Old Jun 30, 2008, 01:11 AM
Sensiblenick is offline
Find More Posts by Sensiblenick
Tearing the Skies a new one...
Sensiblenick's Avatar
Sweden: Ystad
I searched and searched for thin servos... Thanks Adam for that tip: I gave up when I failed to find anything thinner than 10mm
I'd much rather have the servos in the wings... Question is whether I'm being a tad pathetic worrying about the drag. I can make the links tiny and waif-like...
Better to have servos in wings than to have to fiddle with linkages each time you put the wings on.. right?
The servo covers can be moulded... and the recesses can be crack/gap-free...
19 bucks a pop for the 47's? that's about 4 quid with today's exchange rates
Sam: I thought about custom torque-rods... but each time you come to it you need to fit it though the faired-in wing-root and then couple it. Hassle.. especially when the components are small, and especially when the emphasis on this thing is to have an easy-to assemble slope toy.... having little linkages seems to negate that goal, and It'd also load the Kevlar hinges in a weird way.
Typing thought processes out loud seems to make these things easier .... I now know where I Stand
20oz/inch comes out at about 1.4kg/cm by my reckoning... That's MORE than enough welly for this puppy.
Sensiblenick is offline Find More Posts by Sensiblenick
Old Jun 30, 2008, 02:05 AM
samotage is offline
Find More Posts by samotage
find me @samotage
samotage's Avatar
Melbourne Australia
Joined Jul 2005
icicic. Pluggable wings. No good for torque rods. IMO a good blister will be your friend. Praps some of those Airtronics ones?
samotage is offline Find More Posts by samotage
Old Jun 30, 2008, 02:37 AM
Sweden: Ystad
Blister? Is that the official word for the aerodynamic fairings?...
Mr Editor and Peter W have both chimed in to say that the D4.7's are too small for this job, and that the D60's would be a better choice.... I'll get on to modelling one to see if it fits
Old Jun 30, 2008, 02:40 AM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Something as clean as that - it'd be a shame to have servo blisters or control horns out in the air.
ajroahkni is offline Find More Posts by ajroahkni
Old Jun 30, 2008, 03:26 AM
slopetrashuk is offline
Find More Posts by slopetrashuk
You must die! I alone am best.
slopetrashuk's Avatar
The Naughty Corner..Find me tweeting @slopetrashuk
Joined Sep 2003
Nick - These servos are seriously very good even though they're distributed by Ripmax!
The resolution is fantastic for an analouge and the speeds not bad on 4.8v.
I was always wary of the servo arms (being thin and skinny) but every linkage needs a weak link right and I've never had one fail at all under any circumstances.
I have used them on my small electric pylon models in the past and they are readily available over here.
Andy
http://www.phoenixmp.com/acatalog/info_SR010.html
http://www.phoenixmp.com/acatalog/info_SR005.html
slopetrashuk is offline Find More Posts by slopetrashuk
Old Jun 30, 2008, 03:27 AM
Sweden: Ystad
It'd also be a shame to design in a sloppy linkage that needs to be fiddled with each time you slot the wings in...
The surface of the wing would only be interrupted by a very narrow channel for the linkage rod... not to accommodate the body of the servo.... Not all that bad really?
Edit: Slopetrash: Those servos have the exact same stats and shape as the D4.7 and D60 that have been suggested by Adam.... I wonder if they're just re-labelled by each company that sells them?
It is the larger of the two we're now trying to fit in. (and it's about 35% cheaper if bought in the USA)
Old Jun 30, 2008, 04:10 AM
biber is offline
Find More Posts by biber
Needs brain lubrication
biber's Avatar
Aachen, very western Germany
Joined Dec 2004
D47 are not suitable, D60 are close to the perfect servo.
At least that's what most F5D folks found to be true.
We even have sanded D60s to fit the corners into wings.
I would at least try to get an RDS solution builtin, but certainly not on the first prototype.
The Akamodell München, however, has managed to even build Bathlet F5D wings with D47 and RDS fully installed before closing the molds.
Lots of things are possible if you really want it.
biber
biber is offline Find More Posts by biber
Old Jun 30, 2008, 05:45 AM
Sweden: Ystad
Well... Either way: RDS or servo in wing requires a servo hatch... So best to get on with it and whack one in.
D60's.... message received lads.... Thanks
Old Jul 02, 2008, 12:47 PM
Sweden: Ystad
Well, We've nearly got to a shape that I'm happy with on the fus.. and the tail has atleast got a side profile.
I had the settigns low, so the fus looks more angular than it will actually be..
There are a few questions over how to optimise the machining process so that it takes less than 6 hours per mould..
Might start on machining this week some time.
Servos are to be housed near the root with the linkages top-side. Servo bay flanges will countour the wing's surface, and the servo covers will be correctly coutoured to the wing's surface So We'll only be missing lift from the 5mm slice that sheilds the linkages...
It's going to be fun.
Old Jul 02, 2008, 01:13 PM
FSD is offline
FSD
Find More Posts by FSD
FSD
Definite Flight Risk
FSD's Avatar
United States, CA, Crestline
Joined Apr 2008
Very slick! I like it.
-P
FSD is offline Find More Posts by FSD
Latest blog entry: Flow 3.5 Maiden With Aeros
Old Jul 02, 2008, 06:19 PM
chetosmachine is offline
Find More Posts by chetosmachine
chetosmachine's Avatar
Madrid, Spain
Joined Sep 2004
Will it be a Chuck certified product?
chetosmachine is offline Find More Posts by chetosmachine
Old Jul 03, 2008, 02:52 AM
Sweden: Ystad
D60's it is
Following the advice of many helpful people, I've Just ordered 4 M60's from Dymond ... It'll be interesting to see how punitive the import Tax will be.
Dymond's Price $(USD)20 ~ 120Kronor
Ripmax Price £(GBP)16 ~ 190Kronor
That's a 280Kr Saving on 4 servos.. About 20 quid or 40 Dollars...
I wonder what postage and import tax will be... I'll update later to let you know!
Old Jul 03, 2008, 03:00 AM
Sweden: Ystad
Chuck does not certify products. If they continue to exist it can simply be assumed that they do not offend him.
Old Jul 03, 2008, 04:55 AM
zero-zero is offline
Find More Posts by zero-zero
Horned one
zero-zero's Avatar
Vigo, Spain
Joined Sep 2004
That wavy TE on the fin is not deliberate.. and will be strightened out =)
Pity, I liked it a lot.
zero-zero is offline Find More Posts by zero-zero
Old Jul 03, 2008, 05:09 AM
Sweden: Ystad
Anyone else? I'm open to persuasion...
Contest 2008 SSDC - Summer Sloper Design Contest jludwick Slope 40 Oct 23, 2008 09:48 AM
