Old Oct 07, 2012, 08:14 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
4400 would be fine, just use some throttle management so you dont get it too hot.
The black retracts would be ok, the grey ones are a little lightweight, I have some of them for the HET 262, its made for them, and I wouldnt use them in a 90mm myself especially if on grass.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Oct 07, 2012, 08:29 PM
out of stock is offline
Find More Posts by out of stock
DONT PANIC! :)
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
when you say the black ones you mean the metal trunnions?
out of stock is offline Find More Posts by out of stock
Old Oct 07, 2012, 08:43 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, L'Orignal
Joined Nov 2010
Get yourself a set of these and never look back. Perfect if you're over 3.0kg and operating on grass.
http://www.pw-rc.com/product_info.ph...fbcrkc9gd8eg85
vanderbrander is offline Find More Posts by vanderbrander
Old Oct 08, 2012, 01:06 AM
DONT PANIC! :)
Joined Jan 2012
awesome find thanks.... ill be getting these.... so i need 3x of these correct? is there a different one for the nose gear or 3 of these will do the job? (i have never delt with retracts before) again thanks!
ohh wait, what servos are adequate for this model?
are hitec hs 65hb's doable?? i think their okay....
Old Oct 09, 2012, 12:59 PM
DONT PANIC! :)
Joined Jan 2012
double post sorry lol
Old Oct 20, 2012, 05:08 PM
scunna is online now
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
decided to paint mine
scunna is online now Find More Posts by scunna
Old Oct 20, 2012, 05:24 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
You will be able to buy decals soon that will work in perfectly with your paint scheme
Old Oct 20, 2012, 07:48 PM
DONT PANIC! :)
Joined Jan 2012
wow good job!
scunna your not using the nose cone are you? i bet alot of people skip it. mines came with a small split. i might just chuck it
Old Oct 20, 2012, 08:08 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
The world's coolest leaf blower.
World's Coolest 90mm 6s Leaf Blower Disguised as a Dassault Mirage (0 min 43 sec)
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Oct 20, 2012, 08:57 PM
Joined Nov 2010
Scunna - do you actually work?? You probably don't have 3 kids and a full time job like i do because mate every time I see you you've got something new ready to fly.
Awesome Mirage. Post some vid when you get it going. All your vids are sweet.
I guess you'll be going with a perfectly balance CS12 (again)??
Old Oct 20, 2012, 08:58 PM
Joined Nov 2010
Soon as you get them Mark let us know because I want some for mine.
Old Oct 29, 2012, 09:28 PM
DONT PANIC! :)
Joined Jan 2012
whats the average ideal weight on this model on 6s (no retracts) i guess what i want to know is, for good flight behavior whats the weight limit? (im afraid my questions are rather confusing)
Old Nov 07, 2012, 02:52 AM
leebee1965 is offline
Find More Posts by leebee1965
Flying RC since 1980
leebee1965's Avatar
Australia, NSW, Bonny Hills
Joined Aug 2012
I think I might take my retracts out and go with a bungee launch. We have a sealed strip, but it’s always cross wind, our grass strip is better, but I don’t know if I would get it off the ground before the fence! The recommended hook location is 600mm from the nose, but I’m not sure just gluing a ply plate to it is going to hang on with 11kg of tension. Has anyone done this yet?
leebee1965 is offline Find More Posts by leebee1965
Old Nov 07, 2012, 05:22 AM
Graham d is offline
Find More Posts by Graham d
South Africa, GP, Pretoria
Joined Mar 2011
Originally Posted by leebee1965 View Post
I think I might take my retracts out and go with a bungee launch. We have a sealed strip, but itís always cross wind, our grass strip is better, but I donít know if I would get it off the ground before the fence! The recommended hook location is 600mm from the nose, but Iím not sure just gluing a ply plate to it is going to hang on with 11kg of tension. Has anyone done this yet?
I have found that the Mirage takes to the air a lot sooner on grass than on a sealed strip. Think the reason is that it is not even and if you get a little bump to get the positive AOA it takes to the air. Just make sure that the retracts and oleos can handle the grass.
Graham d is offline Find More Posts by Graham d
Old Nov 07, 2012, 03:59 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Hand Launch is very easy with the Mirage, just cut slots for fingers in the bottom at the CG area or just in front. I usually dremel out a thumb hole and a slot for the fingers, works great. Its about the most non event HL model around, the stability means it just floats out on its own.
Video FlyFly Mirage 2000 maiden bill34207 Electric Plane Talk 4 Feb 17, 2008 09:29 PM
Video 90mm EDF Mirage 2000 Maiden Ernest Electric Plane Talk 4 Jun 25, 2007 03:56 PM
For Sale Wattage Mirage 2000 with brushless motor shschon Aircraft - Electric - Jets (FS/W) 2 Mar 04, 2007 10:01 PM
Mirage 2000 with landing gear? webnetxpress Foamies (Kits) 8 Jan 27, 2003 11:16 AM
Mirage 2000-5 with a 15/2 kushal_22 Foamies (Kits) 21 Jan 14, 2003 11:43 AM
