Old Jun 16, 2008, 07:19 PM
Flying freak is offline
Find More Posts by Flying freak
Joined Jun 2006
ABC or AAC?
If you were to rebuild an engine and had the choice what woudl you take and why?
Steven
(25$ more for the aac)
Flying freak is offline Find More Posts by Flying freak
Old Jun 16, 2008, 07:35 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
It depends on what I was going to use that motor for.
AAC is lighter, which can be a bonus if you need the ultimate power to weight ratio (most Saitos are AAC) but ABC provides a greater measure of protection against lean runs or poor cowling.
Tell us what the engine is and what you're planning on using it for.
XJet is offline Find More Posts by XJet
Old Jun 16, 2008, 07:38 PM
Jeffery is offline
Find More Posts by Jeffery
And You're Not
Timbuktu, Mali (Happy?)
Joined Oct 2002
Jett claims that the AAC sleeve is less prone to deforming at the top of the sleeve. From the Jett FAQ
Question:
Is an AAC engine more likely to wear than an ABC engine?
Answer:
Eight years ago I would have probably said yes. That is the conventional wisdom. In fact, I read not long ago in a racing forum a comment by a prominent racer stating just that. The opposite is true. That is why I make my premium engines with AAC liners. Do you remember how nice it was to just change out a piston ring every so often? Well, using an AAC engines is very much the same. We get engines that look like they have been through the Great War, and when torn down and measured, we find the AAC liner is like new. In most cases, all we have to do is fit you a new piston and you are right back to "good as new". It saves you about 1/2 the cost of rebuilding.
The secret of AAC lies in the increased heat stability of the aluminum vs. the brass. With chrome on the liner you do not get wear in either case. What you get is warping of the top part of the brass liner due to heat and stress. The brass, when overheated, tends to "bell mouth" and loose its taper. The aluminum does not do that. About the only thing that will hurt the AAC liners is FOD (foreign object damage). Keep your engine and runway clean!
Jeffery is offline Find More Posts by Jeffery
Old Jun 16, 2008, 08:56 PM
Joined Jun 2006
Well its a jett 50 fire going on a small q500 type plane would like to get 130-140mph out of it
Steven
Old Jun 17, 2008, 12:52 AM
downunder is online now
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
Ummmm...same answer as I just gave on RCU .
AAC all the way. I have the Enya 60X which is AAC and they just never seem to wear out. The reasons given by Jett were found by George Aldrich (from memory). Whatever...go for the AAC.
downunder is online now Find More Posts by downunder
Old Jun 17, 2008, 11:50 AM
Konrad is offline
Find More Posts by Konrad
Everett Wa.
Joined Jun 2001
How does ABC give better protection? It has a greater thermal mass?
Other than costs I think that AAC is the way to go. There is a higher possibility of plating failures as there is the zinc strike.
Konrad
Konrad is offline Find More Posts by Konrad
Old Jun 18, 2008, 01:13 AM
downunder's Avatar
Joined Sep 2003
One apparent difference with AAC (judging by the Enya 60X) is that they don't have any pinch when new. There's certainly never been any reports of peeling with them and everyone says they last forever. I know mine has had a lot of use and it's still as good as new. Strangely, even though I use 20% all castor there's never been even a hint of carbon on the piston crown or in the exhaust.
Old Jun 18, 2008, 01:31 AM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
You are correct.. an AAC won't have a (very) tapered bore because the expansion coefficients of the piston and the bore will be pretty much the same -- whereas in an ABC the bore will expand faster than the piston.
That means the cold clearances are not much different to the hot clearances.
A *good* AAC job will last forever (excluding the effects of foreign object damage) and Saitos are a good example of this.
Also, by chroming straight onto the bore, the heat of combustion can be conducted more effectively to the outside of the cylinder and therefore the engine will run cooler.
AAC engines are often quite a bit lighter than ABC -- one only has to compare the weight of the now discontinued Saito 80 (ABC) with the newer Saito 82 (AAC) to see that.
It's interesting to note that most of the cheap Chinese gas engines on the market today are AAC.
Old Jun 18, 2008, 06:46 AM
Artisan is offline
Find More Posts by Artisan
NM2K
Ringgold, GA, USA
Joined Jan 2006
I'm with Downunder on this point. AAC is superior for those wanting the best in high performance. I'm talking about unringed two-stroke engines, not anything else.
Ed Cregger
Artisan is offline Find More Posts by Artisan
Old Jun 18, 2008, 05:11 PM
Joined Jun 2006
so aac it is ,
Thanx for the help!
Steven
