georgetown ontario
Joined Jul 2001
airwars "infra-red combat system for planes"
has anybody seen or used CSM's combat system on there plane, its an infra-red combat system.
if so does it work very well in sun light or work at all. http://www.rcmodels.org/csm/ |
Yes we've tried it.
Sunlight is completely irrelevant to the sysstem and it triggers and receives very well. I posted a bunch of stuff about it when it was new several months ago which has probably gone from the archives now. The system installs very easily and adds about an ounce to a Zagi (the chosen airframe for our tests). The system consists of a small infrared gun, a processing unit and a small infra-red receptor. One of your servos plugs into your receiver through this unit and the unit takes it's power from the flightpack through the receiver. If you set the unit to continously fire you have a better chance of getting a hit but you can also set it to fire a burst when operated on a trigger channel (gear or rudder in the case of the zagi). Here is what it looks like when fitted to a Zagi pod canopy. http://albums.photopoint.com/j/ViewP...p=35342891&f=0 In use it is actually very difficult to manouver into a position to get a hit on your opponent, specially if there are two of you, as we found it too easy to evade. Ground testing showed that you had to be behind your opponent and close to something like 5-10metres to get into his target cone at the back of the model and register a hit. When your opponent suffers a hit his aileron servo will operate causing a wing-rocking motion for a predetermined time. This is optional and can be set via the software which is available as an extra. IMHO the system needs either more combatants or better pilots (or maybe we are just too good at evading). The game would really come into it's own with six or more combatants and the laptop down at the field to download the scores - the coded infra-red "bullets" which shoot down your opponent are identifiable for each pilot so that kills can be credited. Without the laptop/software kills are indicated by a flashing red led on the unit. The unit is also usable in ground targets. We will certainly be trying it again. hth Brian [This message has been edited by leccyflyer (edited 08-01-2001).] |
| Thread Tools | |
| airwars "infra-red combat system for planes" | Tree_Magnet | Power Systems | 15 | Jan 08, 2008 09:41 PM |
| Cheap, light power system for planes around 8 oz. | Megowcoupe | Power Systems | 35 | Jun 18, 2003 09:19 AM |
| Yippee! New 3Ch system for sub 1 oz planes | dsan1 | Indoor and Micro Models | 111 | Feb 15, 2002 05:09 PM |
| Infra-Red Thermometer for Helis | rscamp | Electric Heli Talk | 7 | Jan 08, 2002 06:11 AM |
| Infra red transmitter and receiver for micro size aircraft | Ron MIller | Power Systems | 2 | May 28, 2001 09:51 AM |
