Well, Jonas and I have now found time to get ourselves together and discuss mould making. We've now got it sorted. Pictures to follow sometime...
I've now cut the matieral that the moulds will be machined from. A lot of time on the bandsaw has yeilded a decent pile of aluminium powder and four slabs measuring 20x225x585mm
Bits that need thought
At the fattest point that the servo could be fitted into the wing, I have precious little room. A 30x30mm servo box has a corner that gives only 9mm between
outer surfaces of the wing. It rather looks as though there's no room in the wings for the servos. Even the belovéd HS 55's are too fat.
At the thickest area of the Elevons, the Elevon is 3mm thick. I may be able to shove a torque-rod in there and put the servos inside the fus leaving lots of scope for many different servo installations and room for balast tubes in the wing roots.
Right now I'm not to interested in squezing RDS in there as the wing will STILL be too thin for a servo... the fun never stops.
At least this means that there'll be no obvious servo-horn outputs on the wing... I was worried abot those messing up the sufaces and adding unwanted drag.
I think I've got it sorted.. but I'm not 100% sure at the moment.
How come there are so few entries this year? has everyone los the will to have a laugh?
