Old Jan 23, 2003, 10:30 PM
neonbutterfly is offline
Find More Posts by neonbutterfly
LSF186
neonbutterfly's Avatar
Wayne, NJ
Joined Jan 2003
Glass Filled and Carbon Fiber Props
Hi!!
I need some help here. What is the difference between glass filled and carbon fiber props other than the material used. Is there an advantage of using one over the other? Is one lighter than the other. Strength to weight ratio of glass filled to carbon fiber?
I am looking at an Aeronaut folding prop system for my Filip 600 -RET. Do the prop blades have to be balanced? If so, How do you do that.
Thanks in advance
Bob
neonbutterfly is offline Find More Posts by neonbutterfly
Old Jan 23, 2003, 11:42 PM
BillM is offline
Find More Posts by BillM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
Cabon fiber is both lighter and stronger.
BillM is offline Find More Posts by BillM
Old Jan 24, 2003, 08:14 AM
flight999 is offline
Find More Posts by flight999
flight999
England
Joined Dec 2002
Carbon are heavier and stiffer.
Also fashionable and more expensive.
Don't think it makes much
difference performance wise.
To bsalance; Tighten blades on hub
so they can't fold. Make sure they
are flat and straight then balance in
the normal way.
flight999 is offline Find More Posts by flight999
Old Jan 24, 2003, 09:23 AM
Alan W is offline
Find More Posts by Alan W
Alan W's Avatar
NY
Joined May 2000
THAT all depends on your power loading. I wouldn't want to be ANYWHERE around you when you Try to put 1000 watts into a Glass-filled nylon prop !!!
Alan W is offline Find More Posts by Alan W
Old Jan 24, 2003, 09:37 AM
Atindra is offline
Find More Posts by Atindra
Balsa Snob - Mostly
United States, PA, Riegelsville
Joined Jul 2001
My two cents...
The blades are rated for a specific not to be exceeded RPM. Also thin vs broad blades are rated for different rpm. Diameter (inertia) also has a bearing on max rpm,weight too.
All depends on the application, carbon is stiffer, but really matters only when striving for max performance., and if you have the motor system and airframe for that.
I never had to weigh them for comparison, there is no non-Carbon 16x16 prop that I know of !
Aeronaut is good, I have used them, prop/spinner/yoke and all for up to 11x8 props and brushed Sp600 motors for electric gliders like Omen 1.8 m/Spectra etc.
IMHO, the whole system, motor/prop/yoke/spinner/prop hub bolts have to be consistent with the application.
In F5B applications, those 17x18+ props on 24+ cells must have the blade tips moving at close to the speed of sound (I think ?), CF all the way for that purpose. Light and stiff tips, light and strong hub.
Oh, one more thing, you have plastic props (Gunther), Glass Fibre (Aeronaut White), Carbon reinforced GF (Aeronaut Black), and all carbon (RFM 15x15 etc).
Atindra is offline Find More Posts by Atindra
Old Jan 24, 2003, 10:19 AM
flight999
England
Joined Dec 2002
Alan.
No one is talking 1000W and you certainly are not doing them on the model under discussion unless.................!!! In which case you shouldn't be in a position to ask such a question, I hope you would know!
carbon fiber props mac52 Glow to Electric Conversions 5 Dec 01, 2005 01:15 PM
For Sale dose any one work eith fiber glass or carbon fiber ?? i have some hB fp blade molds littlepiston Aircraft - Electric - Helis (FS/W) 0 Jul 16, 2005 05:32 PM
Pic's Carbon Fiber Props Villian Ex MeBluEyz99 Racing Boats - Electric 2 Jul 19, 2004 12:03 AM
APC Carbon Fiber Props Azarr High Performance 23 Nov 03, 2003 08:31 PM
