United States, NY, Coram
Joined Jul 2012
I just took the tail blade grips off. They are just traditional bearings with a spacer in between, no thrust bearings...I noticed they were pretty loose. How tight should they be? I'm assuming until they bind than back off a hair? and what stops them from loosening up? I just want this figured out.... It has to be mechanical and not the gyro... I have to be overlooking something
Blue threadlock keeps the grip bolts from loosening up and flying out. The grips should rotate freely without any resistance. Those spacers are important - make sure both grips have them between the bearings. The used heli I bought was missing them (stressing the bearings when the bolt was tightened) and the grips/slider assembly was very hard to move - unflyable basically.
Joined Apr 2009
GyroMan - it was a very strange situation. The previous owner claimed ignorance to a lot of things that were wrong with the heli - blaming them on his previous owner. I don't think either of them knew how to properly build/setup/fix a heli - that thing was an explosion waiting to happen. If somebody else were to have bought it instead of me and actually spooled it up it would have been really, really bad. 6S, 1100kV and a 13T pinion, with McGuyver'd arms & pushrods in the head
![]() gs550t1981 - What did you find ... do tell
| Thread Tools | |
| Discussion Tales of Gadget's Swift 16 | Gadget01 | Large Electric Helis | 486 | Nov 18, 2010 12:13 AM |
| Discussion Tales of Everyone's Swift(s) | JustPlaneChris | Electric Heli Talk | 2551 | Jun 17, 2008 08:46 AM |
| FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. | Etonic | Aircraft - Electric - Airplanes (FS/W) | 45 | Jan 10, 2004 07:07 PM |
| Four red 1400SCR's and two 75mah 7 cell packs | Lance | Aircraft - Electric - Airplanes (FS/W) | 1 | May 20, 2002 01:55 PM |
