Old Nov 06, 2012, 11:12 PM
gs550t1981 is offline
Find More Posts by gs550t1981
Beginner Pilot
United States, NY, Coram
Joined Jul 2012
Swift Nx Spool up Shake!!!!
Hey guys, first post in this thread. I am a new Swift nx owner with three flights on her. The second flight on it the belt loosened up and the thing spun out of control and I crashed. I finally got her all back together, but I went to fly it today and on spool up the swift starting shaking uncontrollably at about half full head speed, the blades struck the ground and broke both plastic blade grips, i'm sure it bent the feathering shaft, etc.... My question is why do these have such a problem with shaking on spool up and spool down. It kind of makes me regret getting this after reading all the reviews and no one having a solution to the problem. I didn't even get it off the ground today after a week of rebuilding from the last crash. It is an affordable heli and that is why I got it but maybe I should have waiting a little longer, saved more dough and got something else? I don't know. I just want to get it flying right. Any ideas? Thanks.
Jeff
gs550t1981 is offline Find More Posts by gs550t1981
Old Nov 07, 2012, 01:23 PM
rotoraddict is online now
Find More Posts by rotoraddict
Joined Jul 2008
Jeff, check out post #6 in this thread in the Century forum on Helifreaks.
http://www.helifreak.com/showthread.php?t=454693
There are various things that contribute to and/or amplify that dance...from head speeds, to type of blades, to tightness of blades in their blade holder etc. This meant that some did and some didn't.
But the cure all that I have found, was the suggestion relative to increasing the spacing in the LG struts from the stock 6" or so, to about 8". This you can do simply by heating the struts in the oven while placing something between them to hold them out at an 8" spacing, then allowing to cool completely before removing whatever you used to hold them out at that spacing.
rotoraddict is online now Find More Posts by rotoraddict
Old Nov 07, 2012, 01:37 PM
FR4-Pilot is online now
Find More Posts by FR4-Pilot
That's Pretty Neat!
FR4-Pilot's Avatar
Joined May 2009
Could it be possible something from your first crash went undetected during your rebuild? That is, maybe there was a broken part in the head or a slightly bent shaft somewhere you didn't notice ... ? Or damage to one or both of the blades ... or skids/struts ...
Mine has a little shake on spool up (until the blades find their comfy spots), but nothing ever severe enough like you mentioned. It also shakes a little on spool down, but nothing a little negative pitch doesn't take care of.
Unless you got a defective kit or something .... Disheartening to hear of your problems none the less ...
-John
FR4-Pilot is online now Find More Posts by FR4-Pilot
Old Nov 07, 2012, 08:30 PM
Joined Jul 2008
Referring to the link I gave earlier, following that thread, the fellow had used some cheap and real bad C/F blades - following through with it, they seemed to be a major contributor to his problem as seen in this thread.
http://www.helifreak.com/showthread.php?t=456377
Old Nov 08, 2012, 12:52 PM
Beginner Pilot
Joined Jul 2012
You know what... I was using the $18 helidirect 550mm gf blades. How can I chack if the cg is good on the blades before I put them to use? I balanced them but I guess that was not enough....
Old Nov 08, 2012, 05:06 PM
Joined Jul 2008
I believe those where the same blades the other fellow was using - try some different blades...any $18.00 CF blade would be very suspect IMHO.
I have found even the 520mm Century wood blades that came in my old Swift 16 were better then all of the cheap C/F blades I tried later.
Old Nov 16, 2012, 10:41 AM
Cyclick is offline
Find More Posts by Cyclick
Joined Dec 2007
You can buy blade balancers like this one:
http://www.centuryheli.com/products/...051&pageid=452
Measuring the spanwise CG is relatively easy. Measuring the chordwise CG is the difficult one, and this is the one that most cheap composite blades get wrong....along with dangerously weak blade roots.
My advise is the same as others - get some decent blades.
Cyclick is offline Find More Posts by Cyclick
Old Nov 16, 2012, 11:03 AM
Beginner Pilot
Joined Jul 2012
Balancing the blades long ways I did. I have a balancer for that. How can I check the chord balance? What are your guys method? I would like to check all my blades for now on, lol, thanks
Jeff
Old Nov 18, 2012, 05:49 AM
Greybird is offline
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
Well, I have not worked on my scale project,but, I have put 20 something more flights on my 620SE in the last couple of weeks. What a nice flying heli. Here is a pic from a few minutes ago.
Greybird is offline Find More Posts by Greybird
Old Nov 19, 2012, 12:01 PM
Joined Jul 2008
Love those canopies!!! What did you use for paint?
Old Nov 19, 2012, 01:25 PM
Beginner Pilot
Joined Jul 2012
I think he used decals.... I have one very similar that I got from callie graphics
Old Nov 19, 2012, 01:56 PM
Beginner Pilot
Joined Jul 2012
Hey, Can anyone post a pic of how they have their tail servo mounted on the nx? Just wondering also which way tail servo control arm goes.... Thanks
Old Nov 19, 2012, 06:52 PM
simages is online now
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
Yes Greybird use Graphics from Callie....... she's great!
She did all my Swift "Tribal" graphics plus the MT 325SE and Hirobo Quark
@gs550t1981- in that picture the NX servo arm is up on the tail servo....
simages is online now Find More Posts by simages
Old Nov 20, 2012, 09:10 AM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
Yes, Callie Graphics beats trying to paint those "milk jug" plastic canopies.
Old Nov 20, 2012, 12:04 PM
mligosh is offline
Find More Posts by mligosh
mligosh's Avatar
New Smyrna Beach, FL
Joined Jun 2005
"Hey, Can anyone post a pic of how they have their tail servo mounted on the nx? Just wondering also which way tail servo control arm goes.... Thanks"
Here's my installation.
I stretched my gear legs as suggested, it may be better, but it still has some of the shakes. It started hopping around on me during spool down. For me the best thing is just some positive pitch in the blades.
mligosh is offline Find More Posts by mligosh
Discussion Tales of Gadget's Swift 16 Gadget01 Large Electric Helis 486 Nov 18, 2010 12:13 AM
Discussion Tales of Everyone's Swift(s) JustPlaneChris Electric Heli Talk 2551 Jun 17, 2008 08:46 AM
FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. Etonic Aircraft - Electric - Airplanes (FS/W) 45 Jan 10, 2004 07:07 PM
Four red 1400SCR's and two 75mah 7 cell packs Lance Aircraft - Electric - Airplanes (FS/W) 1 May 20, 2002 01:55 PM
