Old May 01, 2012, 02:37 PM
karl k is offline
Find More Posts by karl k
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
About 2 hrs.
Not sure if I'm painting the canopy or not yet. Need to make the call before I get it in the air.
karl k is offline Find More Posts by karl k
Old May 01, 2012, 11:37 PM
FR4-Pilot is offline
Find More Posts by FR4-Pilot
Long Live Flybar !
FR4-Pilot's Avatar
United States, IL, Lombard
Joined May 2009
Originally Posted by karl k View Post
All ready for electronics. Attachment 4823648
She looks great!
Are you dis-assembling everything first? If not you might want to - I've found a bunch of 'surprises' in the pre-assembly that needed to be adjusted, replaced and/or corrected.
Mine's taking forever it seems - going on a couple weeks. The tear-down, inspection, correcting then re-assembly is brutal
-John
FR4-Pilot is offline Find More Posts by FR4-Pilot
Old May 02, 2012, 12:30 AM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Originally Posted by FR4-Pilot View Post
She looks great!
-John
John,
I concur, my build is taking forever as well. (My first)
I purchased my kit 2 months ago. Full time job and caring for my 3 year old son leaves me limited flying/build time. It would be easier to build from parts rather than have to deal with tearing down and rebuilding. I have my NX almost done. Need to install esc and bec, and setup all servos etc and program. (thank goodness for Finless Bob's videos) To make things worse I am using my new DX8, (learning all its nuances)
I bought a spare canopy which I am going to paint. I'll use the stock canopy w/ garbage stickers for the first flights. Good luck with your NX!
wavekatcher is offline Find More Posts by wavekatcher
Old May 02, 2012, 11:46 AM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
She looks great!
-John
I pull it apart as I go. Everything looked pretty good. Went over it with other guys that have Swifts and they agree with my findings.
After another couple hours she's ready for the maiden on the weekend as long as I have time.
The one thing I still want to do is make some plastic spacers for the elevator servo to replace the temporary hardwood ones.
Old May 06, 2012, 01:52 PM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
I have built a number of Swift 16's and Swift NX's that used many different servos and never had to insert such spacers.
What servos where you using?
rotoraddict is offline Find More Posts by rotoraddict
Old May 07, 2012, 12:07 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Turnigy 620DMG
They're rebranded blue bird servos.
It's just the depth of them that has bit me once ore twice.
Old May 07, 2012, 12:11 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
The Swift was maidened yesterday. It all went off without a hitch. It is very docile at the lower head speed I ran it at.
I only had time for one flight. I will give continued flight reports as I get used to the machine.
I found that I could avoid the shakes on landing by doing a mini auto to kill most of the head speed before touchdown, then holding 0 deg pitch. Hopefully it will be better flying from grass instead of pavement.
Old May 07, 2012, 10:10 PM
Long Live Flybar !
FR4-Pilot's Avatar
Joined May 2009
Congratulations Karl k!
-John
Old May 08, 2012, 01:29 AM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
-John
Thank you. She flies really gently.
I hope to get more flights in this weekend
Old May 11, 2012, 11:52 PM
Cyclick is offline
Find More Posts by Cyclick
Joined Dec 2007
About 2 hrs.
Get some spray primer from your local auto supply store that is designed for painting the plastic bumpered found on cars. Sand the canopy lightly with 600 grit, then spray on the primer. Then you will find most paints that are for plastics will stick well.
As for the decals, just rub some soapy water on the canopy and you will find that you can move them around esaily until you get them located in the manner and position you want. They actually can look pretty nice.
Cyclick is offline Find More Posts by Cyclick
Old May 16, 2012, 05:26 PM
Joined Jul 2008
+1 to the above.
Old May 18, 2012, 08:07 PM
hfenn is offline
Find More Posts by hfenn
Barnwell, SC
Barnwell, SC
Joined Sep 2004
I have some NX parts for sale in the classifieds. To restore you just need frame sides, motor mount plate, electronics tray, tail boom, blades and and a couple of links. Thanks for looking.
hfenn is offline Find More Posts by hfenn
Old May 20, 2012, 07:42 PM
Joined Jul 2008
Makes for a great trainer when set-up for training type of flights.
But it can also be set-up to be quite aggressive.
Century Swift NX 3D Flight with upgrades (2 min 48 sec)
Old May 21, 2012, 09:38 AM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
As far as head tuning, are lighter flybar paddles and more aggressive radio setup the only changes to the heli? What pitch range is run in that video?
Old May 23, 2012, 01:36 PM
Joined Jul 2008
The first thing to consider is the head speed. The higher the head speed, the faster the cyclic response, but the power system will not be able to use the same amount of collective pitch before loosing rotor speed. The higher head speed develops the same or more lift, at less pitch, then it may at lower head speeds, with more pitch, so you are really not giving up anything in that area, yet you will be gaining faster cyclic and tail response.
Nothing comes for free. The faster you turn the head speed, the less flight time you will get from the same battery pack. This is because of the extra power it takes to turn at a higher head speed. A good rule of thumb is that a 10% increase in head speed will require a 35% increase in power. How much pitch you can pull at the higher head speed will depend a lot on the current capabilities of your battery packs. The higher the C rating, the more pitch you will be able to pull.
You will find that the thinner & lighter paddles, like those from the Swift 16, will also increase the cyclic rate, at the expense of some fast forward flight stability. Of course C/F paddles, that are light with more area and a thicker airfoil, like those made by Rotor Tech, will give you faster response while keeping the FFF stability.
Discussion Tales of Gadget's Swift 16 Gadget01 Large Electric Helis 486 Nov 18, 2010 01:13 AM
Discussion Tales of Everyone's Swift(s) JustPlaneChris Electric Heli Talk 2551 Jun 17, 2008 09:46 AM
FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. Etonic Aircraft - Electric - Airplanes (FS/W) 45 Jan 10, 2004 08:07 PM
Four red 1400SCR's and two 75mah 7 cell packs Lance Aircraft - Electric - Airplanes (FS/W) 1 May 20, 2002 02:55 PM
