Old Jul 16, 2008, 02:46 PM
Sensiblenick is offline
Find More Posts by Sensiblenick
Tearing the Skies a new one...
Sensiblenick's Avatar
Sweden: Ystad
5hrs 53mins
Argh... you just fried my brain Jon.
This effectively cuts out the middle-process of making a plug.
Plugs are usually made because it is far easier to make the actual shape that you want, and then take a mould from it. Alternatively, making a female mould can take a HUGE amount of material if you're making - say - a mould for a car body. In that kind of case a male plug is the best option so that a female mould can be taken from it.
In this case however the moulds are relatively small, and I have scrap 7075-T6 (used to be called "aircraft grade") aluminium to hand that can be used... and this way I get moulds that are far more durable than fibreglass ones, and are "perfect" from the very start instead of potentially building in error from a mistake in the plug.
Sensiblenick is offline Find More Posts by Sensiblenick
Old Jul 16, 2008, 03:29 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Those reasons are all very good, but what does Jon do when Jon drops the lower left wing mold off the table and into the leg of the chair? He cries and cries like a TV preacher is what he does. At least with a male plug it would relatively easy to make another female (I know, stating the obvious). But I do really like the "perfectness" of the female aluminium molds.
Jon
who now wishes his best buddy (tooling engineer with Boeing) was "into" RC planes...
jfinch is offline Find More Posts by jfinch
Old Jul 16, 2008, 03:45 PM
Sweden: Ystad
All done for tonight...
You'll be wanting pictures then?
10:45pm. Time to go home I think.
Old Jul 17, 2008, 01:32 AM
Sweden: Ystad
Recieved an E-mail from Dymond... Servos were shipped on the 7th of this month. I'd missed Andy's mail: it had been filtered as junk
So.. nice and relaxed postage times... hope they get here before monday!
Old Jul 17, 2008, 04:43 AM
Leonardo is offline
Find More Posts by Leonardo
Engine? No, thanks.
Leonardo's Avatar
Firenze (Florence, Florenz, Florencia) Italy
Joined May 2005
too coooooooooooooooooool !!!!!!!!!!!!
5xstars
Leonardo is offline Find More Posts by Leonardo
Old Jul 17, 2008, 09:53 AM
slopetrashuk is offline
Find More Posts by slopetrashuk
You must die! I alone am best.
slopetrashuk's Avatar
The Naughty Corner..Find me tweeting @slopetrashuk
Joined Sep 2003
Gee Nick - I hope it flies OK...
slopetrashuk is offline Find More Posts by slopetrashuk
Old Jul 17, 2008, 10:13 AM
Sweden: Ystad
Yeah.. that's the rub with taking the time and effort to scratch-build things.. .. but with Peter W's input, I'm pretty sure it'll be fine
So.. how's your kit-Jart doing Andy?
EDIT: Nick bites his tongue as he realises that his own Jart is yet to fly....
Old Jul 17, 2008, 10:23 AM
Joined Sep 2003
It rips...
Old Jul 17, 2008, 11:07 AM
winchdoc is online now
Find More Posts by winchdoc
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
Nice Work!
.....(stumbling around the inter-web-nets)...
What's this thread? Oh, That guy from Sweden, Hasn't he finished that big Jarty-thing yet? What's this? CNC cut molds!?!?!
ZOMGWTFBBQ!!!
I'd be curious to know about your finish pass stepovers and depth of cut.
I may have to pick your brains if there are any good parts left after this project.
WinchDoc
Who likes shiny curvy surfaces....
winchdoc is online now Find More Posts by winchdoc
Old Jul 17, 2008, 11:11 AM
Sweden: Ystad
Step-over on the wings was 0.3mm using a 4mm diameter ball-end.
Some of the tailplane was done using a 0.2mm step-over... depth of cut I'm not sure about... Will have to find out from Jonas...
Jonas.. are you reading this?
Ellie's a hundred Km away today, and I'm sat once more polishing.. this time the Canopy mould =)
Old Jul 17, 2008, 11:40 AM
Leonardo is offline
Engine? No, thanks.
Leonardo's Avatar
Joined May 2005
That's one of the coolest thing I've seen since my.... "first time I saw it".
PS: don't forget to put a generous amount of mold releasing wax, this time...
Cheers
Marco
Old Jul 17, 2008, 11:55 AM
JonasC is offline
Find More Posts by JonasC
IforOneCareLessForThem
JonasC's Avatar
Sweden
Joined Jun 2008
ia, just sat down to see your mirrorsurface polishing on that last part. No photos, so still rubbing it?
Anyways, the scallopheight and thus the stepover can be controlled by defining either (scallopheight or stepover). So the finnishing on theese parts where mostly specified with a scallopheight of 0.003-0.005mm.In some cases the stepover was defined to be for example 0.3 with a 4mm Ballend mill, which corresponds to roughly 0.0056mm scallopheight.
( Formula, if interested)
Depth of cut for the finnishing passes are harder to define explicitly, since it depends on the previous tooling. Generally i leave 0.1 mm for the finnish, but if the previous tool is to big to fit everywhere that might leave excess material. Same if you have a flat end mill in a curved area.
Hope that helps, JC
JonasC is offline Find More Posts by JonasC
Old Jul 17, 2008, 12:01 PM
Sweden: Ystad
Ladies and gents, This bloke ^^^^ is the genius behind the Programming.
Welcome to RCG jonas
Photos are... a few minutes away
Old Jul 17, 2008, 12:18 PM
Sweden: Ystad
Here we are...
Last bit of machining 'til we down tools and head off on holiday. the rest are all small fast parts, and we'll be knocking them out next month.
I'm off to the UK for 3 weeks on monday... no way I'm hauling 40kg of aluminium over there for a jaunt.
Old Jul 17, 2008, 12:34 PM
biber is offline
Find More Posts by biber
Needs brain lubrication
biber's Avatar
Aachen, very western Germany
Joined Dec 2004
Jonas, if you have the sparetime, I'd take a set of them, too.
Serious, cool stuff you're doing there.
Keep up the muffin... erm... good work!
biber
biber is offline Find More Posts by biber
Contest 2008 SSDC - Summer Sloper Design Contest jludwick Slope 40 Oct 23, 2008 09:48 AM
