Old Jun 14, 2008, 11:30 AM
ray2006 is offline
Find More Posts by ray2006
Joined Jun 2007
Video
F-4J Phantom II
Maiden Flight Of F-4J Phantom II
ray2006 is offline Find More Posts by ray2006
Old Jun 14, 2008, 05:34 PM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
Nice flight. Now what is the size of the stock fan? Is it easy to swap in GWS EDF64 you used? What is the motor shaft size for the stock fan and what is the motor diameter that can fit in the stock fan?
Thanks!
shschon is offline Find More Posts by shschon
Old Jun 14, 2008, 09:48 PM
ray2006 is offline
Joined Jun 2007
Dear Bro,
Tks For Your Reply. The Size Of Stock Fan Is 64mm And Must Fit Motor Shaft 2.3mm. So It Is Easy To Replace By Gws 64mm Fan.
Old Jun 14, 2008, 09:49 PM
ray2006 is offline
Joined Jun 2007
Also For Stock Fan Must Use Inrunner Motor With Dia 20mm.
Old Jun 14, 2008, 10:34 PM
shschon is offline
shschon's Avatar
Joined Aug 2004
How much power did you use as shown in the video? 3cell or 4cell battery how much amp?
Where can I buy one?
Old Jun 15, 2008, 11:42 AM
ray2006 is offline
Joined Jun 2007
FOR MY SETTING IS AFS:
F-4J PHANTOM II RTF VERSION
GWS 64MM EDF
GWS EDF64 MOTOR ADAPTER 3.0MM
CP400/5100 EDF MOTOR
HIFEI ESC-45A-G-S
CYCLONE POWER 11.1V 1,800mAh 20C
FLYING WEIGHT: AROUND 660g
MAX THRUST: AROUND 610g
MAX CURRENT: AROUND 34A
MAY BE YOU CAN CONSIDER WITH F-4J PHANTOM ADVANCE RTF VERSION WHICH ALREADY INCLUDE SERVO, 64MM DUCT FAN , MOTOR & 30A ESC. DETAIL YOU CAN STUDY WITH www.rc-castle.com.
Old Jun 15, 2008, 04:38 PM
shschon is offline
shschon's Avatar
Joined Aug 2004
GWS 64MM EDF
HIFEI ESC-45A-G-S
How does the "Avdanced RTF" included fan, motor,...etc compare to your setup in the video?
F-4 Phantom II for a first timer? aeroplancek Pusher Prop Jet Models 3 Dec 16, 2005 09:58 AM
For Sale Yellow Aircraft F-4 Phantom II - NIB skyhawk Aircraft - Fuel - Airplanes (FS/W) 6 Aug 23, 2005 08:00 PM
Parkflyer F-4 Phantom II Astrix Parkflyers 0 Jun 06, 2005 08:44 PM
Midi F-4 Phantom II construction jet_jer Electric Ducted Fan Jet Talk 34 May 05, 2003 04:58 PM
F-4 Phantom II - First look... Daren Electric Ducted Fan Jet Talk 139 Mar 18, 2002 01:27 PM
