Old Jun 11, 2008, 02:44 PM
Q-HUNTER is offline
Find More Posts by Q-HUNTER
Thats gona be expensive
Q-HUNTER's Avatar
Glenside Pa
Joined Jul 2001
Mini ultrastick or Stevens shaft 25e
Any opinions of the two? Close enough in price but does the shaft warrant a build??? Since the M.U.S is already built I'm leaning that way.
kenny
Q-HUNTER is offline Find More Posts by Q-HUNTER
Old Jun 11, 2008, 03:20 PM
mxerman is offline
Find More Posts by mxerman
mxerman's Avatar
USA, AL, Montgomery
Joined Feb 2006
MUS all the way!! Its a 1 hour assembly for the ARF. Flys great on a 3s 2000MAH battery. Just too easy. The plane is very aerobatic but slows down and lands real slow. Good luck, mxerman
mxerman is offline Find More Posts by mxerman
Old Jun 11, 2008, 03:32 PM
Q-HUNTER is offline
Q-HUNTER's Avatar
Glenside Pa
Joined Jul 2001
I'm looking at two motors for this, the Hacker A30-16m or the Axi 2217-16 on 3S 2200.
I'm soooo troubled.
Old Jun 11, 2008, 05:08 PM
Unterhausen is offline
Find More Posts by Unterhausen
5 miles from the geographical center of Pennsylvania
Joined Aug 2005
I think you would probably like the Stevens better. Too bad all the Shaft flyers are up in the parkflyer forum
Unterhausen is offline Find More Posts by Unterhausen
Old Jun 11, 2008, 07:13 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Shaft is lighter and will fly beter due to lower wing loading.
And building is a snap with SA kits. They almost shouldn't be called kits.
The time is taken in covering. But even that doesn't take too long, unless you want a super fancy intricate design.
Pinecone is offline Find More Posts by Pinecone
Old Jun 11, 2008, 07:19 PM
mxerman is offline
mxerman's Avatar
USA, AL, Montgomery
Joined Feb 2006
The A30-28s or E-Flight 480 is the way to go on the MUS. Max power and about 10-15 min on that battery. 9-6 up to 11-7 prop. You wont go wrong. mxerman
Old Jun 11, 2008, 07:52 PM
Q-HUNTER is offline
Q-HUNTER's Avatar
Glenside Pa
Joined Jul 2001
Figures... I just sent money on the A30-16
Well , I'll see how it works. My guess is that it will fly.
Old Jun 12, 2008, 05:44 AM
mxerman is offline
mxerman's Avatar
USA, AL, Montgomery
Joined Feb 2006
Its going to be nose heavy. You will need to find a way to get some weight to the rear. Battery, servos, something.. mxerman
Old Jun 12, 2008, 08:13 AM
Stevens AeroModel is offline
Find More Posts by Stevens AeroModel
Truss-Loc Monkey
Stevens AeroModel's Avatar
Colorado Springs, CO
Joined Feb 2002
As you may be aware you are looking at two different size/classes of plane. The equivalent size SHAFT to the MUS's 325 squares of wing would be the SHAFT 400 ($60.00) at 340 squares. The SHAFT 25e ($110.00), at 600 squares of wing, is about double the size of the MUS yet weighs in about 32oz (only 5oz more than a MUS!) assuming your MUS come in the same weight as this fella (http://www.rcgroups.com/forums/showthread.php?t=536655) Honestly, it would be an unfair of me to make a comparison between the MUS and the 25e as I even gravitate to the SHAFT 25e over the SHAFT 400 which is already a fantastic sport aerobatic flyer.
Specs for the Shaft 25e and A30-16M
http://www.stevensaero.com/StevensAe...E-p-19425.html
Specs for the Shaft 400 and A20-20L
http://www.stevensaero.com/StevensAe...0-p-19120.html
-Bill
Stevens AeroModel is offline Find More Posts by Stevens AeroModel
Old Jun 22, 2008, 09:23 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
I >almost< purchased the 25e for 94 bucks on Friday. I will the next time!!!!
-Bill
going4speed is offline Find More Posts by going4speed
Old Jun 22, 2008, 09:24 PM
3DHS 'native'
USA, TX, Spring
What do you like about the 25e over the 400?
-Bill
Old Jun 23, 2008, 09:11 AM
Truss-Loc Monkey
Joined Feb 2002
Size, The large size of the 25e coupled with the light loading make this feel like an exceptionally large airplane. The plane bounces around much less in windy conditions and simply has a more substantial feel about it when airborne. Otherwise performance and aerobatic capability are similar.
-Bill
Old Jun 23, 2008, 12:15 PM
3DHS 'native'
USA, TX, Spring
Bill,
You are going to put me in the poor house!!
-Bill
Old Jun 23, 2008, 03:26 PM
mxerman is offline
mxerman's Avatar
USA, AL, Montgomery
Joined Feb 2006
You can get the ultra stick in 25 size too. That said lighter wing loading, more surface= less stability in wind. Extreme example would be a rock and a balloon. Either plane will be great but don't be mislead by inaccurate facts. mxerman
Old Jun 23, 2008, 05:23 PM
3DHS 'native'
USA, TX, Spring
Inaccurate facts....what do you speak of?
While we are at it....what exactly is an inaccurate fact?
Discussion SHAFT 25e - Stevens AeroModel - Available Now! Stevens AeroModel Parkflyers 474 Jun 22, 2010 07:19 PM
For Sale Mini Ultrastick Pnp setup or electronics. pref local. dave1982 Aircraft - Electric - Airplanes (FS/W) 1 Apr 21, 2008 06:28 PM
Wanted radicle rc mini or micro stik,Stevens Shaft skyforcecapt Aircraft - Electric - Airplanes (FS/W) 0 Jan 28, 2008 08:20 PM
