Ryan,
This is looking good. For a distraction, some photos for you next project: http://www.flickr.com/photos/jsfrenc...7613676328580/ John |
Thanks very much for the link. You picked it correctly from my partially done plans. I hadn't seen a model of this plane done before until 2 nights ago someone posted a link to this guy the other night in the 257" B36 build thread in the electric giants section.
http://www.carlb-rcplanes.com/boeing307pg1.html I'm taking a bit of distraction now and finishing my Cub and then I'll get back to this. Trying to get this done on time at my 1 hour a night pace has started feeling a bit too much like work and I'm at the point right now where I could finish it by the deadline but I'd be really rushing it and have to leave off several things I would like to do such as gear doors and vacumn forming the cockpit and nose and having some form of cockpit interior. I'm going to cover my Cub and get it flying in the next month and have one winter project completed and then come back to this. |
Nice work.
Is it best to have the ESCs close to the battery or close to the motors? For multi-motors, I got one of these Battery Eliminators . Do you have a solution to the problem of getting reliable power/voltage for servos from the ESCs? I was originally intending to use 2 diodes so that I could connect both BECs from the two ESCs to get the full power to 5 servos. But I was advised not to try that because the BEC output from most ESCs is not reliable enough to cope with models larger than 25oz or so. cheers Nick |
The correct way to long leads between motor and ESC. There is a good thread in general formum about it.
http://www.rcgroups.com/forums/showthread.php?t=952523 There are a bunch of others in the power systems forums and there is a good article out there somewhere by Astro Bob regarding this. It has to do with the impedence from the on-off switching that operates the ESC and the impedence of the motor being able to dampen the spikes on that end while capacitors are needed to dampen them on the battery side. Neither of my ESC's have BEC's in them. I have a UBEC to use that will be upstream of both ESC's in the wiring. There will be enough servos in this thing that it wouldn't have been a good idea to use most ESC BEC's anyways. They don't have overcurrent protections built in either so I will be adding some auto fuses to them as well. |
| Thread Tools | |
| Build Log BlueCor/Fanfold Sorta Grumman Goose Design and Build | Vyceroy | Foamies (Scratchbuilt) | 656 | Dec 16, 2008 11:24 PM |
| "Design & Build" "Fiberglass Molds" | Gunny | Aircraft - Sailplanes (FS/W) | 0 | Apr 13, 2004 11:21 AM |
| Design & build of Pencam-class photo platform | Karl Bē | Aerial Photography | 74 | Aug 06, 2003 02:11 PM |
| My first Design Scratch Build Project | Heather | Electric Plane Talk | 20 | Jul 22, 2001 11:03 AM |
