Old Apr 22, 2012, 11:01 AM
karl k is offline
Find More Posts by karl k
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Excellent looking heli, cbarnettone! Thanks for doing the research to find the parts that fit together for an inexpensive FBL conversion.
I've got an NX on order and a spare 3x1000 sitting in my toolbox. Maybe I'll order a few more parts and convert...
karl k is offline Find More Posts by karl k
Old Apr 22, 2012, 07:33 PM
cbarnettone is offline
Find More Posts by cbarnettone
Indianapolis, IN
Joined Mar 2007
Thanks karl k!! I say go for it! I don't think you'll be dissappointed with the conversion!
cbarnettone is offline Find More Posts by cbarnettone
Old Apr 24, 2012, 11:09 AM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
What power system are you planning to use (motor/ESC/Battery packs)?
What other helis have you flown?
What type of flying are you planning to do?
rotoraddict is offline Find More Posts by rotoraddict
Old Apr 24, 2012, 12:06 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
I've got an mCPx, Blade 450x with cx-3x1000 and finally, an HK500GT.
Mainly just sport flying.
I have a 600+ 1100kv motor from a previous project. Planning to run it on 6s 4900mAh packs and gear it for sub 2000 rpm head speed. I'll probably run a HobbyKing ESC. I've had good luck with them on helis.
My goal is a larger, more stable heli for me to get many flights to get more comfortable with it. The long flights are a plus here.
Old Apr 25, 2012, 01:16 PM
Joined Jul 2008
The 600+ motor works very well with the Swift NX on the type of 6S packs that you are planning to use.
The smallest pinion that can handle that power is the 9T, which will give you about a 2100 head speed at a 100% ESC setting and at 80%, would give you a head speed of about 1660. So any settings between 80 & 100 will adjust your rotor speed somewhere in between.
Old Apr 26, 2012, 02:40 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Good to hear that my guess wasn't out to lunch.
Old Apr 26, 2012, 05:27 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
It will also work well with the 650A+ 800kv 12/13T on 6S, typical hs is around 2krpm (+/- 200rpm)
phoenixheli is offline Find More Posts by phoenixheli
Old Apr 28, 2012, 02:50 PM
Cyclick is offline
Find More Posts by Cyclick
Joined Dec 2007
That is another of the great advantages of the Swift, it is so versatile that you can use so many different power systems and blade lengths. I have used blades from 515mm to 570mm on some of mine.
Cyclick is offline Find More Posts by Cyclick
Old Apr 28, 2012, 03:18 PM
Joined Jan 2010
It still blows my mind that you can fly on 4S with it.
Old Apr 28, 2012, 04:36 PM
Greybird is offline
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
I flew my original Swift for 100's of flights on 4S-10000mah packs. 18-20 minute flights.
Greybird is offline Find More Posts by Greybird
Old Apr 28, 2012, 06:04 PM
Joined Jul 2008
Those packs are pretty heavy! Just shows you how much extra weight that heli can carry.
Old Apr 29, 2012, 06:33 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
All ready for electronics. Name: ImageUploadedByTapatalk1335742363.412117.jpg
Description:
Old Apr 29, 2012, 07:42 PM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
All ready for electronics. Attachment 4823648
Careful your kitty doesn't chew your servo wires
wavekatcher is offline Find More Posts by wavekatcher
Old Apr 29, 2012, 09:46 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
She did start. I had to confiscate the heli from her.
Old May 01, 2012, 11:26 AM
Joined Jul 2008
About how much assembly time did it take to get to the point of being ready for the electronics?
I see you have not installed the decals yet?
Discussion Tales of Gadget's Swift 16 Gadget01 Large Electric Helis 486 Nov 18, 2010 12:13 AM
Discussion Tales of Everyone's Swift(s) JustPlaneChris Electric Heli Talk 2551 Jun 17, 2008 08:46 AM
FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. Etonic Aircraft - Electric - Airplanes (FS/W) 45 Jan 10, 2004 07:07 PM
Four red 1400SCR's and two 75mah 7 cell packs Lance Aircraft - Electric - Airplanes (FS/W) 1 May 20, 2002 01:55 PM
