Old Sep 07, 2010, 01:16 AM
dougbo is offline
Find More Posts by dougbo
Proverbs 12:15
dougbo's Avatar
USA, WA, Richland
Joined Nov 2009
stretch vibration
I think the tail belt tension is ok: not ringing in the boom but not Protos' tight.
Next thing to fix is the gear mesh. I think the one sided tight mesh is one of the problems.
I'll get some 620 boom supports coming in the next parts order.
Thanks all,
Doug B.
dougbo is offline Find More Posts by dougbo
Old Sep 07, 2010, 01:42 AM
Cyclick is offline
Find More Posts by Cyclick
Joined Dec 2007
Originally Posted by rp181 View Post
I may want to get a Swift 620SE in the future. Would it be feasible to carry 10S 5000mah, or 6000mah, with the 620 10S power package, flybarless? What kind of flight times would I get with a low head speed? Most aggressive action would be FFF.
I use the Century 650 motor with their 85HV ESC using 10S/5000/30C packs on my 620SE - my favorite heli of all time!!
I find its' stock CNC rotor head with the 4mm flybar system flies great, better then some FBL systems I have flown.
Cyclick is offline Find More Posts by Cyclick
Old Sep 07, 2010, 02:31 AM
Gadget01 is offline
Find More Posts by Gadget01
mad heli scientist
Gadget01's Avatar
United States, OK, Oklahoma City
Joined Dec 2005
Ok. I put them on, only to have them pop off, need some bigger screws!
They are only going to be as good as the weakest link, and if the ends are sketchy, consider replacing them with 3mm ball links. Use JB Weld to install about a 1" section of 3mm threaded rod into the ends of the CF tubing, then wrap the ends in nylon thread with CA to help prevent splitting for extra credit.
Alternatively, I found the boom supports for the T-Rex 600 to be a good replacement. They make ends in assorted colors of anodized aluminum and the CF tubing is slightly larger in diameter.
Gadget01 is offline Find More Posts by Gadget01
Old Sep 07, 2010, 06:07 AM
rp181 is offline
Find More Posts by rp181
Joined Mar 2010
Cyclick: What kind of flight times do you get?
rp181 is offline Find More Posts by rp181
Old Sep 07, 2010, 08:02 AM
Greybird is offline
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
Well, I went to fly my 6S full bling Swift again today. HORRIBLE viration. Turns out the swash developed play. Not between the ball and mainshaft, or between the ball and white nylon. It is in the upper part that spins, betweent the metal that the ball links attach to, and the nylon insert. Hmm... I put a 3mm grub screw in the extra hole in the swash and ALL the play is gone. I wonder if I can just leave it like that? I flew out the 2 packs without issue. I will order a new one, but what does everyone think? Really nothing to fail if you look at it closely. Opinions?
Greybird is offline Find More Posts by Greybird
Old Sep 07, 2010, 08:07 AM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
I wonder if that inner part is changeable between the plastic outer swash version and this one? The inner part looks the same.
Old Sep 07, 2010, 11:08 AM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Since it is a drop-in replacement and should not alter the geometry of your head setup, I would throw a new one on.
cactus is offline Find More Posts by cactus
dougbo is offline
Proverbs 12:15
dougbo's Avatar
USA, WA, Richland
Joined Nov 2009
Where did you see the vibration?
Doug B.
Old Sep 07, 2010, 11:17 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
I discovered something interesting on my pre-flight of the Swift before flying this past Saturday. I recalled horrible pirouette response after flying it the last time so I spent some extra time going over the tail mechanics. I usually disconnect the tail control rod from the servo horn and move by hand to check for any problems, binding, etc... It was very stiff in spots and as I looked at the rod guide on the boom it had worked its way up to the servo. When I moved it back to the middle it smoothed it out. Two flights on Saturday confirmed it was much smoother turning and the tail was holding while doing stationary back-flips. Other than that my Swift is so trouble-free and gets flown every-time I go the the club field. My new 250 is proving much more difficult in getting a solid tail setup dialed in!
Old Sep 07, 2010, 11:54 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
I went with 100% metal.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Sep 07, 2010, 07:37 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
This is the 100% metal one.
Old Sep 07, 2010, 07:45 PM
Greybird is offline
Greybird's Avatar
Florida
Joined Nov 2004
Doug B.
Entire heli shaking. Not vibrating.
Old Sep 07, 2010, 08:37 PM
osterizer is offline
Find More Posts by osterizer
Psurvival = 1/ThArrival
osterizer's Avatar
Maryland, USA
Joined Jan 2007
600 to 620 blades will carry a 5 Ah pack with no problem at all. How they would fit in the 620's frame I couldn't tell you, but my Logo 600 will do 12 minutes of mild flying on 600s at 2K RPM, putting 70-75% back in.
Something I'd suggest for anyone stretching the Swift 16, by the way, is a Raven hub and grips for the tail, with 88-92mm blades. Even on 550s, the stock blades are too soft for the tail, and the longer blades will torque one of the screw heads off sooner or later, without question. Just a note....
Greybird, JMO, but I'd hesitate to fly a big heli with a swash that wanted to come apart, especially if I'd already made up my mind to replace it.
osterizer is offline Find More Posts by osterizer
Old Sep 07, 2010, 11:30 PM
dougbo is offline
Proverbs 12:15
dougbo's Avatar
USA, WA, Richland
Joined Nov 2009
Wow. How many flights on that swash?
Doug B.
Old Sep 07, 2010, 11:41 PM
dougbo is offline
Proverbs 12:15
dougbo's Avatar
USA, WA, Richland
Joined Nov 2009
I'm using the triple bearing tail hub upgrade on my stretch. Not sure if it is the same as the Raven? I also picked up a set of KBDD 84.5mm tail blades. I'm back to running the stock blades until I iron out my vibration problem.
Doug B.
Discussion Tales of Gadget's Swift 16 Gadget01 Large Electric Helis 486 Nov 18, 2010 12:13 AM
Discussion Tales of Everyone's Swift(s) JustPlaneChris Electric Heli Talk 2551 Jun 17, 2008 08:46 AM
FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. Etonic Aircraft - Electric - Airplanes (FS/W) 45 Jan 10, 2004 07:07 PM
Four red 1400SCR's and two 75mah 7 cell packs Lance Aircraft - Electric - Airplanes (FS/W) 1 May 20, 2002 01:55 PM
