Old Mar 07, 2010, 06:46 PM
jonathanC is offline
Find More Posts by jonathanC
jonathanC's Avatar
Calgary, Canada
Joined Jan 2007
Couple of pics of my completed Swift 16. Last thing I did was to spray the windshield black, helps to increase the visibility. Still fiddling with throttle curves, piro rates and expo trying to get the right feel.
Managed a couple of flights today, things are starting to come together.
jc
jonathanC is offline Find More Posts by jonathanC
Old Mar 07, 2010, 07:26 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Nice, coming along well for you. I was thinking about painting my windshield, but then I would not be able to visually check my Rx without removing the canopy....
cactus is offline Find More Posts by cactus
Old Mar 07, 2010, 09:56 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Nice looking blades, jc! What brand are they?
Cactus, what would you need to visually check on your RX?
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Mar 07, 2010, 10:05 PM
cactus is offline
cactus's Avatar
Joined Sep 2001
As a pre-flight check I do make sure the connectors are secure and the lights look good on the Spektrum gear. Not critical, but never hurts to be safe.
Head Setup: I did find several of the links needed to be re-sized and that made the fly-bar pivot easier than it did before. I discovered that my fly-bar arms where not level to begin with so I will need to see if there is enough play in the flat spot for the setscrew to rotate it so they are inline.
Old Mar 08, 2010, 05:52 AM
simages is offline
Find More Posts by simages
AMA# SIMAGES
simages's Avatar
United States, NY, Cold Spring
Joined Dec 2006
jc
Great feeling when it comes together, looking good! And like Chris said; Nice looking blades, jc! What brand are they? We'd like to know...
simages is offline Find More Posts by simages
Latest blog entry: Strega MK2 "P-51 Mustang" by...
Old Mar 08, 2010, 02:02 PM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
Just a cautionary heads-up JonathanC. A few years ago, a friend tried painting the plastic windscreens on some of his nitro birds. Unfortunatley, he found that when left in the hot sun, they would warp.
rotoraddict is offline Find More Posts by rotoraddict
Old Mar 08, 2010, 07:48 PM
jonathanC's Avatar
Calgary, Canada
Joined Jan 2007
Thanks for the comments. The blades are generic from HobbyCity.
http://www.hobbycity.com/hobbycity/s...e_%28type_2%29
They are very stiff and come in at ~ 107g, they work well and seem to auto all day, but I don't have much experience with blades of this size. The decals you see on the top ( and bottom ) are cut from a large "trim sheet" from the LHS.
jc
Old Mar 08, 2010, 07:52 PM
osterizer is offline
Find More Posts by osterizer
Psurvival = 1/ThArrival
osterizer's Avatar
Maryland, USA
Joined Jan 2007
At 107g I bet they would auto for sure .
The Mini Titan's faux CF windscreen is another good one for sunny days- melts on your heli, not in your hand.....
osterizer is offline Find More Posts by osterizer
Old Mar 08, 2010, 09:08 PM
jonathanC's Avatar
Calgary, Canada
Joined Jan 2007
Anybody have any recommendations for a heli tach ? My little GloBee Intellitach works for my 450 size heli fine but doesn't work for the Swift, the readings are all over the place.
jc
Old Mar 08, 2010, 09:34 PM
osterizer's Avatar
Maryland, USA
Joined Jan 2007
You're not trying it under house lighting, are you? Mine works fine in sunlight. 60 Hz house lighting- especially fluorescent -drives it batty.
My favorite tach is the Eagletree microLogger .
Old Mar 08, 2010, 10:40 PM
jonathanC's Avatar
Calgary, Canada
Joined Jan 2007
Thanks osterizer I'll check out the EagleTree.
And no I wasn't indoors. I tried a few times both outside in bright sunlight. I'll haven't change the battery yet so I'll give that a go when the sun comes back .
jc
Old Mar 08, 2010, 11:26 PM
Cyclick is offline
Find More Posts by Cyclick
Joined Dec 2007
jc
I have this Model Avionics unit optical tach - works great.
http://www.ronlund.com/Merchant2/mer...Code=MAV804260
Works on all helis - electric, nitor, gassers
Reads up to 3100 rpm.
Cyclick is offline Find More Posts by Cyclick
Old Mar 10, 2010, 07:00 AM
jamesppp is offline
Find More Posts by jamesppp
jamesppp's Avatar
Georgia, USA
I have the same tach as cyclic. Works great and gives repeatable results.
MA Sky Tach 3100 rpm max. There is an older version with a lower max rpm rating
jamesppp is offline Find More Posts by jamesppp
Old Mar 10, 2010, 08:15 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
I have an Eagletree as well. I just started using the Brush-less RPM Sensor to calculate HS.
Old Mar 10, 2010, 08:32 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Repeatable results - closely (within 10%) of CC Governor settings.
Rick
Rickn816 is offline Find More Posts by Rickn816
Discussion Tales of Gadget's Swift 16 Gadget01 Large Electric Helis 486 Nov 18, 2010 12:13 AM
Discussion Tales of Everyone's Swift(s) JustPlaneChris Electric Heli Talk 2551 Jun 17, 2008 08:46 AM
FS- Super Bright LED's - Part II - Only $1 each or less! One time offer. Etonic Aircraft - Electric - Airplanes (FS/W) 45 Jan 10, 2004 07:07 PM
Four red 1400SCR's and two 75mah 7 cell packs Lance Aircraft - Electric - Airplanes (FS/W) 1 May 20, 2002 01:55 PM
