Thanks Wobby great idea bout the torches! Cant remember what voltage the super leds are?? Im not an expert in electrics but I remember building an anchor light for my boat out of these leds when they first came onto market. I had to use some resistors in line for 3 leds on a 12 volt system. Now u see them everywhere, even in traffic lts by the look of it.
OZZI!! Hijack it any time u want! Re Vise Grip....I stuck my depron panels to the underside of the mirage using it and no probs..It says on the bottle that it sticks almost anything!!! Well it doesnt do plastic and it says on the bottle that at least one surface has to be pourous and like nearly any glue the more pourous the surfaces, the better the bond. As far as sticking foam is concerned it sticks like bear kack to a hunters boot! I would use it for Balsa too.IMHO it is lighter than epoxy - tho I havent weighed it... Im not sure if it has any more flex than epoxy cause it seems to set like a rock yet sands fairly easily but it does tend to creep and foam up a wee bit but if u use it sparingly u can minimise the sanding. Its one glue you have to watch dry and as Mark said you can cut off the foam bits with a blade before it sets. Takes a bout the same time to set as aliphatic resins and PVC glues ie overnight. It seems to resemble contact cement but is runny like honey. I got a pretty good bond all around the fuse without much creep at all. I have resorted to epoxy tho for all ply bracing, round the retracts and wing join etc ....Sat in the sunroom with a razor blade and started the tail cone reduction....8 slits later and pulled the thing in with a noose made out of VB cord....I used vise grip and got it all over my hands and onto the foam - it was a bit of a sh^%tfight....I ended up having to put back some "half slithers" because when I was pulling it in with the string (string noose was good idea) I was able to see that some parts of the now "octa hedral" were not meeting due to my slack cutting technique. However the vise grip and the noose worked in the end, and as I sat there sobbing and wiping the glue excess off, my wife pointed out that I seemed to have quite a bit of blotching on my skin, all over my hands and half way up my arm! To this day I am still not sure what the correct solvent for Vise Grip is but metho is better than water....Lots of hand washing that night and the irritation has subsided. Come to think of it I have been getting a minor irritation from the foam as well and I dont usually have any reactions and Im always working round chemicals in my job?!I think Wobby used some tape on the inside of the cone to keep his together but I found that one needed quite a bit of force to pull it in so I glued it. The foam here is quite thick, I was afraid that the whole piece was going to crack but it didnt. See some earlier pics in this thread for the before shots. The master builders who are reading this (u know who youse are) are probably having a good belly laugh by now!! Anyhoo I havent left myself too much repair work to make it slick....and sorry Mark whilst the Aussie colours make me a proud old bugger......I am going for a "hide in the snow" type camo effect....whites with very light bluey grey and silver cone airbrushed with a carbon effect.....that'll be a belly laugh for another day
http://www.rcgroups.com/forums/showt...78#post9939152 |
Joined May 2007
Those leds in the tail look too much like leds in the tail i feel.
Heres a couple of photos that lyndon posted on our PP thread, pretty sexy looking i think. ![]() I like how the paint is wearing away in areas , caused by airflow i guess. BTW, Mike, I spent a little time on the canopy trying to get it flush. LOTS of carving and triming on the airframe to get a reasonable fit. I think she still looks ok for a foam plane thats had maybe more than 150 flights now, and still going strong. The nose got a little dent becouse some turky at the club picked it up and stood it on its nose to try look down the exhaust. I dont have the plastic nose cone on it. |
Alexandra
Joined Jul 2007
Started my mirage build
Well finally got on with the build, here's a few pics of what I am up to. I started playing with the canopy as it's about the only thing on the plane I am not really happy with.
