Old Jan 24, 2003, 05:33 AM
David Smith is offline
Find More Posts by David Smith
David Smith's Avatar
United Kingdom, England, Standlake
Joined Jan 2003
Sig 2m Riser, what motor?
I have got half way thorugh building a Sig Riser (the 2 metre version) and decided I don't want to bother wiht the bungee any more (not my first sailplane!) Been thinking of stepping into electrics, so would like to electrify this one, what is the best set up? I need something cheap, light and reliable (of course!
David Smith is offline Find More Posts by David Smith
Old Jan 24, 2003, 11:27 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Endoplasma 16T, 30Amp ESC, MA 3:1 box, Aeronaut 12x9 folder, 8xpractically anything cells.. 800 to 1300 are good for climb and low weight.
You WILL be happy!
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 24, 2003, 11:46 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
I agree on the endo - great little motor for 2m jobs.
Let me know how you like that Riser - I am thinking about it for my next sailplane project. I like that Filip really well also though!?!?!
Old Jan 24, 2003, 11:50 AM
Joined Jan 2003
Thanks, is that a concentric gearbox, because I don't thnk I can fit an offeset one in the nose.
The Riser is a decent enough 'old fashioned' kit - most of the parts are printed on the wood and need cutting out, ony the wing ribs are ready cut.
Old Jan 24, 2003, 11:54 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
I like the MP Jet gearboxes - They are good to about 300 watts or so. Good for what you are doing. They have a 3.33 and a 3.8. Either would be good. Can't beat that for $23 bucks.
http://aircraft-world.com/products.asp?id=39
Old Jan 24, 2003, 12:03 PM
Joined Jan 2003
Thanks, the gear boxes look good, that shop is in Japan, do you know if there anything similar available in Europe?
Quick edit to that - just found them over here!
Old Jan 24, 2003, 12:14 PM
vario is offline
Find More Posts by vario
large member
vario's Avatar
beside the highway market
Joined Jan 2003
endoplasma 4 sure
i have the system that sparky suggested and its great for the money!!!
vario
vario is offline Find More Posts by vario
Old Jan 24, 2003, 12:18 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
I don't, but John Emms from Puffin Models might. He hangs around here a bit.
http://www.puffinmodels.com/
Dave at Aircraft-World is great. Worldwide shipping is only US $2.50 can't beat that.
Janzzon is offline
Find More Posts by Janzzon
Sweden
Joined Apr 2002
They're available in Sweden from www.hab.se
http://www.hab.se/vaxellador.htm (in Swedish)
Both 3.33:1 and 3.8:1 costs 255 SEK (about 28)
/Stefan
Janzzon is offline Find More Posts by Janzzon
Old Jan 24, 2003, 12:28 PM
Joined Jan 2003
Sweden's good, so close it's almost home! Thanks for the link. I'll ask around, they may even be available in Finland!
Old Jan 24, 2003, 12:31 PM
Mauilvr is offline
Find More Posts by Mauilvr
Almost a Pilot
Mauilvr's Avatar
NorCal
Joined Oct 2001
Here's another vote for the Endo with an MPJet 3.8:1 planetary box, 8-CP1300 cells and a 12/9 or a 13/8 prop.
Here in the U.S. you can get the Endo at Tower Hobbies ($19.99) and the rest at Hobby Lobby.
I did get my gearbox from David at Aircraft-World (cheaper, too!) because Hobby Lobby was out of stock.
Mauilvr is offline Find More Posts by Mauilvr
Old Jan 24, 2003, 01:33 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
You can fit the MA gear box into a pointy front end..
Old Jan 24, 2003, 05:37 PM
BEA flyer is offline
Find More Posts by BEA flyer
Concord, MA
Joined Jun 2002
electrifying a Riser
I built one and after trying it on a highstart, I made a pylon to mount a motor over the wing. I flew it with a 400 long can and a 3/1 gearbox, with an 11- 5,5, then with a jeti 30-3, both with 10 cells. It is pretty light, and went straight up with the Jeti and 10-1250 scr's. I have a smaller wing also. It is a pretty nice flying plane and was short money for the kit. I poly-fiberglassed mine too. Ill look for some pictures.
BEA flyer is offline Find More Posts by BEA flyer
Old Jan 24, 2003, 08:12 PM
Concord, MA
Joined Jun 2002
riser with "modular pod"
This is sort of stock. The pod is held on with elastics, just like the wing Pretty retro, huh? The wing is a 66" one from a Sterling Taylorcraft kit with a coiuple extra bays and polyhedral. I have te stock wing too. Weight is over or under 3 lbs, depending on the cells.
Old Jan 24, 2003, 08:16 PM
Concord, MA
Joined Jun 2002
I used 1400 AE's, 1100 HECELLS 10x 2 packs in parallel, and the 1250 SCR's. I have had a lot of trouble with the BEC ESC and the 10 cells with brushed motors. The Jeti motor and non-bec 40 amp gold label ESC perform flawlessly
Sig Wonder what motor and cells Rich Ness Sport Planes 4 Jan 29, 2003 09:46 AM
What motor/gearbox combo do you suggest? Rob Andrew Electric Plane Talk 4 Sep 06, 2001 03:51 AM
What motor, gear, battery config for ElectriCub pipercubman Electric Plane Talk 3 Aug 02, 2001 11:08 PM
What motor is this? David Hogue Electric Plane Talk 3 Jul 22, 2001 12:39 AM
Help!!! Airplane, battery, what motor??? FlyerGirl Electric Plane Talk 4 May 25, 2001 11:36 PM
