (I think that's what I heard?) I think the only way you could go lower is if you can you bump it up to 100%. If it's already there you could add some negative expo to make it quicker, or bump up the gyro maybe.
~psguardian |
| Thread Tools | |
| Discussion Tales of Gadget's Swift 16 | Gadget01 | Large Electric Helis | 486 | Nov 18, 2010 12:13 AM |
| Discussion Tales of Everyone's Swift(s) | JustPlaneChris | Electric Heli Talk | 2551 | Jun 17, 2008 08:46 AM |
| FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. | Etonic | Aircraft - Electric - Airplanes (FS/W) | 45 | Jan 10, 2004 07:07 PM |
| Four red 1400SCR's and two 75mah 7 cell packs | Lance | Aircraft - Electric - Airplanes (FS/W) | 1 | May 20, 2002 01:55 PM |