R U talking about inside diameter re the tail cone outlet? Mark from extreme rc recomends 78 to 80mm. Wobby elswhere in this thread is 90mm but I assume he is talking outside dia? I got mine to 81 so Im in the ball park, its not an easy job trying to keep in neat, the wire ties work well.....Its the first thing I thought of but didnt have any. The noose was good, however it left some marks. I am busy trying to fill/repair the tail cone to its former glory and find that the vise grip glue is not as easy to sand as first thought especially when the foam near the glue easily sands away but the glue is stubborn?? What did u use to glu it? I also thought that the canopy was a slight disapointment. I dont have very good cutting skills or cutting tools and go feint at the thought of having to cut something like that strong canopy plastic and be neat and straight So after cutting both pieces out to near the line, I thought I would be able to sand it after I glue the two pieces together. I first used epoxy with no success, was then told to use double sided tape.......Good Wife procured said roll of tape (3m brand) but she said it wasnt much good.......she was right! I then used some industrial 2mm thick foam tape that I had been given by a glazier....this stuff would stick snow to ice cream! Unfortunately I got it well crooked so I had to pull it apart nearly damaging it in the process - it bears the scars! I have now roughened all the surfaces to be bonded with a Dremel and gone back to epoxy.......vwah-la! solid as a rock, I was silly trying to stick it in the first place without this preperation. I understand that other guys use the Double Sided tape please let me know the brand! As for sanding it....I used a belt sander clamped to my workbench and gently got both sides, front and back, nice and straight. Surprisingly I had quite course paper loaded on the sander and it worked well so long as your gentle. Will be painting, so the canopy scars will dissappear. Love the other ideas look foward to seeing more!
As for the brilliant pic of mirage, can u tell us more details? where was it shot? What is he carrying on the wings? who shot it
Alexandra
Joined Jul 2007
More pics
I started using the glue in the pak, but it's so damned cold up here it wont set so I went over to 5 min epoxy.
Played with the painting today.... I tried taping and free hand, not real happy with tape lines, I think it looks to clean. The rough edge looks better ? |
Joined May 2007
Mike, my outlet measures 85-90mm inside diameter depending on where i measure from, looks roundish, obviously isn't. But the difference in thrust and speed from 100mm stock to where i have mine now was HUGE !!!
Double sided tape 3M is crap, in fact most ds tapes bought retail are no good. I use Kikasui tape from Japan used in picture framing industry, has a fibre base that you cant barely tare, and the most aggressive adhesive that actually cures over time also. I use it on all my canopy's. Rally, nice job, Ive got my pilot on the bench, going to paint the helmut on mine now that ive seen yours..... BTW guys, My battery just sits loose inside behind a wooden dowl to stop it moving forward. My pilot then site on top of the battery, then the canopy over the pilot, esentially the pilot and canopy holding the battery in place. Mike, I have no info on the photos, they were posted by Lyndon on the PP thread. If i had a large format printer, I could almost be tempted to print the photo out, cut out the tiger tripes eye design, and stick it to the top of the wing. Im surrounded by turkeys all the time, lol. This site has the best video of the mirage i have ever seen, to vid at the top of the page is stunning. http://www.military-heat.com/76/dassault-mirage-2000/ read the pretext about the vid, very interesting. |
Alexandra
Joined Jul 2007
little bit more
Hi Mike, hope you don't mind me hanging out in your forum.
![]() Well didn't get much done today, procrastinating about the fan and esc. Anyone running there esc behind the fan ? I grabbed a prebuilt setup from another plane and the esc wont sit in front of the fan. Think it will effect airflow much ? Wobby got any pics of inside the cockpit area ? keen to see where your battery sits. Look like I will be flying 5000 5s batteries. Bigger batteries ? Should I use double banana plugs female ie for both + and - on the batteries to be safer ? Double sided tape - I successfully used a local hardware store tape called "Bear" it's a Norton P/L product. Slowly cut strips and applied one side rubbed it to warm everything up then removed cover and slowly brought sides together. For my first "taped" canopy I am pretty happy with the product and process. I did get a few little extras done on canopy. Let me know if you think it's overkill. |
Joined May 2007
Looking good Rally.
My Esc (60amp) is in front of the fan burried in the upper left wall (sort of) I think the rule for bullets is (BATTERY) female on pos, and male on neg. I tuck the leads under rubber bands that i have on all my batteries when not in use. you can see the rubber band in the photo in case you were wandering what it was for. hopefully the photo show a little more. So Mike, ready for maiden yet? cheers
| Thread Tools | |
| Video FlyFly Mirage 2000 maiden | bill34207 | Electric Plane Talk | 4 | Feb 17, 2008 08:29 PM |
| Video 90mm EDF Mirage 2000 Maiden | Ernest | Electric Plane Talk | 4 | Jun 25, 2007 02:56 PM |
| For Sale Wattage Mirage 2000 with brushless motor | shschon | Aircraft - Electric - Jets (FS/W) | 2 | Mar 04, 2007 09:01 PM |
| Mirage 2000 with landing gear? | webnetxpress | Foamies (Kits) | 8 | Jan 27, 2003 10:16 AM |
| Mirage 2000-5 with a 15/2 | kushal_22 | Foamies (Kits) | 21 | Jan 14, 2003 10:43 AM |
