Old Jul 07, 2009, 11:53 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
That usually happens on these setups, I always test the fan for vibration by holding it in a (heavily) gloved hand, this is the most accurate way of feeling vibration and getting the spinner cap positioned just right.
Dont worry about the slight rub, just scrape any material off the fan housing with a new exacto knife, dont sand it you will mess up the housing, just lightly scrape till you have removed the bit of blade material. I have had to do this to pretty much every fan I have assembled and I have built A LOT of these 90mm flyfly upgrades!
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jul 08, 2009, 08:38 AM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
Good to hear.
Back to the build table. I have to review all these build notes.
- Dry fit everything when building battery bay
- Plumb motor wires though channel around fan housing
- Cut down exhaust down to 80mm
- Mount ESC in the breeze
- Use silicon mounting caulk to gap seal ailerons
- Use iron to make finger grips
- MG servo's to take some abuse
- Cut down aileron control horn so it won't snag on grass
Did I miss anything?
Tom
ducatirdr is offline Find More Posts by ducatirdr
Old Jul 15, 2009, 04:49 PM
j6myw is offline
Find More Posts by j6myw
Hampshire UK
Joined Oct 2008
Originally Posted by sparks
I'm not going to hijack, I just want to drop in and let you guys know I have a cockpit upgrade kit available for the Fly Fly Mirage now.
http://www.parkflyerplastics.com
I'll be running a build thread soon and may drop in again to post the link.
Thanks for running this thread, it was very useful in getting my model in the air.
Do u have U/C or do you take off and land with the wing tanks on? oh it looks cool
j6myw is offline Find More Posts by j6myw
Old Jul 15, 2009, 05:33 PM
BrentP is offline
Find More Posts by BrentP
Closed Account
Joined Apr 2008
After mentioning elsewhere I thought $25 was too much for a photo cockpit with no pilots it is refreshing to see that a cast cockpit with pilots and more is priced right.
Hey Sparks, I checked out your site. Cool stuff at very good prices.
I want the larger WW1 engine for my DR1, but too small I think. Is it 1/6 scale.
Thanks.
Brent
BrentP is offline Find More Posts by BrentP
Old Jul 15, 2009, 07:46 PM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
No wheels or gear at all.
however, I do have to use a bungee to get it off the ground. Adding the glass cloth for the finish killed the ROG feature of the tanks.
The angle of attack is slightly nose high while sitting on the tanks so all I do is wait for the rubber to get the model up to speed and it lifts off on its own.
sparks is offline Find More Posts by sparks
Old Jul 15, 2009, 10:39 PM
BrentP is offline
Closed Account
Joined Apr 2008
Sorry for off topic but again-
Sparks is parkflyerplastics larger WW1 Gnome engine 1/6th scale?
Old Jul 16, 2009, 05:23 AM
j6myw is offline
Hampshire UK
Joined Oct 2008
Sparks it looks cool with them wing tanks/cockpit/ inlets, dose it alter the performance at all? And how much weight would I gain ? Not going to glass cloth mine and how did you get the strength in the wing/tanks for landings.
Old Jul 16, 2009, 09:12 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
The tank installation is on post 26 on the following thread.
http://www.rcgroups.com/forums/showthread.php?t=1065911
As for the gnome engine, 1/6 would be the scale if you rounded it up just a bit.
I hate to assign a scale value to any of the models because the experts tend to get a kick out of breaking out the calipers and showing off what they have researched. The sad truth is you can take any three view and compare it against another and the never match.
All a guy can do is his best.
Old Jul 16, 2009, 10:32 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Any idea how much the tanks effect performance? Did you have any flights before adding the tanks to compare it to?
techspy is offline Find More Posts by techspy
Old Jul 16, 2009, 11:26 AM
j6myw is offline
Hampshire UK
Joined Oct 2008
Ok just got home and the mirage is in the box with no damage,, it dry fits well,, so what are the do"s and Donts any issues? and you cant get to the fan after it is installed anyone made a hatch?
Old Jul 16, 2009, 11:31 AM
BrentP is offline
Closed Account
Joined Apr 2008
Yes some of us have. Post #823
http://www.rcgroups.com/forums/showp...&postcount=823
Old Jul 16, 2009, 11:34 AM
BrentP is offline
Closed Account
Joined Apr 2008
The DR1 is about 1/5.5 scale so if it was rounded down a bit to be 1/6 I would be good.
Guess I'll have to scratch build one.
Thanks Sparks
Old Jul 16, 2009, 01:13 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Tanks and performance.
There are a bunch of "ifs" to consider.
In my case I flew the model with the gear, and without the gear. Without the gear made it a different model.
Landing speed required less power and it did fly faster as you would expect.
Then I added the fiberglass weight and the tank weight it became harder to get in the air and landed faster, again as you would expect.
The difference between the gear system and the tanks is 4 ounces. However they offer less drag.
Trading weight for less drag is a personal choice.
Now the truth.
If I had a new naked Mirage it would get the tanks because I know it will takeoff from them.
As for this heavier one I have now, When the tanks see the end of their service life they will be taken off and belly landings will be tried before I replace them.
J6myw
Here is a don't. don't belly land the model without protecting the servo arms and linkage.
also, be sure to protect the wing latch. The grass will release the wing on landing.
I got lucky, when I went to lift the model the wing stayed on the ground.
Old Jul 16, 2009, 01:52 PM
BrentP is offline
Closed Account
Joined Apr 2008
Sparks me again, I wasn't paying attention to the tanks till now.
That could be just the ticket for me for take offs if it will.
I'm at about 2500g not glassed.
I started to have hand launch problems and haven't flown it since.
Thought about a bungee, but the tanks could be easier and I'm fine with any reduction due to drag.
I guess I must have missed something, do you sell the tanks? As I can't seem to find them on your site. Link me and I will buy them and take the WW1 engine and try to mod it.
Thanks Brent.
edit: Found the tank # on the other thread.
Old Jul 16, 2009, 02:12 PM
BrentP is offline
Closed Account
Joined Apr 2008
Hmmm I read Sparks last post in the other thread about scary tanks takeoff so I guess back to thinking bungee LOL.
Video FlyFly Mirage 2000 maiden bill34207 Electric Plane Talk 4 Feb 17, 2008 08:29 PM
Video 90mm EDF Mirage 2000 Maiden Ernest Electric Plane Talk 4 Jun 25, 2007 02:56 PM
For Sale Wattage Mirage 2000 with brushless motor shschon Aircraft - Electric - Jets (FS/W) 2 Mar 04, 2007 09:01 PM
Mirage 2000 with landing gear? webnetxpress Foamies (Kits) 8 Jan 27, 2003 10:16 AM
Mirage 2000-5 with a 15/2 kushal_22 Foamies (Kits) 21 Jan 14, 2003 10:43 AM
