Old Aug 09, 2011, 10:44 AM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
Originally Posted by Cyclick View Post
rotorsport,
Did you machine down the 6mm shaft on your Scorpion?
Yes, I also am curious as to what he did.
rotoraddict is offline Find More Posts by rotoraddict
Old Aug 13, 2011, 10:58 AM
Joined Jul 2008
Rotorsport
Are you here?
Old Aug 19, 2011, 02:53 PM
rotorsport is online now
Find More Posts by rotorsport
St.Albert, Alberta, Canada
Joined Nov 2000
yes
Back from two weeks of fishing Walleye
rotorsport is online now Find More Posts by rotorsport
Old Aug 19, 2011, 02:56 PM
Joined Nov 2000
Cyclick
No I did not go with that one I was looking at, I still have not purchased a motor for the next swift
Old Aug 19, 2011, 08:10 PM
H19 is offline
H19
Find More Posts by H19
H19
H19's Avatar
United States, ME, South Portland
Joined Feb 2011
Swift 16 in KIT form???
1-Where can one buy the Swift 16 in kit-form nowadays?
anybody know???
2-Im buying the AH-1 cobra kit for a winter build,
what motor/EC/Batt/servos, should i buy for long,scale, mellow flight ?
I have a GY401 gyro DX7 raidio and AR7000 reciever,
Icharger,
thank you
jp
H19 is offline Find More Posts by H19
Old Aug 20, 2011, 09:15 AM
Joined Nov 2000
Try Pivotal Hobbies
www.pivotalhobbies.com
They are on the west coast and close to the a distributor If its not in stock it usually does not take to long to get.
Charles
Old Aug 24, 2011, 03:41 PM
H19 is offline
H19
H19
H19's Avatar
Joined Feb 2011
anyone have any info on a motor/batt/ESC setup for long flight times?
not for 3D, just mello flying with an onboard camera,
Old Aug 30, 2011, 05:59 PM
Joined Jul 2008
The Century 600+ motor with the 9T pinion using a 5S, 30C pack of 5000 mah and an ESC setting for a head speed of 1500 will get you over 12 minutes.
Old Aug 31, 2011, 05:16 AM
H19 is offline
H19
H19
H19's Avatar
Joined Feb 2011
is that the 1110KV
1470KV
or
1300KV???
jp
Old Aug 31, 2011, 06:10 AM
H19 is offline
H19
H19
H19's Avatar
Joined Feb 2011
Originally Posted by rotorsport View Post
I have two swifts with the Century 600+ 1100 kv motor, 96 main gear and 12 tooth pinion gives me a head speed of 1830
I was just looking to try another motor with 1100 kv and from the forms the Scorpion 4025 1100 had been used by others.
I'm fitting a swift into another scale ship
what battery are you using with this setup?
and how are you getting that rotor/headspeed?
i dont get that on the RC calculator,,,
thanks
jp
Old Aug 31, 2011, 10:24 AM
Joined Jul 2008
Originally Posted by H19 View Post
is that the 1110KV
1470KV
or
1300KV???
jp
The 600+ is the 1110KV motor.
For even more versatility, more efficiency and more power, you can also use the Century 800LV, 650 motor.
Old Sep 01, 2011, 07:19 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
The 650A plus 800kv is also a decent balance between power and efficiency, but suited better for a 6S setup using 11-13T. Flight times are roughly 10-12 minutes with a 4800mAh 6S pack.
phoenixheli is offline Find More Posts by phoenixheli
Old Sep 02, 2011, 09:33 AM
H19 is offline
H19
H19
H19's Avatar
Joined Feb 2011
im confused, on centurys website the 800KV motor "CNE275"
is rated for 10S
ive also read its bad to run motors under or over there rated "S"
PLEASE unconfuse me,
my brain hurts from all this surfing and not understanding
Old Sep 02, 2011, 05:37 PM
Joined Jul 2008
is rated for 10S
That is its' maximum rating.
Old Sep 05, 2011, 09:13 PM
estarter is offline
Find More Posts by estarter
Berkeley, CA
Have you guy ever had issue with the plastic blade grips?
I have one broke off in flight today, my Swift16 has been hanging from the garage ceiling for 2+ years, took her out for a spin and had bad vibration in the second flight after flyin' about one minute, found one of blade grips broke off when landed, no crash and the blades only touch air. The blade grip screws are checked before first flight and they are just right, not very tight, flew smooth and great in the first flight.
Anyone has a set of good use metal grip and head block to get rid of, please PM me of price. Thanks,
estarter is offline Find More Posts by estarter
Discussion Tales of Gadget's Swift 16 Gadget01 Large Electric Helis 486 Nov 18, 2010 12:13 AM
Discussion Tales of Everyone's Swift(s) JustPlaneChris Electric Heli Talk 2551 Jun 17, 2008 08:46 AM
FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. Etonic Aircraft - Electric - Airplanes (FS/W) 45 Jan 10, 2004 07:07 PM
Four red 1400SCR's and two 75mah 7 cell packs Lance Aircraft - Electric - Airplanes (FS/W) 1 May 20, 2002 01:55 PM
