Old Jun 15, 2008, 07:51 AM
Howemd is offline
Find More Posts by Howemd
Howemd's Avatar
United States, VA, Yorktown
Joined Sep 2005
4 Wing Crow, how to program flaps to a slider on the 9C
Hello y'all,
I am trying to fine tune my ultra stick 'crow' and would like to not only be able to just hit a switch and have 'crow' activated, but to also be able to use a Vr slide to just lower flaps.
-- Percentages have been made for easy mental math --
Currently I have figured out how to program all four wing control surfaces to follow each other in normal flight (ailerons 100% deflection and flaps following at 50% deflection) with Crow linked to switch H.
Is there a way to also program just the flap down deflection to be controlled with a Vr switch not activating 'Crow'.
Thanks in advance
Howemd is offline Find More Posts by Howemd
Old Jun 15, 2008, 10:49 AM
flyfalcons is offline
Find More Posts by flyfalcons
flyfalcons's Avatar
Bonney Lake, WA
Joined Jan 2002
Hey Howemd, try a pmix Vr - Flap channel (whatever channel that is, I think it's 6?). Set the mix to switch H for when you are in the normal flight switch position, that way it won't interfere with your crow mixing. Let us know how that goes.
flyfalcons is offline Find More Posts by flyfalcons
Article How to Program Elevons on the SkySport 6VA Dave Tatosian Electric Plane Talk 1 Aug 17, 2012 07:59 PM
This is how to put throttle on trainer switch on futaba 9C tic High Performance 23 Jan 03, 2005 05:07 PM
How do program reverse aileron differential on Fut 9C? Magna Radios 4 Oct 18, 2004 07:58 PM
How and what is best way of reverse aileron diff on Fut 9c? Magna Electric Sailplanes 4 Sep 28, 2004 11:09 AM
Anyone know how to program elevon mix on a standard Field Force 7 Mike Smart Electric Plane Talk 0 Apr 21, 2001 01:48 PM
