Old Jun 14, 2008, 05:33 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Saito 4-Stroke Valve/Tappet Gap Adjustment
Greetings All,
The Saito small to medium (FA-30 to FA-125) manual indicates valve/tappet gap adjustment in a range of .03 mm to .10 min (.002" - .004"). I am wondering what experience you all have had with valve/tappet gap settings. Is there an advantage to a wider gap or more narrow gap?
Thanks!
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jun 14, 2008, 06:43 PM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Originally Posted by EJWash1
Greetings All,
Thanks!
EJWash
EJW - Edge toward the narrower gap.
Wider gaps allow the valve to remain on the seat longer thus cooling it. This is more practical for gasoline fired motors and allows for some clearance deviation due to expansion of parts due to heat. In a glow motor, combustion temps are lower, expansion is less of an issue, and importantly the rocker/valve contact points are less likely to get hammered and peened with the tighter clearance. The designers factor in clearances for optimum valve timing and I'm guessing they'd go for the tighter clearances too plus this allows for some wear in of the parts but still stay in specs.
gnats82 is offline Find More Posts by gnats82
Old Jun 15, 2008, 09:19 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
Open duration can effect your over all timing. By staying within the specs the engine will operate best. To tight and perfromance drops off, to lose, and perfromance drops off plus other things happen like push rods get hammered. So stay with in the go no go range given.
Cheers,
Chip
Chip01 is offline Find More Posts by Chip01
Old Jun 15, 2008, 12:38 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Thanks Chip,
I guess I should have made it clear that I was looking for experience *within* the engine manufacturerís (Saito) valve/tappet adjustment range of .03 mm to .10 min (.002" - .004").
We have some very talented and knowledgeable modelers on this forum that have been more than willing to share their experience with us.I think itís great that we have them at our disposal.
I realize that we are not talking about a huge spread here. Only a difference of .07 mm.I just measured a single sheet of 20lb. copy paper and it is .10 mm thick, the same as the top end of the valve/tappet adjustment range. But, we are talking about a very small engine here.
I just read the OS 91 manual, and OS prints a valve/tappet adjustment range of .04 mm to .10 min (.0015" - .004"). OS does go into greater detail on how to evaluate if valve/tappet adjustment is necessary depending on the present gap. The OS adjustment procedure has you readjust the gap setting to .04 mm. Iíll go with .04 on the Saito, since this is within the allowable range, and see what the results are.
EJWash
Discussion OS .91 4 stroke valve adjustment GhostRider32 Engines 6 Apr 26, 2015 07:19 PM
OS or Saito 4-stroke??? tumbleweed Engines 25 Mar 06, 2005 09:41 AM
Saito 4 stroke 300 twin Terry3582 Engines 4 Jan 08, 2005 06:02 AM
FS, 2 Saito 4 stroke twins, 5 cyl radial. cbxryder Aircraft - Fuel - Airplanes (FS/W) 9 Sep 29, 2004 07:24 PM
Ace Cloud Dancer with Retracts and saito 4 stroke for sale. Steve H. Aircraft - Fuel - Airplanes (FS/W) 1 Feb 17, 2003 12:04 AM
