Old Sep 27, 2012, 12:06 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Hey guys, am working on the decals now for the Aussie camo mirage, gonna have to order 300 sets from the looks of it to make them affordable.
Who would be interested in buying decals?? They will be based on the version below, mirror image tail decals and roundels, as well as various small markings around the fuse etc. Decal sets will be around 5-6 bucks.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Sep 27, 2012, 03:12 AM
leebee1965 is offline
Find More Posts by leebee1965
Flying RC since 1980
leebee1965's Avatar
Australia, NSW, Bonny Hills
Joined Aug 2012
I'd get a set, I think the yellow tail will help in seeing the plane better. How much for post to 2445 ?
leebee1965 is offline Find More Posts by leebee1965
Old Sep 27, 2012, 03:21 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Gonna be a few months yet! But I would cut them up and pack in A4 with cardboard backing, likely 3-5 bucks to ship them properly.
Old Sep 27, 2012, 09:20 AM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
indeed. well i get my ff mirage today! im at work & im all grrr!!
i actually get 2 planes today. the hk t45 goshawk and mirage. ironically they arrive the same day. anyway hope all goes well on your next flight! cutting out the rudder shouldnt be so hard would it? just use xacto and add ca hinges? im doing it.
out of stock is offline Find More Posts by out of stock
Old Sep 27, 2012, 12:18 PM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Count me in for a set Mark - still haven't got my Mirage built yet
vanderbrander is offline Find More Posts by vanderbrander
Old Sep 27, 2012, 06:11 PM
Speed only
Joined Jan 2012
well i received just the t45 goshawk from hobbyking. (ill never purchase a bird from them again. missing horizontal stabilizer and vertical stabilizer)
my ff mirage should arrive tomorrow.
Old Sep 28, 2012, 01:10 AM
Graham d is offline
Find More Posts by Graham d
South Africa, GP, Pretoria
Joined Mar 2011
Ouch!! I know that there were many people that got their 70mm Rafale's with two right wings
Good luck with their Customer Service.
Graham d is offline Find More Posts by Graham d
Old Sep 28, 2012, 02:11 AM
leebee1965's Avatar
Joined Aug 2012
Cutting the rudder out is the easy part, putting in another servo and running the cable back to the nose is the hard bit.
Old Sep 29, 2012, 01:00 AM
Speed only
Joined Jan 2012
graham, yes i followed that thread. rubbish....
leebee, it shouldn't be that difficult i hope lol..
i added a servo to my sapac euro easily with no prior building experience.
question: ca hinges will work for foam???
Old Sep 29, 2012, 07:37 AM
Joined Nov 2010
Ca hinges work on foam but don't use CA it will eat the foam. Use a very thin smear of gorilla glue and they will never come out.
Old Sep 29, 2012, 05:18 PM
Speed only
Joined Jan 2012
do i add the glue to hinges and insert to control surface let dry THEN add glue to exposed hinges and slide them into V-stab?
or
the traditional way? (i ask because gorilla glue seems thicker than ca and wont seep like ca does)
Old Sep 29, 2012, 07:45 PM
Joined Nov 2010
Add a small amount (and when I say small - I mean a VERY thin coat) on the hinge, just enough to dampen it.
Slip them into the control surface. Immediately wipe off any excess with a damp cloth. Wait a couple of hours (more if you can) until it dries.
Repeat the above on the wing/vstab. Wipe off any excess immediatey. Once dry, give them a firm pull to check for security. If you glued them correctly, the hinge will be stronger than the surrounding foam and they will never come out.
Exercise the control surface fully to loosen up the hinge point.
Old Sep 30, 2012, 12:00 AM
Speed only
Joined Jan 2012
couldn't thank you enough! i will use very little as you advised.
may i ask, what other EDF's produce a wooosh turbine like sound other than changesun? ( perferably a combo set that comes balanced)
i was explained to on how to balance a 90mm changesun edf but maaan, im afraid to do it wrong.
actually i found this but wouldn't be available till after october 25th which is fine. im preordering.
my question is, does it come balanced? ill contact them.
http://parkrcmodels.com/product_info...3umvkljg79f7k1
Old Sep 30, 2012, 12:14 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Stumax
Odysis is offline Find More Posts by Odysis
Old Sep 30, 2012, 12:29 AM
Speed only
Joined Jan 2012
this thing must sound phenomenal. i love real turbine rc jets but edf's are taking over imo. however $400 is a little ehhh
Video FlyFly Mirage 2000 maiden bill34207 Electric Plane Talk 4 Feb 17, 2008 08:29 PM
Video 90mm EDF Mirage 2000 Maiden Ernest Electric Plane Talk 4 Jun 25, 2007 02:56 PM
For Sale Wattage Mirage 2000 with brushless motor shschon Aircraft - Electric - Jets (FS/W) 2 Mar 04, 2007 09:01 PM
Mirage 2000 with landing gear? webnetxpress Foamies (Kits) 8 Jan 27, 2003 10:16 AM
Mirage 2000-5 with a 15/2 kushal_22 Foamies (Kits) 21 Jan 14, 2003 10:43 AM
